TopDrawings 97 – Sturmgeschütz III (9788366148895)
Mike
Kagero Publishing via Casemate UK
Based on the Panzer III, the StuG III had its turret removed, was refitted with a casemate and a high velocity gun that had limited traverse within the hull.  This meant that the vehicle had to roughly align itself with the target, fine-tuning it with the gun’s roughly 15oc traverse.  This marked it out as being ideal as a tank destroyer that lay in wait for its targets, although it was originally intended to provide support for infantry, aided by the comparatively low silhouette of the turretless design.  It was effective in its job and fought all the way to the end of WWII, although it was notionally replaced by the StuG IV that was based upon the heavier Panzer IV.
We have kits in scales from 1:72 through 1:35 from many of the main manufacturers, all the way up to the 1:16 giant that you can get in Remote Control (R/C) form (I forget the brand), which explains the different scales used in the plans throughout the book.  The TopDrawings series majors on scale plans, which is the main thrust, but also includes a little background information, some pertinent profiles, and often a bonus of decals, plans or masks targeted to the subject matter in hand.  With this edition, you get a double-sided A3 sheet of folded loose-leaf plans in 1:16.
The book is written in English on the left of the page, with Polish on the right, which translates to top and bottom for the captions to the various drawings within.  The book itself is bound in a card cover and has 15 pages, with the rear cover devoted to two profiles of a couple of Ausf.Gs in very different camouflage.  The first page gives a written introduction, then launches straight into the plans that show the vehicle from the Ausf.A through to the Fs and Gs, after which there are eight profiles of all types except the A, with a wide range of schemes, fitments and equipment.  After the colourful break we’re back to plans again, this time in 1:48 scale from all angles, and again in 1:72, showing each mark in each scale.
Conclusion
These books are essential for the modeller that enjoys comparing their models against scale plans, and wants them to be as accurate as possible, with the additional large sheet perfect for poring over on the lounge floor or hanging on the wall.
Highly recommended.
Review sample courtesy of
