Sturmovik Posted March 14, 2021 Share Posted March 14, 2021 9 minutes ago, Lord Riot said: I need to get some gloss yellow, only got matt for brushing. Wouldn't it be the same to apply matt yellow and then regloss? Link to comment Share on other sites More sharing options...
Lord Riot Posted March 14, 2021 Author Share Posted March 14, 2021 1 minute ago, Sturmovik said: Wouldn't it be the same to apply matt yellow and then regloss? Probably, but I don’t have any gloss varnish either! The paint will come in useful when I make my Sea King and Sycamore at some point anyway. 1 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 15, 2021 Author Share Posted March 15, 2021 Yet another respray! I wasn’t happy with the silver or the demarcation line so more masking required ... Looking better now I think. And a straighter line. Just a few bits of touching up needed around the intakes mostly. 3 Link to comment Share on other sites More sharing options...
Ruskin Air Services Posted March 15, 2021 Share Posted March 15, 2021 4 hours ago, Lord Riot said: Yet another respray! I wasn’t happy with the silver or the demarcation line so more masking required ... Looking better now I think. And a straighter line. Just a few bits of touching up needed around the intakes mostly. I always brush a coat either gloss or matt varnish to seal the edge so I get a good demarcation line 1 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 16, 2021 Author Share Posted March 16, 2021 After all the attempts at spraying and masking I still ended up having to tidy up the spine with a pot of Humbrol gloss yellow. Close up photos are always a harsh judge on my painting so I think once it’s on the shelf it should be good enough after a bit more tidying up. 6 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 17, 2021 Author Share Posted March 17, 2021 I think this will have to do! 3 Link to comment Share on other sites More sharing options...
heloman1 Posted March 17, 2021 Share Posted March 17, 2021 Ouch with the making. However, I think the problem might be yours, the packing states the 'glue' is moisture activated by that I think it means water based paint as in PVA decorators paint. Tamiya tape if you are using anything else! Colin 1 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 18, 2021 Author Share Posted March 18, 2021 Undersides tidied up a bit ready for the undercarriage. I washed over a light coat of dirt wash too though I’m guessing these Hunters were generally kept quite clean. Tail and jet pipe fitted. 5 Link to comment Share on other sites More sharing options...
bigbadbadge Posted March 18, 2021 Share Posted March 18, 2021 Looks very nice indeed Chris 1 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 19, 2021 Author Share Posted March 19, 2021 Always a relief when they don’t tail sit. Need to add more undercarriage doors yet but I’m pleased with the stance. Even in my ham fisted modelling the Hunter looks such a graceful aircraft. Looking forward to making the Airfix 1/48 ones at some point. Two may not be enough though given all the squadrons available. Nice glossy finish from those new spray cans, definitely looks more 50s/60s I think. 3 Link to comment Share on other sites More sharing options...
Selwyn Posted March 19, 2021 Share Posted March 19, 2021 A top tip when masking to stop paint creep under your tape. Paint your appropriate kit bits (in your case yellow) freehand. When dry then mask them up as required with the tape. Then paint over the tape concentrating on the tape edges with your yellow paint then let dry. This yellow paint coat over the tape will bleed under the tape but, as its the same colour it doesn't matter, but what's important is it seals the edges of the tape peventing your camoflage colours bleeding under. When dry paint on your camoflage colours. they dont bleed under as the edges of the tape have been sealed, and give a great line when you remove the masking tape, you can mask really fine lines using this method. Hope this helps, Selwyn 1 2 Link to comment Share on other sites More sharing options...
Lord Riot Posted March 20, 2021 Author Share Posted March 20, 2021 Thanks @Selwyn that’s a fantastic tip and one I’ll definitely use next time! Link to comment Share on other sites More sharing options...
Lord Riot Posted March 21, 2021 Author Share Posted March 21, 2021 Ready for the decals. Stencils first. I’ll be making this as XG209 rather than the kit option as sadly 204 was subsequently lost in a crash. Found some 9s in the spares bag so all good, just need the code letter C for this one. I remembered not to paint the rear frame on the canopy! It’s a nice little kit this, just wish my painting could have done it justice. 4 Link to comment Share on other sites More sharing options...
