So here is my PAK 40
This is a really nice kit to build and includes PE for the shield and other small parts and a one piece ali barrel (also comes with rubber tires which I have to say Im not a big fan of).
The only real problems I had (which are down to me really) is that the plastic bolts for the two PE shields are absolutely minute, would be much easier for someone who doesn’t have failing eyesight or a few dexterity problems.  I ended up putting plastic rod through the holes and once dry snipped them off. However they do do a set of AF35073 Brass Shield Bolts, I found out after.
The other was after I had applied the colours I sprayed with Tamiya X-22 gloss clear to add some weathering (not much weathering done as I have a diorama in mind for the future so will do it then). After drying I applied what little I had of the XF-86 left (fully covered though) but it came out semi-gloss🙄
I then after 24hrs+ drying I applied some Tamiya LP-23 (after some helpful advice from some of you folks).  This also came out semi-gloss actually bordering on gloss.  Out of frustration I searched through my paints and came across a bottle of Polly Scale Flat Clear (I got in the 90’s). For the first time ever I mixed the paint and thinner in the AB cup.  After a few minutes it started to go matt and the finish I was hoping for.  Never had this problem before with Tamiya strangely.
If anyone has any thoughts or ideas why this has gone wrong (or should I say what I have done wrong) it would be much appreciated.
Sorry for the waffle
AFV Club 1/35 PAK 40 7.5cm ATG
OOB apart from the shield bolts
Tamiya Acrylics/Lacquer Paints
Flory Washes
Abteilung Oils for the wood
Various Metallic Enamels
Thanks for looking 👍
  • Like 23
Very nice build. The fine looking detail is well done, as is the paintwork. Good photos too. Like this a lot.
Thank you echen much  appreciated 👍
Looks really good, I like camo 👍
Vytautas
PS. A small note - if you have not yet glued the breechblock, it should be turned on to the other side. Photo
Vytautas
Thanks Vyautas, I've not glued it yet so thanks for the heads up
Great work Si. superb finishes. As has been said very nice photos. A great amount of time to achieve this. You can have a beer now
Although it looks as though your breech has been blocked.
Laurie
