Vacform Lightning - I have no idea what I'm doing
This is probably @Martians fault. The vacform tutorial build got me thinking about challenging myself to do something other than an injection moulded kit. I stick to 1:48 and almost always the end-of-the-cold-war through to modern era aircraft that I've seen at shows since my childhood. So there really isn't tons of choice in vacform, as soon as I saw the Lightning I knew it was the right one for me.
I don't normal go for the un-boxing type shots, but a lot of you might be as new as me to this form of modelling.
the box
IMG_20201214_223714
 Unfortunately no longer with the etch or the redtops that have been redacted from the front
The fuselage
IMG_20201214_223822
Wings
IMG_20201214_224029
Spine stiffener, belly stiffener and an over wing tank
IMG_20201214_223834
Another tank
IMG_20201214_223955
White metal parts for the undercarriage, cockpit, exhausts and nose.
IMG_20201214_223919
injection moulded parts
IMG_20201214_223815
canopy
IMG_20201214_224103
Decals
IMG_20201214_223900
and sticks attached to the bottom of the box
IMG_20201214_224037
First job, as it says in the instructions is to read the instructions. I might have done this in excess of 30 times before I was brave enough to do anything. But eventually the time came.
I bought a new cutting mat
IMG_20210305_154410
Outlined the fuselage halves with a fine pen and with my new #11, cut the fuselage out of the backing.
IMG_20210305_154427
IMG_20210305_234620
Sanding and more sanding until they fit together and also the nose and the exhausts fit snugly at opposite ends.
IMG_20210307_233557
IMG_20210307_234647
I have no idea how that ended up working so well.
Until next time.
Edited by chrislowe
  • Like 28
We've all been there once. Especially when moving out of our modelling comfort zone.
I built the F1 before Airfix released their injection moulded one. It'll either be in the Coltishall or City of Norwich museum now - was a part of the RAF Coltishall history collection before we closed and things got dispersed. From recollection it went pretty well, but I'd cut my teeth on a few Dynavector kits by then.
Edited by JagRigger
Good work so far
just take your time and test fit, test fit, test fit, before you glue. It builds into a nice kit. Airfix my have the nice recessed panel lines but lacks the correct width, its just too skinny. And there's no angles in the leading edge of the wings.
Darren
I have. Time, patience, care and general modelling skill. Very nicely done so far.
That’s a very nice looking kit; I haven’t seen one out of the box before. Those injection parts should help enormously when it comes to building the wings.
Jon
Wow, Blast from the past !!
You are over the worse bit, the wings are designed to need very little thinning of the edges they 'drop' into the injection parts.
Keep at it nothing to fear in vac forms they're only plastic !!
Must dig out a finished one to keep you going
Edited by Paulaero
Duplicate
EBAY II 017
Keep at it mate, this was the very first built one to test fit the parts. Been rebuilt about three times. As some have said I think it captures  better the look of a lightning.....
Sorry the image is a bit blurred the model is packed away in the loft and hasn't seen the light of day for ten years  but retirement is looming  🙂
  • 4 months later...
Fingers crossed I've managed to keep that energy going...
On 3/10/2021 at 12:36 AM, AdrianMF said:
Looks good so far! (without meaning to jinx it)
Thanks Adrian. Fingers crossed!
On 3/10/2021 at 1:42 AM, billn53 said:
This is going to be great :popcorn:
Thanks! Hopefully I won't disappoint.
On 3/11/2021 at 9:40 AM, MADMUSKY said:
Good work so far
Darren
Thanks Darren. It certainly looks very well engineered.
You're too kind
On 3/11/2021 at 2:09 PM, Paulaero said:
EBAY II 017
That looks fantastic Paul, thanks for digging that our of the loft! I'm on the lookout for some appropriate missiles. Definitely inspirational.
It's been some considerable time since my last post, work, life and other kits have been taking my attention, but I haven't been idle.
The last post was a test fit of the two halves, so next came the bulkheads.
IMG_20210311_000139
More test fitting
IMG_20210311_003458
The wheel well
IMG_20210311_235745
And the intake
IMG_20210313_213607
I wanted to see if I could get a better shape in the front wheel bay. It started quite elliptical so I used a micro chisel to improve the shape.
IMG_20210314_214625
Just enough here to play with, but no extra
IMG_20210314_214653
Intake parts painted with MIG metallics and a Flory wash applied.
IMG_20210315_220931
IMG_20210316_235246
Probably won't see much of this when the whole thing is assembled but I'm happy enough with that result.
Back to the wheel bay. Still some tidying to do but hopefully you can see what I'm going for.
IMG_20210317_123331
Engines with a wash
IMG_20210317_122631
Offered up to the bulkhead so I can test fit the white metal exhausts
IMG_20210317_191104
Now the instructions say that you can crack on with the wings before you need them so I made the jig pieces and started gluing the leading and trailing edges to the vacform skin.
IMG_20210320_230756
And test fit the composite spar
IMG_20210320_230834
Still not able to glue the two halves together, I started on the cockpit. A touch of black in the right places with a light cost of grey to start.
IMG_20210326_185934
Followed by a wash and picking out the knobs, levers and buttons. I don't have any pictures of the IP in progress, but hopefully you can see from this pic that I cut out dials from spare decal sheets to make the most of the nicely derailed white metal piece.
IMG_20210331_235036
With the cockpit done, the intake glued and the wheel bay ready it's almost glue time
IMG_20210416_103824
IMG_20210416_103934
  • Like 10
I don't have any pictures of the gluing stage, but here's a picture of the two halves glued and the tail in place.
IMG_20210428_182612
Having already checked that I could fit it later, I made the ejection seat.
IMG_20210429_230920
Here it is with the coaming fitted too
IMG_20210428_182741
IMG_20210506_153414
IMG_20210506_153438
Next up I spent some time on the many vents and ducts on both sides. Thanks to everyone who contributed to the walk around section. The variety of photos really helped with this bit.
IMG_20210429_230850
Wings and canopy on and a cost of primer before lots of filling, sanding, priming, filling, sanding, priming etc.
IMG_20210601_235237
And that brings us up to date. Next up is some preshading, masking and the camo scheme.
  • Like 17
Looking very nice indeed. The vac/resin combo seems to be working well.
Camouflage - something about “Lightning” says “shiny” to me - I built the Airfix F1A in 196x in glorious silver plastic so I’m afraid that’s ruined me for life!
Looking forward to some greens and greys…
Regards,
Adrian
Looking good o far,especially for a first attempt at vacs.  I'll just add, as others have said,test fit, sand, test fit. Wash rinse, repeat. Don't get in a rush,When you get done you'll have something that will rival an injection kit.
9 minutes ago, Deano353 said:
I'm curious to try a vac form kit myself as I'm seeing them on here was this easy enough to come by?
Aero club is no longer in operation, but you should be able to find a decent kit at a local hobby show, yard sale or Ebay. Heres one site I found doing a quick search online.
https://www.kingkit.co.uk/products/vacform-model-kits/
Fantastic build! It has been a while that I haven´t build a vacformed kit mysef. The finished model should look great. Knowing Aeroclub's reputation for producing accurate models, I wonder how this kit compares with the Airfix injection molded version of the Lightning.
Cheers, Ivan
Edited by IvanP
Its wonderful to see your Aeroclub Lightning build steps here Chris, thanks for sharing, you're providing me heaps of inspiration.
Where and how did you locate the spine and belly fairing inner stiffeners ?
I've not come across this concept in my injection moulded kit experience, and have been head scratching over this.
With their shape, do they essentially form an inner second skin once attached and the fuse halves joined ?
Keep up the good work - you're lighting a path that this mortal has feared to tread until now. Mine are calling "build me", like little gremlins - the force is strengthening !
Have you selected a final camo scheme yet ?
All power to your progress,
Never having attempted a vacform kit, I've been following this at a distance - watching the work has been highly educational & inspirational - I might even give one a go sometime. Fine work!
Q
Nice work on the Lightning. John has always been very careful about how he engineers stuff and it shows here. I am glad you are getting on well with a vacform and proving that they are not as scary as people think (Although there are exceptions, see worse kit ever thread in Chat)
Nice to see one of these actually being built. I've had an F6 in the stash for years and years but never had the courage to make a start. The Airfix injection kits came out, then the Sword trainers all in injection. Made all of those so I could never see the point of the vac kits. Cant see me ever getting round to it, but good to see someone has 😁
Ian
