Bf109G-10--- Yellow 5 10./JG 51 1945
My build to take a break between all the sanding and masking of airliners. I have 3 109s to do
a Hasegawa 1/48 K-4, an Academy 1/48 G-14 and this. Not sure how many will get done this year
it's a busy build year for me. This is an OOB build so kit decals and parts, no PE. The start.---John
I'll follow this build if that's okay.  I've a Gustav of my own not very far down my list of builds.
Started the wings. I had problems joining the upper and lower halves, the wheel well inserts seemed to hold them
up a bit but I clamped and glued several times and finally got the gaps closed. I think the wheel well inserts were a
bit over engineered and made it a bit fiddly.---John
I can not post images as Imgur seems to be having issues, I will try to post images a bit later---sorry---John
For assembly the wings follow these steps
1 bottom
2 upprer side but start from the root to make a smoot allignement . l
Let dry for 1 day then you can glue the rest
It's my metod and I forgot the putty
After a lot of clamping and prodding I have the leading edges of the wings cleaned up along with the wing roots.
The wing join to the fuselage was quite good and almost uneventful.---John
Well you got it looking ok in the end, I'm glad I can across this I have a G6 from the same tooling.  I'll watch out for this when it's my turn.
Edited by Walter
Pretty good work but you will have to remake the rubber seal between the fire wall and engine cover (where there is much putty) and leave the seam on the back as this is a trademark of the 109. best regards.
Done, just waiting to do a bit of blending.---John
I know the feeling. I have 4 airliners paying the price for my 109 "motivation"!
I have this one, a K-4 almost in same construction stage and a soon to be
started G-14.---John
And here we go! Great work! Painting soon? Cheers.
Just masked and painted the bare metal on the underside of the wings and fuselage and a small
area of the intake scoop. I sanded down the area near the front of the wind screen.---John
I just painted the RLM 76. It came out good except for the tail wheel breaking off. I knew that was eventually going to
happen. I didn't like the idea of trapping the strut in between the fuselage halves, never works for me.---John
I found a nice dark green for the prop. Tamiya TS-9, British green.---John
  • 3 weeks later...
I have remasked and am awaiting paint. I got bored so I decided to try and drill the broken tail wheel
out and fix it with a wire splint. I drilled a hole in both parts then inserted the wire and super glue, put
some super glue in the hole in the mating piece and joined then positioned them proper. When that was
set I ran some Tamiya thin glue around the outside of the mated parts to hopefully "melt" the outside
plastic together, a little extra protection.---John
