TonyOD Posted March 3, 2021 Share Posted March 3, 2021 I need to add a little landing light to a 1/72 helicopter, I've made a recess that I figure I'll line with a bit of foil. If I then fill the hole with CA can I sand and polish it with increasingly fine grades of wet and dry/Micromesh will it come up transparent? Thanks Link to comment Share on other sites More sharing options...
Black Knight Posted March 3, 2021 Share Posted March 3, 2021 No it won't, in my experience. If the hole is small use PVA glue. Most PVA dries clear, but it shrinks, so you need to repeat 1 Link to comment Share on other sites More sharing options...
Cheshiretaurus Posted March 3, 2021 Share Posted March 3, 2021 Get a UV glue pen and allow it to form a blob, once your happy with the shape, shine the UV light on it. Here's an extract from a P51 build I did, of course the colouring is optional Punch some 1mm discs out of self adhesive aluminium tape and fix them in the light recesses Tiny drop of Tamiya clear colour in each light Followed by a drop of UV cure glue to make the lens. 5 Link to comment Share on other sites More sharing options...
fishplanebeer Posted March 10, 2021 Share Posted March 10, 2021 Micro Kristal Clear is also very good at creating clear lights and windows etc.. Looks just like pva and can also be used as a white glue but doesn't shrink and looks nice and clear and convincing when dry. Regards Colin. Link to comment Share on other sites More sharing options...
bentwaters81tfw Posted March 10, 2021 Share Posted March 10, 2021 24 minutes ago, fishplanebeer said: Micro Kristal Clear is also very good at creating clear lights and windows etc.. Looks just like pva and can also be used as a white glue but doesn't shrink and looks nice and clear and convincing when dry. Regards Colin. This. Link to comment Share on other sites More sharing options...
