speedy Posted February 21, 2021 Share Posted February 21, 2021 (edited) Hi folks, I’m building a 1/32 Puma at the mo and the canopy area is a very poor fit. The clear plastic is of the hard brittle type. Any advice would be welcome, I’m looking at removing 1 or 2mm in thickness. I have a micro mesh kit, but I’m conscious of making a right hash of it and destroying all my work to date. Edited February 21, 2021 by speedy Link to comment Share on other sites More sharing options...
dnl42 Posted February 21, 2021 Share Posted February 21, 2021 I'm not quite sure I understand what you're trying to do. 12 minutes ago, speedy said: I’m looking at removing 1 or 2mm in thickness. Are you asking about making the plastic thinner or removing material from the edge? I've never tried to thin a clear part that much as I've only thinned clear plastic to remove scratches. I start with a 1500 pad and then work, pad by pad, until finishing with a 12000 pad. A polish with Mr Hobby compound finishes it off. I've just started using Deluxe Materials Looks Like Glass as a clear coat after painting framing with Mr Color. I've found Mr Color atop Looks Like Glass is not a Good Thing... When I need to remove material from the edge of clear plastic, I prefer Swiss-cut needle files, particularly an equaling file. Depending on the amount, I'll start with 0-, 2-, or 4-cut and then finish with 6-cut. Be very careful and support the part to avoid crazing. I mostly use needle files for shaping as I can carefully control where material is removed. A 6-cut file leaves plastic smooth and shiny. HTH -- dnl 1 Link to comment Share on other sites More sharing options...
Tail-Dragon Posted February 21, 2021 Share Posted February 21, 2021 I sand the clear plastic on almost every build, it's nothing to be warry of. I will get the basic contour with down to a 400 grit, then work up (wet sanding) through 600, 800, 1000, 2000, and higher. Polish with a rag wheel on a Dremel - no higher than a medium speed and keep moving around to avoid melting in (ask me how I know!). Final step is a coat of Future (or Pledge) painted on with a fine brush (I cut with 10% water to enhance the flow and leveling) . Sometimes it's the only way to transparencies to fit. Just be careful not to try and force a fit, or you'll end up with stress fractures. 3 2 Link to comment Share on other sites More sharing options...
Sabrejet Posted February 21, 2021 Share Posted February 21, 2021 @speedy: I'd practice on a spare bit first, but if you have a Micromesh kit, you're on the best track. They do say to alternate 90 degrees between each grade, but sometimes it's difficult and it doesn't seem to make much difference. As a final shine, I usually apply a coat of Mr Color Topcoat. It will look a mess until you get to about 4000 grade, but you'll notice that each grade will be quieter than the last. Link to comment Share on other sites More sharing options...
speedy Posted February 21, 2021 Author Share Posted February 21, 2021 Sorry dnl42 a poorly written question when I was being rushed, but you’ve answered the question, as has the others. Intake of breadth and I’ll give it a go. Link to comment Share on other sites More sharing options...
