Builder Advice: 1/48 Westland Whirlwind
Hey Guys...  I wanted to build one of my favorite airplanes the Whirlwind.  I have it in Trumpeter in 1/48.  I hear it has accuracy issues.  What do you do about the wing fuselage fillet?  Should I get a different kit?  What is the go to kit for a Whirlwind in 1/48?  With my luck, I will go thru the trouble and expense fixing a bad kit and then someone will release a good new kit of the same plane!  So for us to get a good Whirlwind kit, I have to build a hard one!  Thanks!
Bob
Classic Airframe,  it's based on a vacform by Cooper Details IIRC, which was done Roy Sutherland.    The CA kit should be findable in the US,  certainly be easier than finding one in the UK
The Trumpeter kit is , erm , not very good.    I can't remember the full litany of errors.
I'll @brewerjerry as this is his pet subject.
HTH
Thanks Troy...  i am not skilled at vac form.  I do see the CA kit but it looks rough.
I dont have issue with fixing the cockpit details on trumpeter kit.  I recall hearing about the wing fillet.
Hope to hear what needs fixing and maybe i can fix some of this on trumpeter
2 minutes ago, europapete said:
Or you may want to switch up scales and wait for the 1/32 one which is coming out soon. That will make all the other kits obsolete. Regards, Pete in RI
Pete...  who is doing the 1/32?  I will stick in 1/48, but maybe can wait for a downsize kit
I see...  Special hobby is doing a 1/32.  Well hope they scale it down...  i dont have room for 1/32...
I still may armwrestle this trumpeter kit...  just to get something on the shelf
The Trumpeter canopy was all wrong, as was the fuselage depth, and/or other equally major issues. It is one of those where either get the CA kit, borrow a few Trumpeter bits (easier props on Trumpeter, I would assume), or start from scratch!
Edited by WrathofAtlantis
Hi
    Yeah CA is the best bet, try to get the second issue.
there is also a 1:48 resin kit I have not sure who made it
  Best thing for the trumpeter kit to to 'what if'  it.
 I am going to modify mine with some merlin XX engine pods on it, and the other with radial engines
    Jerry
Bob
Bob,
The Trumpeter kit does have issues but on the plus side it does fit together well. If you are up for a bit of scratch building it can be made up into a pretty good representation. I certainly wouldn't avoid it. Good luck with it,
Roger
On 2/25/2021 at 12:55 AM, dragonlanceHR said:
Also done by Roy Sutherland IIRC
Done under the Cooper Details brand, his older company before becoming Barracuda. Roy also does wheels and a canopy for the reasonably good CA kit.
Pete M.
Edited by Pete M.
I'm a huge fan of the Whirlwind but my scale is 1/32 however as no kits were available in 1/32 I dropped down a scale and built the CA kit and it is certainly buildable, if a mite challenging, As you may imagine I have an SH kit on order at Hannants
Trumpeter kits however are great, what they lack in correct detail they make up for in being well engineered and fun to build.
If accuracy is your main aim go for the CA kit
If you want a fun, well engineered build go for the Trumpeter kit
Dennis
