RAF 1000LB Bombs (Free fall & Retarded tails) (209432 & 209532) 1:32 VideoAviation.com
The RAF Have used the 1000Lb bomb for a while, the standard bomb body can be fitted with a variety of Fuzes and tails, including paveway guided bomb kits.
The Bombs
They arrive in videoaviation's standard clear clam-shell box with an insert showing the bombs. Like the real bombs they are split into the bomb body and the tail units. There are a couple of resin runners which hold the tail fuse vanes and the carry lugs.  There is also 2 small decal sheets for each set.
Freefall Tails
Retarded Tails
Conclusion
Another quality product from Videoaviation. If you're planning on bombing up your 1/32 RAF aircraft then you need to look at these. Highly recommended.
Review sample courtesy of
