Phantom726 Posted February 4, 2021 Share Posted February 4, 2021 7 hours ago, RAGATIGER said: Hi there HTH Please post some photos or link Regards Armando The pylons have evolved a lot over the years and are known under different names. In recent years several other nations have adapted the pylon-based solution. Here´s a link to the producer's website: https://www.terma.com/media/362889/pylon_based_ew_solutions_letter.pdf Link to comment Share on other sites More sharing options...
RAGATIGER Posted February 4, 2021 Share Posted February 4, 2021 5 hours ago, Hook said: There's some info on p. 5 of this TERMA brochure, : https://www.terma.com/media/105013/integrated_electronic_warfare_self-protection_solutions_for_all_types_fo_aircraft_-_brochure.pdf Also, see halfway here, under "Pylon Integrated Dispenser". Cheers, Andre Thanks Andre Now I understand those were included on Revells F-16A/B Falcon in 1/72 scale Best day Armando Link to comment Share on other sites More sharing options...
Hook Posted February 4, 2021 Share Posted February 4, 2021 3 hours ago, RAGATIGER said: Now I understand those were included on Revells F-16A/B Falcon in 1/72 scale The earlier PIDS pylons are included, in all RoG new tool F-16 boxings, but not the later "warty" ones in the TERMA brochure. Cheers, Andre Link to comment Share on other sites More sharing options...
Bernd A. Posted February 6, 2021 Author Share Posted February 6, 2021 On 2/3/2021 at 5:18 PM, Phantom726 said: XF-1 is flat black so that would need to be glossed up a bit to represent one of the early blocks with the black nose. XF-54 is close to FS36270 if I recall correctly. That could be an option for the later blocks. Again, tonal variation to the radomes ranged from deep grey to light grey. Here´s an example for ET-204. Same airframe in all the photos - yet multiple shades on the radome: https://abpic.co.uk/pictures/construction-number/6G-1 I do have Tamiya X-1, but I was expecting it to be too glossy for the nose. On closer inspection I do have XF-24 Dark grey as well as possible nose color. So many different nose cones, so much choice! Link to comment Share on other sites More sharing options...
CT7567 Posted February 6, 2021 Share Posted February 6, 2021 On 2/1/2021 at 4:16 AM, Bernd A. said: I can't find any info quickly on different types of wing fuel tanks on f-16.net, but I do have a Revell Belgian F-16 MLU (03905) for comparison, and Heller's fuel tanks are of equal size. So that either means both kits got the fuel tanks wrong, or they're the right ones. Heller's kit doesn't come with a centerline tank, but instead is supplied with an ECM pod, likely the ALQ-119 jammer. Apologies, I was working from memory and should have checked my stash (or Scalemates). The large tanks (370 gal) in the Airfix kit are correct depictions of the production design. It's Italeri (and Testors) whose early F-16 kits include the FSD style. (I believe the original Revell kit - unrelated to the later Revell AG gem you have - also featured the early tanks). Link to comment Share on other sites More sharing options...
Hook Posted February 6, 2021 Share Posted February 6, 2021 25 minutes ago, CT7567 said: Apologies, I was working from memory and should have checked my stash (or Scalemates). The large tanks (370 gal) in the Airfix kit are correct depictions of the production design. It's Italeri (and Testors) whose early F-16 kits include the FSD style. (I believe the original Revell kit - unrelated to the later Revell AG gem you have - also featured the early tanks). Italeri later redid their molds to represent the production wing tanks. However, most kits (Italeri, Fujimi, Hasegawa) feature triangular aft fins - only the RoG mold has the correct cropped ones. Cheers, Andre Link to comment Share on other sites More sharing options...
