Valkyrie 4,526 Posted February 15 Share Posted February 15 Having missed out on building one from this Royal Class boxing in the MTO III I will be making one of the 2 Afrika deployments included in the box. Being limited to building only one of the Afrika options from parts from the boxing I’m not restricted as purchased an overtrees kit in the Eduard sale last year when I went a bit daft on Spitfires. I do like the tropical filter but I really should make yellow 4 too, seen as I have the print of it involved in a naval attack of Bona Harbour hanging in the study... 7 Link to post Share on other sites
Col. 12,053 Posted February 15 Share Posted February 15 Another good subject and one that will make an interesting comparison as well as companion to your 109 1 Link to post Share on other sites
Valkyrie 4,526 Posted February 15 Author Share Posted February 15 Thanks Col. I am wondering do I try to squeeze U-boat U-331 into this GB too between two aircraft? Part of its Afrika action was to shell a fuel dump with its deck gun at Sidi Barani which might be an interesting wee addition... 2 Link to post Share on other sites
Angus Tura 774 Posted February 16 Share Posted February 16 The U-331 would be pleasantly outre. The FW-190 sand and blue colours are affy fine. Alan 1 Link to post Share on other sites
Col. 12,053 Posted February 16 Share Posted February 16 11 hours ago, Valkyrie said: Thanks Col. I am wondering do I try to squeeze U-boat U-331 into this GB too between two aircraft? Part of its Afrika action was to shell a fuel dump with its deck gun at Sidi Barani which might be an interesting wee addition... I'd certainly like to see your U-331 project here but only if you feel the timescale allows it in combination with your two others. 1 Link to post Share on other sites
Valkyrie 4,526 Posted February 17 Author Share Posted February 17 Ok, I want to kick things off at midnight on Friday so the votes are the Benghazi scheme has it.. 4 Link to post Share on other sites
Valkyrie 4,526 Posted February 20 Author Share Posted February 20 Team Afrika assemble..... Ok, studying the instructions and it’s quite a tricky start...straight into photo etch drilling and painting...3 airframes, 2 sets of wings. Like the look of the tropical air filters though on top of the research books 5 Link to post Share on other sites
Valkyrie 4,526 Posted February 20 Author Share Posted February 20 Not a lot to show despite nearly a full day at the bench but it’s crunch time. I have to bite the bullet and saw off the cowling to replace it with another cowling mould which contains the tropical air filters. 3 Link to post Share on other sites
Valkyrie 4,526 Posted February 20 Author Share Posted February 20 Cockpit built up with the fiddly photo etch but it really details it up 3 Link to post Share on other sites
Valkyrie 4,526 Posted February 21 Author Share Posted February 21 EKdo 19 were testing the suitability of Bf 109s and Fw 190s as ground attack aircraft in tropical conditions from Castel Benito airfield. The tropical filters cowl is one piece. I’ve never attempted anything like this before and although it looks like I used my teeth to make the cuts I’m hoping il be able to smooth this all out and once painted you’d never know...hopefully. My plan of attack is to make the entire front section up with cowling, cowling ring, underside and cowl mounted gun cover all around the engine pieces giving me the correct shape to then attach. I had a real battle getting the sides of the fuselage to meet at top, bottom and rear and forward ends. I had to trim and sand a lot off the cockpits sides until I got enough tolerance to glue and hopefully over night it will bind in place. 5 Link to post Share on other sites
Col. 12,053 Posted February 21 Share Posted February 21 That seems to be a long way around adding the tropical filters but it's going well for you 1 Link to post Share on other sites
Valkyrie 4,526 Posted February 22 Author Share Posted February 22 The tropical filters might have been better just being the filters that could be placed over the top or replace just that part. Let’s hope it goes well, can’t stop now! Link to post Share on other sites
AaronKSJ 919 Posted February 24 Share Posted February 24 How are you getting on with the replacement cowl @Valkyrie? 1 Link to post Share on other sites
Valkyrie 4,526 Posted February 26 Author Share Posted February 26 @AaronKSJ thanks for looking in. They have sat on the bench while I pluck up the courage to attempt it. My plan is to build up the cowl pieces which i have started so will get the proper shape and hope to try tomorrow with this... Thanks 3 Link to post Share on other sites
Valkyrie 4,526 Posted February 27 Author Share Posted February 27 I think this was the right approach to tackling this, port side engine cover with tropical filter is on the to the cowl ring and under cowl cover. The fit is going to be quite tight. I used Revell contacta first which bulged a bit from the seams so switched to extra thin which wasn’t sticking the flare dampening bits to the replacement engine covers. This stuck it but it has run onto the cowl ring a little..nothing a gentle sand won’t fix. Speaking of sand, I’m going to be trying to give this a sand blasted dusty sun bleached effect with powders by AK and maybe even the glue finger print might help with the texture... 2 1 Link to post Share on other sites
Valkyrie 4,526 Posted February 27 Author Share Posted February 27 Ok so made a real mess of it but it’s together and tightening up. Should be able to tidy up the glue spillages. Eduard kits are magnificent but really over complicated a lot of the time which can be really off putting. 4 Link to post Share on other sites
AaronKSJ 919 Posted February 27 Share Posted February 27 Not wanting to jinx it, but is the trickiest bit out of the way? 1 Link to post Share on other sites
Valkyrie 4,526 Posted February 28 Author Share Posted February 28 I hope so, with the fiddly construction of so many parts, hopefully the shape is correct. Getting it to mate up underside at the wing root and fuselage will be tricky too, then sanding all the glue off, probably losing all the nice rivets and detail. Should be plain sailing after that 1 Link to post Share on other sites
Valkyrie 4,526 Posted February 28 Author Share Posted February 28 Cowl tidy is going well and despite Eduard’s ridiculous over engineering at times it’s coming together. going to glue wings to fuselage next then put this to one side as I need to try something else...the 109.. 3 Link to post Share on other sites
Col. 12,053 Posted March 1 Share Posted March 1 Good progress on a kit that does sound a little over-engineered. 1 Link to post Share on other sites
Valkyrie 4,526 Posted March 1 Author Share Posted March 1 Thanks Col, maybe it’s just me, but sometimes they are just over complicated. They are always worth it in the end...if you get to the end lol.. Link to post Share on other sites
