is it windy yet? Posted March 13, 2021 Share Posted March 13, 2021 I want to make an RAF Eurofighter Typhoon in 1:48 scale. Are all RAF Typhoons FGR 4’s now? I would like to do a combat aircraft with live ordnance. I don’t care which conflict, just want it to be a non-anniversary or non-air show scheme. I have not come across any specific decals yet, so any recommendations are appreciated. I was going to use the Revell kit but boxing’s are currently limited with only the German bronze tiger boxing the only option near me at the moment. So how do I model the aircraft I want? Link to comment Share on other sites More sharing options...
Muzz Posted March 13, 2021 Share Posted March 13, 2021 The Bronze Tiger boxing will allow you to build an RAF FGR4 as much as the RAF boxing does, same plastic and contains the PIRATE sensor, you'll be missing the inner wing pylons the RAF use which Revell dont provide but can be bought as AM. Xtradecal do a few squadron schemes in standard markings such as 1 Sqn. The only issue you might have is with a full set of correct stencil data. https://the48ers.com/eurofighter-typhoon-inner-pylons.html https://www.hannants.co.uk/product/X48114?result-token=K8GoS Muzz 1 Link to comment Share on other sites More sharing options...
exdraken Posted March 13, 2021 Share Posted March 13, 2021 decals aer a bit short on suply for Eurofighters in general unfortuantely if you want a war mashine over Libya, contains also corect bombs for the time and the necessyry pylons https://www.scalemates.com/de/kits/olimp-resin-accessories-ora-48-14-ef-2000-typhoon-englishman-over-tripoli-update-set--251122 https://www.ebay.co.uk/itm/Olimp-Resin-1-48-EF-2000-Englishman-over-Tripoli-Update-Conversion-Set-/122636310235 still need basic decals though... (the Revell two-seater also has RAF decals by the way!) the revell air to ground weapons are only party usable though.. (or not at all with you want a operational used load out...) the Storm Shadows are included and can be used for ~5 years now, but as far as I know were not used yet Link to comment Share on other sites More sharing options...
RMP2 Posted March 13, 2021 Share Posted March 13, 2021 There's the Falklands based Typhoons for an air to air load, the box bits should cover that. Decals wise for markings at least would be a bit of a mix n match from other Flight 1435 options from Phantoms and/or F3 Tornados. Just a thought. Link to comment Share on other sites More sharing options...
is it windy yet? Posted March 15, 2021 Author Share Posted March 15, 2021 Thanks. Good to know these things. I will start collecting materials for this now. Link to comment Share on other sites More sharing options...
Muzz Posted March 16, 2021 Share Posted March 16, 2021 On 13/03/2021 at 20:10, exdraken said: revell air to ground weapons are only party usable though.. (or not at all with you want a operational used load out...) the Storm Shadows are included and can be used for ~5 years now, but as far as I know were not used yet It would appear Storm Shadow been used for the first time recently....... https://www.thedrive.com/the-war-zone/39792/british-typhoons-have-used-storm-shadow-cruise-missiles-for-the-first-time-in-combat?xid=twittershare 1 Link to comment Share on other sites More sharing options...
exdraken Posted March 16, 2021 Share Posted March 16, 2021 2 hours ago, Muzz said: It would appear Storm Shadow been used for the first time recently....... https://www.thedrive.com/the-war-zone/39792/british-typhoons-have-used-storm-shadow-cruise-missiles-for-the-first-time-in-combat?xid=twittershare just in time for my post good to know! also interesting to see this clear picture of the missile rear end Link to comment Share on other sites More sharing options...
DeepSea Posted May 5, 2021 Share Posted May 5, 2021 Is the storm shadow carried on the same pylon as the underwing tanks - or am I going mad?* * Both is a valid answer too 😃 Link to comment Share on other sites More sharing options...
exdraken Posted May 5, 2021 Share Posted May 5, 2021 No, and I do not know for sure.. You are asking strange, hardlyrelevant things in the grand schem of things Sorry. same station yes, but the tank has an integral pylon afaik http://www.ipmsdeutschland.de/FirstLook/Revell/Rev_EF_Typhoon_48_Baron_Spirit/Revell-03848-Eurofighter_11.jpg And from the above link: 1 1 Link to comment Share on other sites More sharing options...
Paws4thot Posted May 6, 2021 Share Posted May 6, 2021 On 13/03/2021 at 20:10, exdraken said: the Storm Shadows are included and can be used Multiple Storm Shadows have been fired from both squadron Tornados and squadron Typhoons on the Hebrides air range over the last several years. Watch out for the pylon adaptors though because the Tornado uses a different adaptor to the Typhoon. Incidentally, they have also fired ASRAAM, AMRAAM, Sky Flash (Tornado only) and Meteor there. Link to comment Share on other sites More sharing options...
