Sandbagger 2,257 Posted February 4 Share Posted February 4 (edited) Hi all, I'm now starting on the 'Wingnut Wings' 1:32 scale model of the Roland D.VIa fighter. This aircraft was unusual in that its fuselage was clad in overlapping plywood planks, known as ’lapstrake’, which was similar to that used on clinker built boats. This proved to be as strong, but lighter than existing constructions methods provided, which was an important factor for a fighter aircraft. Also the lower wings were located under, not into, the lower fuselage. It's the Roland D.VIa, Serial No: 3615/18 during 1918 (Jasta unknown). Mike Edited February 18 by Sandbagger Different aircraft 4 Link to post Share on other sites
Ted 1,852 Posted February 5 Share Posted February 5 You're relentless Mike. I have this kit and look forward to watching you give it the expert treatment. Nice choice scheme too, it has some colour but also lots of visible strips of varnished spruce. Link to post Share on other sites
John Masters 16,064 Posted February 5 Share Posted February 5 Lovely aircraft and not so commonly built. This'll be a good one I am sure. Link to post Share on other sites
Marklo 7,147 Posted February 5 Share Posted February 5 As with almost everything WWI I have a 1/48th kit in the stash so this will provide inspiration. Link to post Share on other sites
Sandbagger 2,257 Posted February 11 Author Share Posted February 11 (edited) Hi all, A few updates. I'm working on the fuselage internals and the engine. The fuselage halves were two-tone, as were the cockpit side frames. The engine bearer frame was a single colour. As I normally do, the slight weathering effect was done using the 'Flory Models' dark dirt clay wash. The rudder, elevator and ailerons control lines were added using 0.08 mm diameter mono-filament and blackened 0.4 mm diameter tubes. Other detail, such as pipes, seat harness etc will be added after the cockpit assembly is built and before closing up the fuselage. The next stage, after completing the engine is to assemble the fuselage, Mike Here's the engine. As most of the engine won't be seen, it's just the basic engine with the addition of ignition leads and the pipe at the front cylinder. The replacement exhaust pipe is from 'ReXx', Mike Edited February 11 by Sandbagger 6 Link to post Share on other sites
Sandbagger 2,257 Posted February 13 Author Share Posted February 13 Hi all, Just a quick update. The cockpit structure is now complete and ready to be fitted into the closed up fuselage. I had to sand the outer surface of the two cockpit side frames and cockpit frames quite a bit, as for some reason the fuselage wouldn't close up fully with the cockpit test fitted. I know tolerances are tight, especially on WNW kits so I made sure there was no paint etc on any mating faces. Even so the gap at the underside seam of the fuselage was large, indicating something wasn't fitted correctly. Everything look correct so I'm not sure where the obstruction was - probably around the fuel tank area. Anyway, it's sorted and ready to move onto closing up the fuselage, Mike 5 Link to post Share on other sites
Xtof P 59 Posted February 13 Share Posted February 13 Very nice Start Mike! The exhaust Looks amazing - such a thin wall at the opening and the weathering is just beautiful! Link to post Share on other sites
Sandbagger 2,257 Posted February 13 Author Share Posted February 13 Hi all, The fuselage is now closed up with the cockpit front decking panel fitted. I'm replacing the kit supplied machine guns with resin equivalent weapons from 'GasPatch'. These needed to be modified slightly so that would fit down and into the weapon slots in the front decking panel. This required the removal of the front mounting and synchronizing cable from the underside of the breech blocks. In addition the lower part of the cocking mechanism on the right side of the left weapon was removed. Now it's onto preparing the fuselage for the application of the 'ProperPlane' wood effect decal set for this aircraft, Mike 4 Link to post Share on other sites
Sandbagger 2,257 Posted February 14 Author Share Posted February 14 18 hours ago, Xtof P said: Very nice Start Mike! The exhaust Looks amazing - such a thin wall at the opening and the weathering is just beautiful! Thanks but that's not my work. The exhaust is made by 'ReXx' (from 'ProperPlane') and what you see is what you get. Their exhausts are very well made but are fragile and easily crushed by hand if you're not careful, Mike Link to post Share on other sites
Xtof P 59 Posted February 14 Share Posted February 14 Thanks Mike, have just looked up their Website - great stuff! I envy you a bit for having this Roland Kit - i wanted to do all the WnW single Seaters (did the Fokker E.II and now the D.VII) and have most of them in my stash exept the Sopwith Triplane and the Roland.... Christof Link to post Share on other sites
Sandbagger 2,257 Posted February 16 Author Share Posted February 16 Hi all, The wood effect decals with 'scarf' joint plywood joints (from 'ProperPlane') are now done. These are probably the most difficult decals I've applied. The 'scarf' joint strips and the fin, rudder and lower wing fairing were tricky, but the fuselage decals were something else. They are four separate fuselage long single decals. Not 'cookie' cut and with no marking or transparent areas for the fuselage raised details, such as access panels, pulleys and fittings. Cutting these into sections was not really feasible as any slight overlap of the decal joins would show up as dark (double thickness of the decal. Therefore when you lay down the decal, it rest on top of all the raised detail, like one pole holding up a tent. This causes wrinkles and fold over of the decals. I eventually worked around the problem but not without a few tears (patched) and wrinkles (fortunately on the underside), but these are certainly not for the less experienced modeler. The decals are similar to those from 'Aviattic' in transparecy, but are not as strong. They were laid onto a base coat of 'Tamiya' Dark Yellow (XF59) to darken the effect. Next up is creating the masks for painting the large yellow arrow marking along the sides of the fuselage, which of course will cover a lot of the decals, Mike 3 Link to post Share on other sites
Sandbagger 2,257 Posted February 17 Author Share Posted February 17 (edited) Hi all, There is some doubt now over the authenticity of this particular colour scheme. It seems that it was based on what is apparently the only known photograph of Emil Schäpe seated in a Roland fighter. The Windsock Data file states that he is seated in a Roland D.VI but doesn't state whether it is a D.VIa or the later D.VIb version. The photograph shows what appears to be the top of a multi-headed arrow marking on the side of the fuselage. The late Dan-San Abbott interpreted this as the yellow arrow and this seems to have been accepted by painters and illustrators, such as Bob Pearson's profile I'm basing this model on. The doubts centre on three things - The aircraft in the photograph is a later Roland D.VIb (not a D.VIa), the arrow marking was a lightning bolt marking (not an arrow) and the fuselage was not varnished wood but in fact painted. I've looked again at the photograph and to me at least, the fuselage marking looks more like an arrow head that lightning bolts. Also I believe wood grain can be seen on the fuselage planking, although it is very faint. That said this was plywood strips, which wouldn't have much wood grain as such. As to whether this is a D.VIa or a D.VIb is difficult to tell as the main differences were the D.VIb had a different engine and radiator cowl under the nose of the aircraft, neither of which can be seen on the photograph. One possible clue for it being a D.VIb is that the two machine guns have extended cocking handles, which from other photographs the D.VIa didn't (standard cocking handles). Maybe one day someone will come up with photographic or documentary evidence to settle these doubts, When I build a model I like to try where possible to apply colour schemes that are not often modeled, which is why I chose this particular scheme. I also didn't want to cover the wood effect decals with too much paintwork. However, given the uncertainty of this colour scheme I've decided to switch the scheme to the Roland D.VIa, Serial No. 3615/18, which had no personal or Jasta fuselage markings. Mike Edited February 17 by Sandbagger 1 Link to post Share on other sites
Sandbagger 2,257 Posted February 18 Author Share Posted February 18 Hi all, The basic fuselage is now finished. As I said in the previous posts, the original colour scheme I was planning to do is in doubt, as to its authenticity. In addition, any masking or masking tape laid onto these decals, no-matter how gently, started to lift the decals. Having spent time and effort applying the wood effect decals, I didn't want to risk destroying them with masking. There I chose a an authentic scheme that has no personal or unit markings. The metal fittings were brush painted with 'Tamiya' Grey Green (XF76). Padding was 'Humbrol' Leather (62) with hightlights of 'Tamiya' Hull Red (XF9). Other metal fittings were 'Mr. Colour' Stainless Steel (213) and 'Tamiya' Black (X18) 'Weathering applied with 'Flory Models' Dark Dirt clay wash. Sealing coat is 'Alclad' Light Sheen (311). Now onto preparing the wings, ailerons, tail plane, rudder and elevators for the lozenge decals, Mike 8 Link to post Share on other sites
Sandbagger 2,257 Posted February 22 Author Share Posted February 22 Hi all, Just a quick update. The 'Aviattic' four colour faded decals have been applied along with the kit decals. The lozenge decals were applied on a white, pre-shaded gloss base coat. The next step it to seal the decals with a clear semi-matte before applying the weathering wash. Then onto pre-rigging the wings, Mike 7 Link to post Share on other sites
Sandbagger 2,257 Posted February 23 Author Share Posted February 23 Hi all, Subtle weathering applied and sealed. As usual I used 'Flory' Dark Dirt fine clay wash and sealed it with 'Alclad' Light Sheen lacquer (ALC-311). So now it's onto some sub-assembly and pre-rigging, Mike 7 Link to post Share on other sites
shortCummins 3,103 Posted February 24 Share Posted February 24 those wings look very nice rgds John(shortCummins) Link to post Share on other sites
Sandbagger 2,257 Posted February 25 Author Share Posted February 25 Hi all, Apart from the cross bracing wires, the landing gear is complete. The lozenge wheel covers were cut out using a 'Thinnerline' circle cutter. I'm now working on pre-rigging, the first of which are the aileron control lines. These are 0.08 mm diameter mono-filament and 0.4 mm diameter tubes, chemically blackened. Turnbuckles are the metal 1:48th scale from 'GasPatch'. Holes of 0.2 mm diameter were drilled through the ends of the upper wing control levers (for the rigging lines). These can't be finished until the upper wing has been fitted. Now onto the rest of the pre-rigging, Mike 2 Link to post Share on other sites
Sandbagger 2,257 Posted February 26 Author Share Posted February 26 Hi all, All of the pre-rigging of lines is now done and ready to be attached to the various parts of the model before assembly starts. The tricky areas were the rudder and elevator, which need to be rigged before assembly starts. All turnbuckles still need their centre section painted, Mike 3 Link to post Share on other sites
Sandbagger 2,257 Posted March 1 Author Share Posted March 1 Hi all, The actual aircraft model is more or less complete now. However, I'm still waiting for the figures from 'Model Cellar' to arrive from the USA. So for now this model completion is hold. A few shots of the fitted 'ProperPlane' propeller and 'ReXx' exhaust. Of all the rigging, the trickiest were the aileron control cables from their levers in the upper wing. So, whilst waiting for the figures, I can start thinking of the next model to start? Mike 3 Link to post Share on other sites
shortCummins 3,103 Posted March 2 Share Posted March 2 15 hours ago, Sandbagger said: Mike wow, I thought the top picture was a "reference" photo very realistic, fantastic job rgds John(shortCummins) Link to post Share on other sites
FZ6 697 Posted March 2 Share Posted March 2 Wow! That has come together in a relative short timeframe and looks stunning. Thanks for sharing, Mark Link to post Share on other sites
Sandbagger 2,257 Posted March 8 Author Share Posted March 8 Hi all, Today the 'Model Cellar' figures finally arrived from The States, so they've been painted now. I'm just waiting for the display case to arrive, hopefully tomorrow. Then I can wrap this one up and post the completed shots, Mike 2 Link to post Share on other sites
Sandbagger 2,257 Posted March 10 Author Share Posted March 10 Hi all, The completed model shots are now posted in the Ready for Inspection thread, Thanks, Mike Link to post Share on other sites
nheather 970 Posted March 10 Share Posted March 10 Wow that’s incredible - that photo of the wheels, if I didn’t know better I’d swear they were full size. Cheers, Nigel Link to post Share on other sites
