Westland Dragonfly HC4 - LF Models 1/72
Thanks John and Adrian :)
Losing it a bit this afternoon :(
Dry fitting the rotor head shows that the shaft is the right length:
…but that would mean a butt joint in the top.
Nasty.
Let's have fun drilling holes and trying to fit some nickel silver rod:
Patience gone.
Better leave it until I calm down!
  • Like 19
  • Sad 1
Good idea, it's looking far too good to take a final flight against the wall....!!
And I'm feeling exactly the same about Telford..... :(
Keith
Suitably weathered, Ced :clap: Smart choice about the rotor head :thumbsup:
Ciao
Loving the detail that wash has brought out and that’s some very cunning work on that rotor head. Looking very nice indeed Ced.
Rob
Looks very good Ced, making all the right moves, all the right decisions
Suits you sir, suits you
I have never been a 'washer'* but seeing the way this pops after treatment I might send off for some to try out.
* Oi!
Watch it.
  • Haha 2
Keith
Thanks Keith :)
See you in 2022 though eh?
Ciao
Thanks Giorgio :)
To be honest I had cut the rod to poke into the bottom of the fuselage but trimming meant it ended up too short.
I also had to trim the kit shaft to get the head at the right height.
Plenty of CA on the join and in the hole so fingers crossed :fingerscrossed:
Rob
Thanks Rob :)
* Oi!
Watch it.
Same here Bill, then I saw what Johnny and Giorgio achieved and decided to give Flory a go.
Easy peasy - slosh it on, let it dry then rub it off with kitchen towel or cotton buds 'to taste'.
One tip - I use kitchen towel, lick it, rub a bit off then fold it over and repeat.
Don't forget to fold it before you lick - otherwise 'to taste' ends up more true than you'd want.
Ask me how I know :D
  • Haha 4
One hangover from my time in business is a visit to 'the desk' before bed to prepare for the next day.
Old habits are hard to break…
Last night I decided I should paint the PE and bits ready for the morning.
Imagine my surprise when I checked the clock to see it was 2am!
It was only this morning I realised the clocks had 'sprung forward'.
Happy Summer all!
Here are the bits gathered together:
This morning I fiddled with the remaining tiny bits for the rotor head:
No idea if that's accurate, but it's too small to see anyway under normal circumstances.
Honest.
Nose wheel has been tube glued on:
I did consider a pin but hey, once the thing's glued the plastic is welded and I don't plan to knock the thing anytime soon.
Regrets, I've had a few, but then again I doubt it'll shift.
Note the 'jaunty angle' - very hard to get it lined up straight so I gave up.
Main wheels next.
Then varnish coat - satin I think.
Then masks off.
Then the bits I can knock off will be glued on.
The main blades are a tight push fit so they won't be glued.
  • Like 24
On 26/03/2021 at 17:08, CedB said:
Once they're dry I'll flat coat ready for a Flory wash.
As it worked amazingly I’ll just say this as a “Do the what now?🤔 ”  Now I might be wrong. I usually am but I’m pretty sure you do a Flory wash on a gloss coat then mat coat afterwards. Makes it a lot easier to fix any cock ups.
Either way Mr B that rotor head and the whole thing really is looking rather splendid. 🙌🙌🙌
Bravo. Right suitably revved up I’m headed to the bench.
Johnny
Nice ‘Fly!  The rotor head / drag dampers are particularly impressive, given the raw material.  Lovely job
Coming together nicely Ced, not far to the finish line now
Any thoughts on what's next?
  Stay safe                Roger
Now, this becomes tricky.  Yes, you do the wash on a gloss coat, so that you can work it out to stick only where you want. However, if you push this a little further, you can also do another wash after a  flat coat; you need to be very selective and precise, though, because that will not clean up as on the gloss coat. In turn, it will add a nice halo in selected spots.
Tests on scrap parts are highly recommended, here.
Ciao
4 hours ago, silverkite211 said:
Did I mention that you're nuts? I did? Well, it bears repeating. You're nuts! ;)
Exemplary work, that is turning out very nice!
Thanks SK :mental:
Johnny
Ciao
Thanks both.
Ah, now then, that's my fault… again.
I thought I remembered 'wash on a matt coat' but obviously not :(
Gloss coat, gloss coat…
Oooh, thanks Crisp. Great praise from the chopper master :)
  Stay safe                Roger
Thanks Roger :)
Not ready to start anything else just yet but it's likely to be something for the 453rd.
And big.
Main wheels on.
That was fractious, even with tube glue.
Perhaps I should have used some rod but I can never get the holes in the right place :(
Satin coat applied:
I tried some of the perdu recommended decal sheet for the blade tips:
Couldn't get it to bend and settle.
On the main blades I tried Decal Strong and, sure enough, the decal melted, but not where I wanted it.
Drat.
In the end, and as forecast by Ian, I brush painted them with Hu24:
Masks off next - yay!
  • Like 15
I'm not going to say "I told you".
 Oh, wait erm, maybe I just suggested it "could be a possibility"? :whistle:
Nice save though!
Ian
  • Haha 2
Quite right Ian - you did tell me so. Post amended! :)
The Dragonfly's had it's jabs then?
Love work Ced.
  • Haha 4
3 hours ago, John Masters said:
This is looking superb.  It inspires me to get back to my attempt and finish it properly!
Thanks John - probably worth a last push! :)
1 hour ago, The Spadgent said:
That’s just bloody lovely that is. 🙌
Johnny.
Awww, thanks Johnny :)
Love work Ced.
Jabs, prods, pokes, shoves, you name it! :D
Masking off, blades on:
Just a few bits of PE to attach, then I'm done.
Phew.
  • Like 16
Looking good, Ced! :clap:  :clap:
Ciao
The canopy looks great (as does the rest of it!). Unmasking it must have been very satisfying.
Regards,
Adrian
This just gets better and better superb result Ced
  Stay safe            Roger
