Tony Davis Posted March 16, 2021 Share Posted March 16, 2021 Hope this is the correct forum. I am looking for a guide to masking off the division between the upper and lower wing surfaces for airbrushing, initially on a 1/72 Spit. Should I just put masking tape on "sideways" around the wing edges, or would that bleed? Also, sometimes the upper surface colour "wraps around" the wing edge to the underside, so how to tackle that? Any other tips I should be aware of? Regards Tony Link to comment Share on other sites More sharing options...
ckw Posted March 16, 2021 Share Posted March 16, 2021 I use thing strips of masking tape along the length of the leading and trailing edges - wrapping round the leading edge as required. To avoid bleeding - use good quality tape (e.g. Tamiya) and make sure the tape edges are clean - burnish the edge after applying (I rub the edge down with a rounded wooden dowel, but a paint brush handle would probably do) - when spraying, don't use too high a pressure, use light coats and don't spray into the edge - keep the airbrush at 90 degrees to the surface Cheers Colin 1 Link to comment Share on other sites More sharing options...
Tony Davis Posted March 17, 2021 Author Share Posted March 17, 2021 Thanks Colin Link to comment Share on other sites More sharing options...
