Ruskin Air Services Posted May 19, 2021 Author Share Posted May 19, 2021 9 hours ago, tonyot said: The Lanc looks lovely and so does your man cave! The Lego is good too,.... we bought our lad the Millenium Falcon and it graces his bedroom now! Re the nose turret,..... it will look better if you add a horizontal frame line to cross the vertical one,.... for some reason Revell missed this one off! See below; https://www.ipmsstockholm.se/home/avro-lancaster-in-detail/ Cheers, Tony Tony, how did I miss that! Out with the Hannants white decal strip then. I find it puzzling that a kit manufacturer puts so much effort in but still makes silly mistakes 1 Link to comment Share on other sites More sharing options...
stever219 Posted May 19, 2021 Share Posted May 19, 2021 4 hours ago, Ruskin Air Services said: It does Steve, that's the rather pale masking tape I've used. It's bizarre as the white leading edges get to the join of the outer wing panels it Narrows down That’ll teach me to try commenting at stupid o’clock in the evening after a long day. Now you’ve mentioned it I’ve spotted the tape between no’s 3 and 4 engines. As you were! 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted May 19, 2021 Share Posted May 19, 2021 Looking great and the Falcon looks ace, would love one of those. Impressive collection of Dakotas there. Chris 1 Link to comment Share on other sites More sharing options...
Ruskin Air Services Posted May 20, 2021 Author Share Posted May 20, 2021 Well third coat of MSD to the wings and tail: Now with the fuselage spine painted with a little touch up required: Just waiting for the masks for the canopy, model on 11 Link to comment Share on other sites More sharing options...
Thom216 Posted May 21, 2021 Share Posted May 21, 2021 Looking nice in that white/gray scheme. 1 Link to comment Share on other sites More sharing options...
Ruskin Air Services Posted May 26, 2021 Author Share Posted May 26, 2021 Small update, the eduard mask set turned up so for the first time the task of applying and making sure that they're burnished down. I hope after all this they work! Painted and left to dry for their final coat: Model on boys 6 Link to comment Share on other sites More sharing options...
Ruskin Air Services Posted May 28, 2021 Author Share Posted May 28, 2021 Well the Eduard masking worked, so on with all glazing using my trusted glue n glaze: Just waiting for glue n glaze dry in the cockpit and bomb aimer positions. Well it's the eve of another 4 day shift so little time for modelling 😞. Model on boys 11 Link to comment Share on other sites More sharing options...
woody37 Posted May 29, 2021 Share Posted May 29, 2021 Lovely scheme and coming along well. Feeling the need for a white Lanc now, great inspiration Link to comment Share on other sites More sharing options...
TheyJammedKenny! Posted May 29, 2021 Share Posted May 29, 2021 Beautifully done! It looks like this will be very handsome! What are your plans for clear-coating it? Link to comment Share on other sites More sharing options...
bigbadbadge Posted May 29, 2021 Share Posted May 29, 2021 This is looking very impressive with the glazing added . Lovely job. Chris Link to comment Share on other sites More sharing options...
Ruskin Air Services Posted May 29, 2021 Author Share Posted May 29, 2021 14 hours ago, TheyJammedKenny! said: Beautifully done! It looks like this will be very handsome! What are your plans for clear-coating it? An application of johnson's clear on the mid sea grey as the white is gloss and that's according to the Hannants instruction sheet 1 Link to comment Share on other sites More sharing options...
Ruskin Air Services Posted May 29, 2021 Author Share Posted May 29, 2021 7 hours ago, bigbadbadge said: This is looking very impressive with the glazing added . Lovely job. Chris Thanks Chris, Regards Mark 1 Link to comment Share on other sites More sharing options...
Ruskin Air Services Posted May 29, 2021 Author Share Posted May 29, 2021 14 hours ago, woody37 said: Lovely scheme and coming along well. Feeling the need for a white Lanc now, great inspiration I'll be stepping back from building anything that has white surfaces for a while 😬 Link to comment Share on other sites More sharing options...
Ruskin Air Services Posted June 4, 2021 Author Share Posted June 4, 2021 Well it's decal day with the excellent Hannants post war sheet and the common markings from the revell kit. Unfortunately some of the revell walkway decals silvered a little 😬. Then I will seal them in a do some weathering. Model on boys 9 Link to comment Share on other sites More sharing options...
TheyJammedKenny! Posted June 4, 2021 Share Posted June 4, 2021 Ugh! So frustrating. You know what I would do? Take some masking tape and gently remove those walkways, because they'll drive you up the walls. Use a sharp Xacto blade to trim around the roundels. The walkways silvered on my Revell C-54G, and I was so angry I wanted to....At any rate, it took several tries to get them about right, during which I carefully removed, repositioned, and employed quantities of Microset. Anyway, this appears to be a chronic problem with whomever it was who received the tidy contract to supply decals to Revell. I recommend you get yourself a set of black stripes and replace them before you layer on some clear. 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted June 4, 2021 Share Posted June 4, 2021 Oooooo this is gorgeous with the decals on, I am going to have to look at the post war decal sheet now. Great work, I have had issues with Revell decals silvering too. Chris 1 Link to comment Share on other sites More sharing options...
Lewis95 Posted June 4, 2021 Share Posted June 4, 2021 Looks fantastic matey! 1 Link to comment Share on other sites More sharing options...
Ruskin Air Services Posted June 10, 2021 Author Share Posted June 10, 2021 Now in RFI 2 Link to comment Share on other sites More sharing options...
