Revell 1/44 Space Shuttle Stack + New Ware Kit
OMG, this is modeling madness! :yikes: How big are your snippets for the tiles? :hmmm:
These tiles were normally 6 by 6 inches (15 by 15 cm) square, what means in 1:144 aprox. 1 by 1 mm ... :doh:
I made the exact same calculation!
I’m cutting 1mm x 1mm square tiles as accurately as I can but obviously being off by even 0.1mm is a 10% fluctuation so they’re not, nor will ever be exact.
I’m then cutting any irregular sized tiles by eye to fill in gaps etc.
I am ‘roughly’ following the actual tile layout but I’m not worried about every tile being right!
Each tile has to be dipped in superglue first to ensure a strong bond, very fiddly work but quite therapeutic. I am finding tiles all over the house though, in bed, the wife found one stuck to her boob at one point...
Thanks for the kind words, I’m glad people think it’s looking good!
  • Haha 5
Unbelievable, my respect for your work is rising constantly, up045518.gif because then you will need around 20.000 tiles ... crazy.gif
As promised a quick update.
Not too much to report but since last time I have...
- Realised my original window plan wouldn't work/look right (the frames would've been too deep) so instead I carefully cut some clear plastic from a pop bottle to the size of the window aperture and glued it in place. Of course I used superglue which has fogged them up a bit but I am not going to beat myself up about that too much. It does mean though that the cockpit I scratch built can be barely seen! At least I will know it's there I guess...
- I have re-done the window rivets in metallic (previously in grey) these are a little bigger than I would've preferred but I couldn't get them any smaller, I had to use the head of a pin dipped in paint to get them this small!
- I have added some more of the thermal blanket protection to the sides and along the edges of the bay in anticipation of covering and fitting the bay doors.
- I have given the wings a very quick coat of white just because the grey primer shows up too dark through the masking tape layers.
- I have also added black protective tiles along the forward leading edge of the wings.
Thanks again for the kind words and continued interest in my build!
164694092-127873215947507-60890687603112
165243297-481693336292811-39501308083526
165283204-899276980912237-53646008212347
164965238-126423496109070-72728149863746
Hi everyone!
Latest update...
- I have glued in the cargo bay interior and part of the cargo bay contents (just for strength and stability) and using some of the plastic sprues added some support beams for the doors.
- Doors have been primed and had the tiles applied.
- The masking tape 'blankets' were looking a little yellow in comparison to the rest of the tiles so I have painted these with a very light grey.
- I have started applying the tiles to the wings.
- I have been rubbing a pencil on some paper then wiping my finger over it to add some 'dirt' to the cleaner areas to give it a 'well travelled' look.
Thanks for looking!
166819172-480380846330981-46973658378351
167196972-442519826809124-66849103144767
167462029-289213795932809-23125548813558
167463536-443117963660774-27146449409172
167496349-959453738137594-40933372369974
Hi,
Another quick update albeit slow progress!
I have finished applying the thermal blanket tiles to the sides of the orbiter and have fully tiles one side of the vertical stabiliser.
I did some tests with the Revell decals onto the fabric tape material but it's a bit too obvious that there's a shiny decal on a matt fabric so I have ordered some dry rub transfer paper that I am hoping will give a better finish.
Cheers!
169057004-255880049563289-39140109872187
169266245-444022910234652-24321039196987
169635541-811203493086186-10852532323467
169426892-1171917193273224-8384322465887
Hi guys!
Not done much in the past week or so as other things have gotten in the way, but what I have done is...
- Tiled the left OMS cowling
- Covered the left wing surface in masking tape 'blankets'
- Painted over all the white areas with a thinned out white paint to try and get less differentiation between the different materials
- Continued the slow job of tiling the bottom of the orbiter
Thanks for your continued interest!
174331026-490557565640717-52282306299895
174484290-134446591980693-54253485640622
174353604-808575166412837-58703526354000
174564457-2246011348863061-5838140683713
174323307-277760657312272-40346724070542
  • 4 weeks later...
Sorry there’s not been much action recently, I’ve a new job which is taking up more of my time than before.
Progress is continuing though, been working on getting more tiles affixed to the bottom of the orbiter.
Getting there!
254-BC4-D7-0-F13-4272-AAE9-6-DE3-FAFD0-D
65731-C00-D340-4157-82-D5-DF09-EF8-CBEF8
  • 4 weeks later...
Almost there! A little bit more work and that will be the underside fully tiled... I also did a very quick job on the fuel tank connections since they’re not likely to be seen much/at all.
69-D81325-D175-400-A-950-D-102-F0-EDD435
96019910-460-E-4763-A875-9-B87-BCE6765-A
708-AF6-B9-BF6-E-42-EC-8-A3-F-1-DE9574-D
She's looking amazing dude! The more shuttles I see, the more I want to construct one using this tile technique.
I'm considering doing it to either the Tamiya 1/100 as I read its one of the best recreations out there
OR
Doing a kit with the SRB's and main tank in situ complete with tiling
Keep up the good work bud and please keep posting :)
Cheers! I'm really enjoying the build but i'd be lying if I wasn't ready to do something other than tiles!
Looking forward to getting the decals applied, I ordered some 'make your own' dry rub decal paper in the hope it'll give a nicer finish than waterslide decals. Also excited to start painting the engine cowlings.
But for now, it's tiles and tiles and tiles...
Have you managed to get anything more done matey?
I bought an Airfix stack 1/144 yesterday so have big plans down the line 😁
Cnt wait to see yours progress
Regards
Hi,
A little bit of progress, was gonna wait until more was done for an update but since you asked...!
I’ve done the other side of the tail and the other upper wing surface, plus I decided to give the whole orbiter another wash of thinned down white for a more even colour. Once all the white areas are done I’ll go back and touch up the black parts that need it.
1-DEDFD2-B-B578-4267-9403-56-C39-FCD99-D
FC06810-F-76-F3-4-F97-B7-D0-935-EEDD40-D
8-A89-E20-B-D017-4379-83-EA-B962-BC0-C86
Be sure to share your progress once you start your model!
Jinx I've also just bought a Monogram 1/72 stack so am already considering options for her - exciting times ahead!
I lookforward to more of your content, absolutely love the effect you've achieved, the front nose section looks superb!
  • 4 weeks later...
Hi!
Apologies for being absent for a while, I haven't had much modelling time recently and figured there's no point in updating every little bit I do.
Since last time I have tiled the other OMS cowling, both sides of the orbiter, made more progress on the bottom heat shield and started on the rear section. Also some more white paint washes added to try and give better colour consistancy.
Plan of action next is to finish the bottom heat shield, rear section and the horizontal stabilisers. Then I will paint the grey RCC bits on the nose and leading wing edges. After that I can start to paint the engine cowlings and add some more detail to various bits of the orbiter that need it, will also touch up any black areas that have gotten some white paint on them. Finally try this dry-rub transfer paper, so design all the decals I will need for the markings, little hatches, warning signs etc and apply them.
Hope you like the pics and thanks for your interest!
228207117-1135017590325012-1594318856338
228476712-215190853732506-79047690118895
221831641-218191476878712-72651030088467
228347950-2986484994961283-7401214131109
226454448-4547903118622367-2595400848258
228775507-360260132255551-60665623430543
  • 3 weeks later...
Well it’s taken an age but...
Milestone reached!
After what must be a few thousand individually hand-cut and superglued pieces of electrical tape The bottom of the orbiter is finally tiled.
192140-B0-741-D-4144-AB08-0695017-C4-AFE
Quick update before heading to work...
Horizontal stabilizers done and cargo bay door hinges added. I am starting to see the finish line with the orbiter I think (though still lots to do!)
9-E058066-C3-EE-4079-95-ED-2-FFB1922066-
0-B261121-7-B95-4-BBC-96-DD-02-A581420-C
BD87-D353-1-F78-4-E15-91-CA-9-D937-DB47-
7-EC0-F1-E6-BD47-4958-B23-B-50-FF9-AFBDC
