USS Parche SSN-683 (Late) from Mikro-Mir
Just delivered - courtesy of Hannants and Royal Mail - Mikro-Mir's latest 1/350 scale submarine USS Parche SSN-683 - Late Version.
Box art - note the divers lockout chamber on the aft casing - disguised as a DSRV..........
The instruction sheet is a flimsy A4 page folded in half ........... the first page gives a brief potted history of the boat and a painting guide (!)...
The reverse is the construction diagram.......
The hull is split horizontally.....
The only other sprue provides the upper and lower decking, sail, control surfaces etc.... note that it DOES NOT include the DSRV !!!
The package is finished off with a small decal sheet for the depth markings and escape hatches - plus a small etched brass part for the propeller and towed-array sonar.
This is another nice kit from the prolific Ukrainian enterprise of Mikro-Mir - but they are being a bit naughty not including the DSRV - as it is already provided in their (Early) version kit....
Note the DSRV at top left.
As I have already scratched a model of this version :- http://www.flankers-site.co.uk/model_submarines_USA.html#USS_Parche_SSN-683_
it will be interesting to compare mine with MM's kit - they probably had more info to hand -
I couldn't find much about the 'Hush-Hush' undersides at the time -
but I have just found this cutaway drawing... https://i.pinimg.com/originals/fa/70/a6/fa70a6ef6d59cc1e12d33ca39229e447.jpg
All my 1/350 scale subs are here :- http://www.flankers-site.co.uk/model_submarines_link_page.html
Stay Safe...
Ken
As with most Mikro-Mir sub kits, the parts have large sprue gates and need a lot of 'fettling' (scraping and sanding) to make good mating surfaces.....
The ventral structure for the divers saturation chamber is made up from two sides and a floor (or 'roof' - depending on your point of view).....
There are no positive location pips - so I added strips of L-section plastic to form a ledge on which the 'floor' can sit.....
This made locating the sides much easier....
..... although there are still seams to fill.....
Similarly, the top and bottom hull halves needed a lot of work to scrape away flash from the mating surfaces -
I have added strips of thin plastic card to make a better join........
More later.....
Ken
A little progress......
Taping the lower pannier to the hull........
...reveals a large mis-fit at the front and rear......
I sanded the mating surfaces to a bevelled-edge - which made the fit better... and finished off with filler.
The Conning Tower/Bridge/Sail is made up from two sides and a top section...
Guess what? - the cutout in the top decking doesn't match the contours of the sail - so more fettling and filler...
Finally - all the major parts are fitted and she's ready for a coat of primer....
I'm hoping that the overall black finish will hide a lot of my botching......
More later...
Ken
