Had this mostly built gathering dust on the shelf for a couple of years.
If it wasn't for the fact that this was mostly built up, it was too advanced in build to enter into the Interceptors GB but since as I'd just done the MiG, I thought it was only right that I should complete its western counterpart
Finally got it done & at last got to grips with Alclad as opposed to the Vallejo Metal Colour on the MiG. Added another pic of them both side by side for size comparison & comparison between the metal finishes.
So this is the Sword kit which is a short run kit & should be treated as such. The seam lines on the underside were a pain to ensure that they didn't show up after priming. There was a lot of filling & priming involved but the underside join still faintly shows through.
Sword provides a resin insert for the two Avon exhausts which are quite nice only once in, they're not a perfect fit. Either a fine shim inbetween the fuselage halves is needed, or a little bit of filler around the resin is needed.
Talking about the resin exhaust, would have been good if they had produced a resin nose ring. The kit halves around the nose were short shot, so it would have taken some sprue filler to correct that, so I added the Quickboost resin nose ring for the Trumpeter kit which fetted exactly & improved on the overall length of the model.
I also find that Sword kits in 1/72 have very shallow fine panel lines, so I usually give them a going over to slightly deepen them.
Decals are a mix of the kit decals & used some stencil data from the Airfix F.6, only those that applied, similar to what went on the F.3.
Thankfully the Sword tail fin markings actually fit the tail fin which was a bonus as a lot of the time with large dcals, they're not always exact in dimensions. Everything else is just out of the box.
First success using Alclad over their gloss black base. Used some Vallejo Metal Colour for picking out some individual panels. Used Ammo Mig red for the spine, custom mix Klear gloss & Ammo PLW.
English Electric Lightning F.3 XR719 D Wattisham Summer 1965
And a couple for size comparison.
Thanks for looking!
Martin
  • Like 43
Very nice NMF aircraft which could be placed next to my recent Mirage III B.
Thank you for sharing.
Patrick
you can't beat a nice frightning ,nice nmf i just can't seem to get that right but i can't use alclas because of the fumes
Striking Lightning!
My word,  that is a real beauty.  Flawless finish and I bet that looks lovely on display.
I have to agree. That's one sharp looking Lightning.
 Very nicely done, looks great in those 56 sqdn colours.
 Glad you got the hang of Alclad paints, you've done a cracking job.
 gazza l
Ooooo!!!!  That is pure eye-candy! Lovely work. Makes me want to do a Lightning. But, I just finished three NMF builds and I need to do something different.
5 hours ago, Avgas said:
That's a good looking pair!
Aha! Awwwmmmatron! 😆
Cheers Avgas!
5 hours ago, ForestFan said:
Stunning!
Cheers mate! 👍
Patrick
Cheers mate, yep really liked that Mirage IIIB of yours. Must get that some time, but got to work out which scheme to do it in. Will definitely be another metal one!
Cheers! I've been mostly using the Vallejo Metal Colour range up until now & I'd highly recommend those if you don't want to use Alclad.
I purchased some Alclad six years ago & this is my first proper go with it. I just thought I've had that paint for ages & I might as well use it properly.
I do have to confess that I ended up giving parts of the fuselage a dusting of the Vallejo Airframe Aluminium on top of the Alclad as in my opinion, the Alclad seemed too bright for the scale. That might have been because I used the gloss black underneath. Next time I will use a grey primer.
Martin
4 hours ago, Plasticbasher said:
Fantastic! Both great replicas of iconic aircraft. The size comparison is interesting too.
Cheers mate, that's another reason why I only build in one scale. Bit of a 60's theme going on as well.
Thank you for sharing this build Martin. I must say I think the lightning is my favourite jet aircraft. Yours looks superb!
Nice to note you choose a 56 Squadron example! My uncle Peter flew Tempest Vs with 56 in early 1945. I'm doing one of his aircraft in 1:32 .. Up the Firebirds I say! Regards, Andy
Thanks Booty003 I am rather pleased with it. Does inspire more metal themed jets!
Many thanks Andy, for me this scheme has to be the ultimate profile for the Lightning in all it's permutations. I read that it drew a lot of fierce reactions from upon high which is a shame. Love the sound of your Tempest build look forward to checking that out. Awesome aircraft. Hopefully we'll see one flying one day.
Wow!   That's beautiful!
The NMF's so shiny I need sunglasses to look at it! 😎
Waow !! The fight was though but you finally tamed this beast !!
That's a great result Martin !!
Congratulations !!
The MiG look great too, nice cold war foes !!
Sincerely.
CC
Martin, what a great finish, and the scheme which does the Lightning proud too!
Thanks also for the tip about adding a shim at the back end, I have built three Sword Lightnings (T4, F1, and F3) and have never thought about that, despite not being happy with the result, I still have two more to go.
Thanks for brightening my day,
Ray
