patmaquette Posted March 11, 2021 Author Share Posted March 11, 2021 On 07/03/2021 at 07:32, (ex)Sgtrafman said: Hey Pat you’re doing sterling work there buddy, glad I could be of assistance re the radiator grill and I look forward to seeing it in situ. all the best mate Iain Thank you, Iain - I'm getting closer to fitting that grill. I glued the engine in place today and have started attaching the various conduits. Should be ready for the grill within a week or month! On 07/03/2021 at 10:22, Alan P said: This is pretty spectacular. It's like an engineering project 😮 I'm glad you like it Alan 🙂. This big model is a good way to get to know the ins & outs of the aircraft, although I'd much rather work on the real thing of course! With the cockpit about done, now onto the engine. This was primed with black Mr Surfacer 1500. I noticed some flanges were missing on the four supercharger outlets so added these from rings cut from plastic card..... (you can also see some filler has been put over some quite deep shrinkage dimples in the carburetor). and then cut to shape in-situ..... Xtracrylix XA1036 RAF Dark Camouflage Grey was then applied to upward facing areas of the engine. The airbrush was held at the 10 o'clock position over the engine and the paint directed down, leaving the black primer coat visible in areas of shade. A gloss coat of Tamiya Clear X22 was next and this was followed by a pin wash of Citadel Nuln Oil shade mixed with Klear. Highlights were picked out with a medium grey oil paint diluted in odorless thinners. This was applied lightly to edges. Larger areas such as the ducts on the top of the engine and pipes had the oil paint brushed on as a line and then the edges were feathered using a clean and dry Microbrush. Various conduits have also been painted and are ready to install. I used Vallejo 71.065 Steel as the base colour. A mix of 70.939 Smoke and Klear was applied to the braided areas and various connections.... The distributor cable harnesses were also given a glaze with the same mix. Medium grey was brushed onto highlighted areas of the banding around the cables. As mentioned above, I have now started assembling the parts into the engine bay. I think I will fit all the kit parts before deciding what additional detail to add. I'm having problems figuring out what details are in the kit and those that have to be made, and making sure I don't do something that makes assembly difficult later. So I'll take the safe approach I think. I still haven't decided on which aircraft to finish the model as. I've read "Hawker Typhoon - the combat history" by Richard Townshend Bickers and that has given me some ideas. Ideally, I would like to find one flown by a French pilot (as the kit was a gift from French club members) but haven't found an example yet. Many thanks for stopping by to look! Any thoughts or comments would be much appreciated 😀 Cheers, Pat 8 Link to comment Share on other sites More sharing options...
Elwick Posted March 13, 2021 Share Posted March 13, 2021 Really enjoying seeing the build - very impressive! 1 Link to comment Share on other sites More sharing options...
patmaquette Posted April 3, 2021 Author Share Posted April 3, 2021 (edited) Hi everyone, Progress has slowed since my last posting, but I have now installed the kit parts for the engine bay and started on adding some extra detail. I have also reached the point where I need to decide on the aircraft to depict and have spent some time working on this (and maybe you can help me with this? - see later). The engine block needed to be massaged into position: there is a cruciform-shaped spine that runs throughout the length of the engine and supercharger, and protrudes out to locate the assembly to the fire wall. To get this into place also requires the engine mountings to be eased aside. Airfix rely on the soft and flexible plastic to get the parts to fit together - I think it would be nigh-on impossible to build this kit with the hard type of plastic we get from most other kit manufacturers! Having wrestled the engine into place, it had to be pulled apart sufficiently to apply glue and then pushed back and held there with lots of clamps whilst the glue set..... Here is the engine with some of the harnesses added... I have been looking forward to putting on the photoetched grille that Iain @(ex)Sgtrafman let me have, and it did not disappoint. The plastic parts of the radiator assembled together quite well, but the joints along the sides need careful filling and sanding because imperfections would show under the metallic finish. Note the fine raised edges that run around the front and rear need to be preserved: straps holding the radiator to the mountings above run between them and I used a slightly different tone to the radiator to represent them. The radiator was airbrushed Citadel Boltgun Metal over a primer of black Mr Surfacer. Aluminium was sprayed onto highlights and a darker shade, Vallejo Oily Steel on the undersides. The faces were airbrushed Vallejo Track Colour to provide a dark neutral brown backing to the pe grilles. The grilles were airbrushed with Vallejo Smoke with Thinner Medium, mainly around the outside and along the braces, leaving the middle areas with very little paint. The grilles fitted really well and were secured in place with Klear as per Radu Brinzan's instructions. The Klear was applied lightly around the edges, trying to avoid it tracking through and filling the fine holes in the grid. The radiator piping looks to be a dark colour in photos, although some show them as silver. I opted for oxidised copper and undercoated the pipes with Vallejo 70.880 Khaki Grey.... and then applied a glaze of Humbrol 10 dark brown mixed with Liquin Fine Detail. This glaze was removed from highlighted areas..... I think the idea was right, but I should have used less brown paint in the glaze as it has come out far too dark. Burnt umber oil paint would probably have been a better choice of paint as well. The finish is too shiny and so I'll cut it back with some satin varnish later on. The glycol coolant ring header tank has a flexible hose that I represented with some turns of 0.5mm string.... This was coated with black Mr Surfacer. Metal connections top and bottom were added from 0.6mm lead wire..... The circular front plate behind the spinner should have holes for cowling fasteners and some notches cut in. Also, it benefited from thinning around the edge that lies against the header tank. The hole positions were marked onto Tamiya tape using the cowling panels as guides. Photos were used for placing the notches.... I painted the front plate with Vallejo Grey-Green, followed by a coat of Klear and then a pin wash of Vallejo Smoke + Klear. I also used this paint mix for the underpan. As I intend to display the model with the cowling panels removed, I decided to thin down the edges and add some internal stiffener detail (not that I could find a photo of it) using Tamiya flexible masking tape.... The carburettor intake was painted in Tamiya Medium Sea Grey with Vallejo black-grey for the flow splitter. A jubilee clip was represented by a strip of metal foil that was glazed with some Smoke + Klear..... I noticed a cross brace was missing from the frame above the radiator. This was added from plastic rod but, quite honestly, little of it could be seen once the radiator was installed.... Here is the model assembled with the kit parts before I add any further detail into the engine bay... The first items of detail I added were a couple of triangular brackets from plastic card. These attach to the front of the radiator mounting. Typically for me when making items from sheet (whether plastic or metal) is to do internal cutouts first..... And then score for folds and cut the parts from the sheet.... Doing it in this order reduces the risk of the sheet splitting or twisting. Some extra-thin Tamiya glue was run along the folds and the parts set to dry square..... They were then glued in place.... Don't worry - I'll not bore you with every detail I add. I thought it might be useful for some who are starting out with adding their own details as to how I found it best to do mine. ************* The next stage after completing the engine bay is the wing. Various holes need to be opened up in the lower wing depending upon which aircraft the builder selects. So now having reached the point where I need to decide on which aircraft to build, I am thinking of straying from the kit options after having heard a presentation by the Jet Age Museum on 183 Sqdn pilot FO Robert David Acker RAFVR who died when his Typhoon was hit by flak in an armed recce attack on 18 August 1944 in the Falaise area. I would like to depict my model as the one in which he was flying when he was hit, however there seems to be some uncertainty as to which of the squadron's aircraft it was. There are differing accounts as to how he was killed and in which aircraft he was flying. The presenter said that JR128 HF-L was most likely, and indeed "Hawker Typhoon, The Combat History" by Richard Townshend Bickers does list this aircraft as being brought down by flak near Livarot on that day. A second option was MN595 HF-D which the reference also lists as lost on that day, but this time as being brought down by a Bf109. In checking through my books and searching on-line, I discovered that I could download (for a small fee) squadron records from the National Archives. I found those for 183 squadron for the month of August 1944, but rather than add certainty it confused the matter. It also made sobering reading. I read there were nine aircraft on that mission and that David was flying JR431 for the second time that day. So why am I confused? - well JR431 was also listed in a later mission so could not have been shot down - and all the other aircraft on the same mission were also used on later ones. JR128 was not mentioned at all in the record for that month (so therefore no mention of its loss). MN595 was in action up until 15/8 but no mention is made of its fate on 18/8. The record says attacks were made by rockets and cannon, so I will install rocket rails on my model rather than bomb racks. In the absence of confirmation that David was flying JR128 when he died, my first alternative is JR431, but I do not know the squadron code for that aircraft. My next alternative will be JR390 HF-U which David flew on missions twice the day before he died. Looking through the invaluable information in the AMW Hawker Typhoon supplement by @Chris Thomas, all of these have the smaller tailplane so I can get on with building the model while I finalise my choice. MN595, on the other hand, has the larger tailplane, so I'll avoid that option unless something convincing turns up before I commit glue to that part! If anyone has any information or opinions on the above I would love to hear them! Thank you for stopping by to read 😀 Cheers, Pat Edited April 4, 2021 by patmaquette JR128 crash site changed from Evreux to Livarot. 11 1 Link to comment Share on other sites More sharing options...
Murdo Posted April 3, 2021 Share Posted April 3, 2021 It would be a terrible pity to cover this incredible work with a fuselage and wings! 1 1 Link to comment Share on other sites More sharing options...
Chris Thomas Posted April 3, 2021 Share Posted April 3, 2021 Sorry Pat but Flg Off Ackers was indeed shot down in MN595 HF-D as confirmed in MoD casualty records. JR128, although it had (famously) been HF-L, was lost on the same day, 18 August 1944, but by that time was flying with 181 sqn (code EL-). Whatever, it will be a terrific model. 1 Link to comment Share on other sites More sharing options...
patmaquette Posted April 4, 2021 Author Share Posted April 4, 2021 12 hours ago, Chris Thomas said: Sorry Pat but Flg Off Ackers was indeed shot down in MN595 HF-D as confirmed in MoD casualty records Chris - thank you looking into answering this question, I much appreciate it. Additionally, thank you for researching and publishing on this (and other) aircraft, it's been the go-to source for me. I'm glad I didn't go for JR128, that would have been an embarrassing error! Although I guess it is not an important point, but is one I'm curious about, do you know whether David Ackers was shot down by flak (squadron report) or by Bf109s (The Combat History book by Richard Townshend Bickers)? Thanks sgain, Pat Link to comment Share on other sites More sharing options...
Chris Thomas Posted April 5, 2021 Share Posted April 5, 2021 There seems little doubt from the account in the squadron ORB that F/O Ackers was shot down by flak. This was at the time the jaws of the Falaise gap were closing and the trapped German forces were both desperate and well-armed with an ever increasing concentration of Flak. It was the day on which most Typhoons, 17 in all, were lost to enemy action - most attributed to flak - and the unknown causes may well also have been flak. There were no German claims for Typhoons that day. R.T.Bickers seems to have compiled his Typhoon listings directly from the Air-Britain serial registers (when people copy mistakes it is a give-away!), which incorporated information from my Air-Britain Typhoon File, both of which had MN595 shot down by Bf109s. I checked backed to my working notes for the latter and I had MN595 as shot down by flak! So it seems there was a typo in production, which may well have come about through the fact that 183 Sqn had lost 4 Typhoons to Bf109s the previous day. Incidentally, JP431 (quoted in the ORB as Acker's aircraft) was in fact the replacement HF-D. A very common type of error in the ORBs in general. 1 1 Link to comment Share on other sites More sharing options...
patmaquette Posted April 5, 2021 Author Share Posted April 5, 2021 Very interesting information, Chris. That settles the matter perfectly. I'll also let the presenter at the Jet Age Museum know, as he had been studying the life of Robert David Ackers. Thank you so much for giving your time and expertise to help me out, I really appreciate it. Best regards, Pat Link to comment Share on other sites More sharing options...
bigbadbadge Posted April 5, 2021 Share Posted April 5, 2021 Absolutely stunning work, love all tge extras you've added, the terminals in the cockpit, the seat cushion effects etc. Brilliant work. Chris 1 Link to comment Share on other sites More sharing options...
Johnson Posted April 5, 2021 Share Posted April 5, 2021 Hi Pat, A most amazing build, I am in awe of the details (the i/p and cockpit are superb, the engine, pipework...) and techniques you've employed. Really great work and I've enjoyed reading your thread from the beginning. I could go on but would run out of superlatives! The research on F/O Ackers and the Typhoon he was lost in is as fascinating as it is sad. I look forward to following the rest of your build. Best wishes, 1 Link to comment Share on other sites More sharing options...
patmaquette Posted April 7, 2021 Author Share Posted April 7, 2021 Many thanks @Murdo, @bigbadbadge and @Johnson for your kind and encouraging comments on the build so far 😀. I have now completed adding further details to the engine bay. I've left most of them unpainted so they can be picked out in the photos. One item missing from the instructions is a pipe (part C14) that attaches to the Coffman engine starter at stage 64. I didn't notice this until too late and used wire for the piece of pipe, but I thought it a bit strange that Airfix had provided location holes for it!.... Although I have heard of a Coffman starter and have a rough idea how they work, I've never seen one. From what I have learnt when building this model (making kits is a fun way of learning, as I have found since childhood!), the Coffman starter installed on the Typhoon's Napier Sabre engine has a carousel of five cartridges each containing a cordite charge. One is used at a time for starting the engine and the gases pass through pipe C14 and drive a piston in the cylindrical portion of the starter. The piston causes - by means of a thread - a shaft to rotate and this drives gears in the rectangular portion which connect to the upper engine crankshaft, causing it to rotate. A diagram I have been working to shows a hand cranking mechanism on top of the rectangular portion, so this was added from square section plastic rod with some circular housings added - visible in white in the photo below.... Other items added are a cartridge loading lever (and a filter housing which I guess is unrelated) on the starboard side and a firing unit on the port side. In the same area is a push-rod arrangement which goes to the front end of the engine via a bell crank. It connects to a constant speed unit which I made from scraps of plastic.... It has some interesting colour details that look good... On the opposite side of the constant speed unit is a vacuum pump. This looks to be made from brass or bronze. This was once again made from scraps of plastic. It was painted Sand and given a dark brown wash over a coat of Klear. A pair of pipes run across the top of the engine so are quite visible. I used tinned copper wire for these and will give them a coat of varnish to prevent them going dull. The other thing I did was to check that pipes and cables going into one side of the firewall had a continuation on the other side. Some more piping will be added later for the fuel tanks located along the leading edge of the wings. I'll complete the painting of these details as I work on the next stage of the build, which is the wings. Thank you for stopping by to look! Cheers, Pat 14 Link to comment Share on other sites More sharing options...
Johnson Posted April 7, 2021 Share Posted April 7, 2021 1 hour ago, patmaquette said: Thank you for stopping by to look! A real pleasure Pat. I also wondered how the Coffman starter worked, I now have a better idea. Thank you. 1 Link to comment Share on other sites More sharing options...
patmaquette Posted April 8, 2022 Author Share Posted April 8, 2022 Work on the model slowed to a snail's pace whilst we had builders in working on the house - now I see it was a year ago since my last posting. Time does fly. The model is about ready for painting now. It is by far the biggest model I've painted and I am looking forward to making a start - but first I need to mask up all the openings. My painting sequence will be different from what you'd normally expect, so I'll post on progress unless things go embarassingly wrong! I'll also put in some notes about the build since I last left off that may help someone building Airfix's kit in the future. I hope you find something of interest here and any comments would be most welcomed! Cheers, Pat 12 Link to comment Share on other sites More sharing options...
ColinChipmunkfan Posted April 8, 2022 Share Posted April 8, 2022 Such amazing, skillful and detailed work- can't wait for the next installment. Colin 1 Link to comment Share on other sites More sharing options...
mick Posted April 8, 2022 Share Posted April 8, 2022 great work will follow your build 1 Link to comment Share on other sites More sharing options...
Johnson Posted April 8, 2022 Share Posted April 8, 2022 How time flies! I'd quite forgotten your excellent build so I had go go back and look at the engine detail again, wonderful! Looking forward to seeing the outside painted. 1 Link to comment Share on other sites More sharing options...
stevehnz Posted April 8, 2022 Share Posted April 8, 2022 Though I'll likely never build or even own one of these, as a Typhoon fan from way back, I've enjoyed a read through this & marvelled at both the intricacy of the kit & the work you're doing to bring it to life. It will be good to see it come to finality & make a suitable tribute to FO Ackers & his fallen comrades. They did take fearful casualties in their daring attacks on the enemy. Steve 1 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted April 8, 2022 Share Posted April 8, 2022 Good grief, just been looking back at your incredible engine work, all you need to do now is add fuel and get that coffman starter fired and is looks like it would happily splutter into life. Crikey a year!!! Time certainly is flying by. Still the Tiffie is looking very impressive and am looking forward to seeing the paint go on . Seriously tremendous work. Chris 2 1 Link to comment Share on other sites More sharing options...
thommo Posted April 9, 2022 Share Posted April 9, 2022 Superb. 1 Link to comment Share on other sites More sharing options...
patmaquette Posted April 9, 2022 Author Share Posted April 9, 2022 Thank you to everyone for your comments and "likes". The masking went quicker than I expected today and I managed to lay on a primer coat as well. I don't know whether this is of interest to you, but here is how I mask things like navigation lights and leading edge stripes, which can be tricky because of the curved surfaces (especially in smaller scales, although that is not the case here). Here is one of the Typhoon's navigation lights. Although it uses the clear lens from the kit, there have been some alterations made (I'll cover that another time)...... Thin strips of Tamiya stretchy tape were placed along the outside of the light......... Liquid mask was applied. I've used a number of liquid masks, and the Vallejo one is my favourite.... The Tamiya tape is peeled off whilst the liquid mask is still wet. Any seepage under the tape can be trimmed away once the masking fluid has dried. I used thin sheet foam for masking elsewhere, supplemented with squidgy foam, Tamiya tape and Blue Tack. I lined the edges of openings with tape and then put squidgy foam into cavities to stop the sheet foam falling in. More Tamiya tape then held the sheet foam in place. The model was given a good rub down with methylated spirits and then given a coat of Grey Ultimate Products primer. I'll leave that for a day or two before addressing any defects and then recoating. With that done, my next step will be preshading. That will comprise zenithal highlighting for light and shade effects (something miniature figurine painters are familiar with). I also plan to try highlighting the wonderfully rippled panels that Airfix have in their mouldings by dry brushing, having watched this video ... https://youtu.be/kxuY2NXeI2M by Artis Opus. I won't be able to do anything like as well as him, but I fancy having a try. 🤞 Thanks again for reading and your interest. Pat 7 Link to comment Share on other sites More sharing options...
patmaquette Posted April 29, 2022 Author Share Posted April 29, 2022 Hi everyone. I found a couple of areas where the model needed remedial work after the first coat of primer. There were also some places where I had skimped a bit on the dark grey primer and also some spots where the paint had crazed - looking like cracked earth. I put this down to the plastic not being clean and grease free. However, I had a lot of problems with the second coat of Ultimate Primer reactivating the first layer and making it very rough. Maybe my second coat had been laid on too heavily. Anyway, I stopped as soon as I noticed the problem and left the paint to harden off for a couple of days before smoothing it with Micromesh and sanding sticks. I airbrushed a light grey (Vallejo white-grey) pre-highlight along the spine of the fuselage, across the wings, tailplane and other places where the light would strike. This was also done for the various cowling and fuselage panels, as well as for the rocket rails where they would protrude from the shade cast from the wing leading edge. Individual panels were picked out by brush using the same colour where the light would catch. This was done by observing & following the rippled skin effect Airfix have put into the mouldings.... I am using paint masks for the aircraft's markings for the first time and, contrary to what I suppose is normal practice, decided to apply them before the camouflage colours, rather than after. The reason was that I wanted to make use of the painted pre-highlight and undershade effects under the markings. I found that using masks and paint means the model gets a lot of handling and lifting & repositioning of masks, which could rub away or peel off your top coats of paint if you were to do all this work at the end. So I think doing it early on has a lot going for it - but those of you with more experience of using masks please do comment one way or the other! Chris Thomas's supplement in Airfix Model World magazine usefully illustrates how the Typhoon's markings changed over time. I used this, along with Ducimus' Camouflage & Markings, RAF Fighter Command, 1936-1945 for positioning the markings, checking as I went against period photos. The aircraft I am modelling, MN595, had the enlarged tailplane and has the trailing edge of the Sky fuselage band cutting across it. The dimensions I had for positioning it were based on the earlier tail, so this was corrected for by taking measurements and doing some sums which placed the back edge of the band 1.7mm behind where the kit's fin part attaches to the rear end of the fuselage. The 18" band scales out at 3/4" wide. The model is intended to represent MN595 on the day of its loss on 18 August 1944. Invasion stripes had been removed from upper areas of the fuselage and wing a month or so before that time. Five invasion band stripes of 18" (3/4") were placed ahead of the Sky band. In reality, there was some variation in positioning of the stripes and how much remained after the bands were reduced on the fuselage - seemingly on an aircraft by aircraft basis - but I don't have a photo of my selected aircraft, unfortunately. The wing bands commence 6" inboard of the upper wing roundels. These 50" diameter roundels are placed 84" from the wing tips, therefore the bands commence 115" (or a scale 122mm) from the tips of the wings. The roundels on the fuselage were placed 34" (36mm) behind the rear edge of the First Aid hatch on the port side. The height of the centre is not given in the Ducimus plan, but was easy to gauge from the position of a prominent panel line visible in period Typhoon photos. The rear edges of the fin flashes were positioned 1/2" (0.5mm) from the rear of the fins. The bottom edges are placed 12" (1/2") above the tailplane. The squadron codes were added next, but everything got a bit crowded so they were taken off until the roundels had been painted. Painting commenced with the white of the roundels, flashes and invasion stripes using Vallejo 70.993 white grey which gives a nice scale-effect tone. A purer white was added where the light would catch, but this was kept to a minimum (a "light touch" only!). The black followed (Tamiya NATO black - is there any other option!). The red was a mix of 70.908 Carmine red with Scalecolor SC14 Kalahari orange (I'm sure there are better alternatives to mixing the colour, but these did the trick from what I have in my stock). Yellow was Humbrol Trainer Yellow. The blue was mixed from 71.004 blue and 71.091 Signal blue. I typically also add a drop of Vallejo flow improver and quite a bit of Vallejo airbrush thinner to the airbrush cup. With the markings, stripes and wing leading edges done and masked, the squadron serial codes were added. Contrary to the instructions supplied with the masks, I found it much better to apply each letter alone, leaving the surrounding part on the sheet. Some jiggery-pokery was needed to get the letters positioned (once again using photos as guides, although once again there seems to be a lot of variation). The surrounding parts of the masks were then placed over the letters and the letters then removed ready for painting. It was impossible to get the mask film to conform to the detailed surface of the model, so I expect there will be some overspray. The letters were then put into place once the paint had dried and surrounding parts peeled off. The model is now at a stage for the main colours to be laid on. All of the above took a long time as I generally waited a day for the paint to dry at each step before messing around with masking. You may be able to do it quicker, but I didn't want to risk any damage to the paint film. There were other things that could be worked on during the wait, so the time was not wasted. I hope you find the above of some interest and thank you for passing by to look 🙂 Pat 10 Link to comment Share on other sites More sharing options...
Ngantek Posted April 29, 2022 Share Posted April 29, 2022 Oh what a treat, this is looking amazing! Instant follow! 1 Link to comment Share on other sites More sharing options...
Johnson Posted April 29, 2022 Share Posted April 29, 2022 52 minutes ago, patmaquette said: I hope you find the above of some interest Very much so Pat. Your pre-shading and highlight work is fascinating. I'm intrigued and looking forward to seeing how you will mask the insignia and codes. Best wishes, 1 Link to comment Share on other sites More sharing options...
patmaquette Posted April 30, 2022 Author Share Posted April 30, 2022 22 hours ago, Ngantek said: Oh what a treat, this is looking amazing! Instant follow! Thank you @Ngantek, great to have you aboard. I do hope it leads to a good result - but there is plenty of opportunity ahead for me to muck it up! 😬 22 hours ago, Johnson said: Very much so Pat. Your pre-shading and highlight work is fascinating. I'm intrigued and looking forward to seeing how you will mask the insignia and codes. Best wishes, Thank you, Charlie. It is a tricky matter to get the result right - I normally end up putting on too much paint and losing all the pre-shading and highlighting, so fingers crossed it goes okay this time. 🤞 Time now for painting the underside in Medium sea Grey. I chose AK Air Series AK11843 paint for this, after having tried it out first on Airfix's 1/72 Typhoon, which I preferred somewhat over Tamiya paint that I used in a side-by-side comparison on their Mosquito before committing it to the big Typhoon that I want to avoid screwing up if at all possible! Both little kits were fun to build. I used some W&N Flow Improver with copious quantities of Ultimate Airbrush thinner with the AK paint, and the mixture needed to be thoroughly mixed together before spraying through the airbrush. Here is the little Typhoon in AK paint.... And this is the Mossie in Tamiya, using their acrylic thinners.... The heavily thinned AK paint was applied in a number of layers. I aimed the spray for the middle of each panel, leaving the darker grey of the primer coat to show through at edges and rivet lines. I kept it off the pre-highlights I had already put on (although that was difficult in some places) until towards the end of the painting session, being careful not to completely obliterate it under too much paint. Here work is under way on one side of the tailplane so you can compare it to the unpainted other side..... Each paint layer was applied thinly and I moved onto fresh areas to let it dry off before adding more. The big model, along with the other loose items that also needed painting, gave plenty of time for drying off before returning to it. Here is the completed painting... I removed the masking where I could as I don't like to leave tape in place any longer than necessary, as it can sometimes be more difficult to remove without peeling off the paint beneath if it is left for a long time. The masking went well, there being only a little overspray. I don't foresee such a good result on the top surface though, owing to it not being flat. I notice that the engraved surface detail - such as panel lines and rivets - are still in the darker grey primer colour. I wonder whether I still need to do a panel line wash? It would save the trouble of gloss coating, washing & matt coating. I'll see how the topsides come out before deciding. Work has now moved on to marking out the camouflage pattern on the topsides of the model and painting the dark green. Thank you once again for passing by and all your thoughts & comments, Pat 10 Link to comment Share on other sites More sharing options...
Johnson Posted April 30, 2022 Share Posted April 30, 2022 1 hour ago, patmaquette said: being careful not to completely obliterate it under too much paint Successfully by the look of things. 1 hour ago, patmaquette said: I notice that the engraved surface detail - such as panel lines and rivets - are still in the darker grey primer colour. I wonder whether I still need to do a panel line wash? Not from what I can see, but that's just the photo, only you can see what's really there. I'm not a fan of panel line washes, purely personal view! Your call. My eye keeps getting drawn to the wheel bay, quite amazing. 1 hour ago, patmaquette said: but there is plenty of opportunity ahead for me to muck it up! 😬 I can't really see that Pat! Looks great, looking forward to the upper surfaces. Cheers, 1 Link to comment Share on other sites More sharing options...
