Mike Posted March 14, 2021 Share Posted March 14, 2021 Fi-156 Storch Interior 3D Decal (QD48078 for Tamiya) 1:48 Quinta Studios When Quinta’s innovative products first came to our attention recently, they caused quite a stir, as well they should. The replacement Instrument Panels and internal details are mind-boggling to look at, because we’re used to seeing simplified styrene instrument panels, or pre-painted Photo-Etch Brass panels with either two layers of etch, or laminated parts that can be tricky to glue together, even though they are pre-painted for your ease. But decals? These aren’t your run-of-the-mill decals though, they’re 3D printed in many layers and colours on a flat carrier film, having as much in the way of relief as is needed to complete a realistic panel printed in the correct colours, complete with shiny dial faces, MFDs and metallic-effect hardware, often also including cushions and seat belts in the set. Each set arrives in a ziplok bag with two folded instruction booklets protecting the decals, which are also separately bagged, so they should reach you in good condition. The pictorial instructions are printed on glossy paper, and are shown in full colour as befits the detailed nature of the sets, showing exactly where each part should go on the actual model, so there’s no confusion due to pictures speaking a thousand words, as they say. Additional hints and instructions for the uninitiated are also included, marking out parts needing bases, kit parts and other useful tips. The technical instructions in the text-based sheet give additional tips to the new user about maximising adhesion and preventing lift at the edges by wicking in super glue. Application is much the same as your standard decal, but you will need to remove any raised detail that would be underneath the location depicted in the instructions, and some new parts will need small backing panels or bases on which to apply the decal. A slim piece of sheet styrene would perform that task, and painting the edges a matching colour should minimise its appearance or turn it completely invisible. This set is patterned for the excellent Tamiya kit of the type that was released a few years back now, but it’s still the top of a very small heap by quite a way. The set comprises two small sheets, containing instrument panel sections, two large radio boxes, levers and other instruments, the dials having a lustrous shiny finish, just like the real glass panes. The panels are in the RLM 66 dark grey, and includes mag straps if your Storch was fitted with a self-defence machine gun, seatbelts for up to three crew members, rudder pedal straps, plus small instruments on the canopy internal framework. Conclusion The detail on the parts is incredible, even down to the infinitesimal switches, the texture of the main panel and impressive crispness of the set. Any Quinta outfitted cockpit really needs a crystal-clear or opened canopy to show off the details. Very highly recommended. Review sample courtesy of 2 Link to comment Share on other sites More sharing options...
