shortCummins 3,103 Posted January 28 Share Posted January 28 After completing my Tamiya Spitfire Mk.V tropical and with a view to continue getting me “back up to speed” on the modelling front I’ve delved into the stash and decided on this… HobbyBoss 1:48 Brazilian EMB-314 Super Tucano Having watched a YouTube video by Becker’s Models on his build… https: //www.youtube.com/watch?v=PMJsGOZ3fTI I decided to get the resin pilots he used, I don’t think I’ll be doing her “wheels up” but I liked stuffing a pilot in the Spitfire and as HobbyBoss don’t supply any I’ve order these KASL Hobby figures… For some reason they don’t appear to be available here in the UK? so I’ve ordered them from an Australian outfit BNAModelWorld.com (where I stole the product photos). As these are coming from the other side of the world they may holdup the build but hopefully not for too long. Eduard also have a PE set for the “outside” of the aircraft. This PE set is very nearly the same price as the full kit, and in truth I’m “humming and haring” but their product photos do look good. Eduard used to do a cockpit PE set, no longer available, having looked at it I’m not sure I’d have got that set as the resin pilots would hide most of the detail. The kit has 3 marking options Força Aérea Brasileira (Brazilian Air Force) Fuerza Aérea de Chile (Chilean Air Force) Fuerza Aérea Colombiana (Colombian Air Force) I’ll be opting for the Brazilian version until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 8 Link to post Share on other sites
shortCummins 3,103 Posted January 29 Author Share Posted January 29 As “normal” with aircraft builds this one starts with the cockpit. I’ve ordered a couple of resin pilots & seats which are winging their way from down-under so I’ll be adding them as and when they turn up. So to start I identified the parts I’ll be using and prepared them for some UMP/Stynylrez black primer. I also assembled the front wheel well. Some photo etch is supplied with the kit, I’ll not be using the PE seat belts (unless the pilots don’t turn up) however here is the PE gun sight. These were then given a blast of UMP/Stynylrez black primer. I’ll be starting to add some colour to the cockpit next. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 3 Link to post Share on other sites
Andres Alvarado 75 Posted January 29 Share Posted January 29 HI John! great job !! May I suggest to take a look at this : http://www.avm-maquetas.cl/web/galeria.php?id_galeria=33 Cheers!! Andrés Link to post Share on other sites
bigbadbadge 8,855 Posted January 29 Share Posted January 29 Looking forward to this John. Nice start. Chris Link to post Share on other sites
Shalako 478 Posted January 29 Share Posted January 29 It looks like a promising build! I'm particularly interested to see how well the etched set will "fit" on the exterior of the model, because it seems to be a bit on the thick-side of things. At least, when I look at the photo this is the impression that it gives me. Cheers, Bill 1 Link to post Share on other sites
shortCummins 3,103 Posted January 30 Author Share Posted January 30 15 hours ago, Andres Alvarado said: HI John! great job !! May I suggest to take a look at this : http://www.avm-maquetas.cl/web/galeria.php?id_galeria=33 Cheers!! Andrés Thanks Andrés they look interesting, now if there was a Short Tucano conversion I'd be very interested. 15 hours ago, bigbadbadge said: Looking forward to this John. Nice start. Chris thanks Chris this is my first HobbyBoss kit so it should be "interesting" 15 hours ago, Shalako said: It looks like a promising build! I'm particularly interested to see how well the etched set will "fit" on the exterior of the model, because it seems to be a bit on the thick-side of things. At least, when I look at the photo this is the impression that it gives me. Cheers, Bill thanks Bill I've decided against getting the PE, partly because I agree that it looks too thick and partly because I'm really only interested in a "simple" build and also I'm not sure how much it would enhance the kit as the moulded detail looks nice. best rgds John(shortCummins) 1 Link to post Share on other sites
bigbadbadge 8,855 Posted January 30 Share Posted January 30 2 minutes ago, shortCummins said: this is my first HobbyBoss kit so it should be "interesting Hi John I built their Spitfire Vb and the details and fit were great but they squashed the Cockpit and the spine of the fuselage is all wrong. Not sure about other HB kits as I have not bought anymore after that . Chris 1 Link to post Share on other sites
Pete in Lincs 15,549 Posted January 30 Share Posted January 30 John, This is a bit modern! It will be an interesting build to follow. I agree about the etch. All those panels should be flush with the skin, so the plastic would need cutting out. Too much fuss for me. Don't forget the nose weight! And the usual HB trick of fudging details. Suspect everything! I'm already wondering what the purpose is of that large access panel on the RH side above the aft wing root. Compared with the Shorts Tucano, it would allow access to the rear of the hydraulic pack. Something that would have been welcome back then! We had to change a Hyd reservoir once. It took forever due to lack of access. And, IIRC, there was a 32mm nut holding it in place. We had to get a special order open claw socket just for that one job. 1 Link to post Share on other sites
heloman1 2,924 Posted January 30 Share Posted January 30 Great start, I too am beginning to think the PE detail sets are becoming too expensive. I recently purchased the KH Huey and then the Big Ed set. The bottom dropped out again! Of our SA Rand so the Ed set cost me 50% more than the kit. I'm sure I'll not be using all of it!!! Colin 1 1 Link to post Share on other sites
shortCummins 3,103 Posted January 30 Author Share Posted January 30 2 hours ago, bigbadbadge said: Hi John I built their Spitfire Vb and the details and fit were great but they squashed the Cockpit and the spine of the fuselage is all wrong. Not sure about other HB kits as I have not bought anymore after that . Chris Hi Chris I "normally" build 1:48 aircraft, mainly Eduard or Tamiya kits but I have a couple of Revell & Airfix in the stash, I know that Eduard often re-box other manufactures but finding "reasonable" kits is always a joy, especially if they're from someone I've not built before. Its what this forum is really good about seeing others builds and thinking, that's a nice kit I wonder if I could build it to that standard? inspiration and challenges at the same time. One of the Revell kits is a re-boxed Hasegawa Phantom FGR.2, £70 for the Hasegawa £30 for the Revell kit, go figure!? I'm lucky enough to have some 1:32 kits, the Tamiya Spitfire that I'm building my way back to, a couple of Wingnut Wings kits, shame they went bust, and the Meng Dr.1 Triplane which is the Wingnut kit but with poorer instructions. I've just ordered the Das Werk Ju EF-126/EF-127, just because its looks an "interesting" aircraft and the kit was very reasonably priced at under £40. There's one kit that I will build this year, it's my favourite aircraft, the Lukgraph DH-89 Dragon Rapide, it's also the most money I've spent on a kit (£120) but it was the first aircraft I went on, 1960's pleasure flight along the Cornwall coastline, there's something about the Rapide that captures the elegance of a bygone age. rgds John(shortCummins) 1 Link to post Share on other sites
shortCummins 3,103 Posted January 30 Author Share Posted January 30 1 hour ago, Pete in Lincs said: John, This is a bit modern! It will be an interesting build to follow. I agree about the etch. All those panels should be flush with the skin, so the plastic would need cutting out. Too much fuss for me. Don't forget the nose weight! And the usual HB trick of fudging details. Suspect everything! I'm already wondering what the purpose is of that large access panel on the RH side above the aft wing root. Compared with the Shorts Tucano, it would allow access to the rear of the hydraulic pack. Something that would have been welcome back then! We had to change a Hyd reservoir once. It took forever due to lack of access. And, IIRC, there was a 32mm nut holding it in place. We had to get a special order open claw socket just for that one job. Ha Ha Pete it is a bit modern isn't it, I nearly got a nose bleed! for some reason she makes me think of what the Mustang would be if she was designed 40 or 50 years later. "normally" I wouldn't mind a bit of faffing with the PE, but I'm really just trying to get back up to speed so that I can tackle my 1:32 Spitfire and get back to the Stuka kit-bash, I've had one or two or twenty ideas on how to move that build forward so hopefully they'll be back on the bench in the not too distant future. I do think she's a lovely looking aircraft, I'd like to build a 1:48 Shorts version, the RAF had some very nice looking schemes. rgds John(shortCummins) 1 Link to post Share on other sites
shortCummins 3,103 Posted January 30 Author Share Posted January 30 1 hour ago, heloman1 said: Great start, I too am beginning to think the PE detail sets are becoming too expensive. I recently purchased the KH Huey and then the Big Ed set. The bottom dropped out again! Of our SA Rand so the Ed set cost me 50% more than the kit. I'm sure I'll not be using all of it!!! Colin thanks Colin I'm a big fan of adding extra detail, either scratch building or PE, but it's getting increasingly difficult to justify spending the extra. Having said that I've got a project for a 1:48 Eduard Spitfire and I've purchased the Brasin cockpit and engine, I also need(?) the radio compartment, so far I've spent more on this 1:48 version that the Tamiya 1:32 Spitfire cost me! rgds John(shortCummins) Link to post Share on other sites
shortCummins 3,103 Posted January 30 Author Share Posted January 30 Well my “first cock-up” (I’m sure it won’t be the only one) for this build was that I’d used UMP/Stynylrez GLOSS black primer when I’d meant to use the “normal” stuff. I’m not sure that it’d make too much difference in the long run however, I didn’t want to take any chances so I gave the relevant bits a coat of UMP/Stynylrez black primer, this time I checked the bottle twice to make sure it was the correct one! HobbyBoss suggests the main colour for the cockpit and instrument panel should be dark gull grey however, I found this on the interweb… To my eyes the IP looks to be more of a blueish grey so I’ve used H306 gray FS36270 For the gull grey I used H305 gray FS36118 Wheel wells should be aircraft grey, I’ve used XF-19 sky grey as it’s the nearest colour I’ve got and by the time a panel line wash and weathering it’ll be close enough. Next will be painting some of the detail in the cockpit. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 5 Link to post Share on other sites
bigbadbadge 8,855 Posted January 30 Share Posted January 30 2 hours ago, shortCummins said: There's one kit that I will build this year, it's my favourite aircraft, the Lukgraph DH-89 Dragon Rapide, it's also the most money I've spent on a kit (£120) but it was the first aircraft I went on, 1960's pleasure flight along the Cornwall coastline, there's something about the Rapide that captures the elegance of a bygone age Would have loved to have got that one too, but my savings are awaiting the Special Hobby 32nd Westland Whirlwind at the mo. Chris 1 Link to post Share on other sites
arfa1983 103 Posted January 30 Share Posted January 30 This is a super nice little kit. Make sure you add plenty of nose weight. I ended up drilling out the nose and spinner to put lead sinkers in right at the end. I had to glue the spinner in place after this. It really needs a lot and there isn't much space in front of the cockpit. Perhaps some extra weight anywhere in front of the main landing gear can help! 1 Link to post Share on other sites
shortCummins 3,103 Posted January 30 Author Share Posted January 30 1 hour ago, arfa1983 said: This is a super nice little kit. Make sure you add plenty of nose weight. I ended up drilling out the nose and spinner to put lead sinkers in right at the end. I had to glue the spinner in place after this. It really needs a lot and there isn't much space in front of the cockpit. Perhaps some extra weight anywhere in front of the main landing gear can help! thanks arfa1983 I think I read somewhere that it needs around 60 grams for the nose weight? I plan to use the external fuel tanks and I'll add some weight in the front of them also. rgds John(shortCummins) 1 Link to post Share on other sites
shortCummins 3,103 Posted January 31 Author Share Posted January 31 Panels were picked out with various greys Tamiya XF-20 medium, XF-63 German, XF-82 ocean and a couple of panels in XF-1 black. the floor was scuffed-up a bit and buttons, knobs and/or switches were highlighted by dry-brushing with XF-16 flat aluminium. Various buttons were then painted black, red, yellow or red brown. To tone-back the silver, the edges were dry-brushed with XF-66 light grey I think this might be a little too colourful however once the pilots are crammed in I’m not sure how much of it will be seen. This was then given a coat of aqua gloss in preparation for a weathering wash. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 3 Link to post Share on other sites
Biggles87 7,874 Posted January 31 Share Posted January 31 Hi John, I've always liked the look ( and sound ) of the Tucano, so I'll tag along if I may. The cockpit looks good to me, modern ones do tend to be quite colourful. Looking forward to more. John 1 Link to post Share on other sites
exdraken 10,845 Posted January 31 Share Posted January 31 Nice project, and a good start that is! 1 Link to post Share on other sites
shortCummins 3,103 Posted January 31 Author Share Posted January 31 59 minutes ago, Biggles87 said: Hi John, I've always liked the look ( and sound ) of the Tucano, so I'll tag along if I may. The cockpit looks good to me, modern ones do tend to be quite colourful. Looking forward to more. John thanks John I've had a problem with finding suitable cockpit photos as there's different versions of the aircraft, obviously the Brazilian "original" but also a couple built under licence in the 'States and here in the UK (Northern Ireland I believe). Each version appears to have different instrument layouts and I'm guessing they'd be different depending on what role the aircraft would be used for, a trainer might be different to a ground support role? Anyhow artistic licence has been liberally abused! 48 minutes ago, exdraken said: Nice project, and a good start that is! Thanks exdraken she's a smart looking aircraft and as I said earlier suggests to me that she's a grandchild or great grandchild of a P-51 Mustang best rgds John(shortCummins) 3 Link to post Share on other sites
shortCummins 3,103 Posted January 31 Author Share Posted January 31 This was then given a coat of aqua gloss and “magic acrylic wash*” was used to help pick-out the panels and buttons etc. *D o o g’s magic wash recipe: colour of choice: 3 drops (I used XF-69 NATO black) water: 80% aqua gloss: 20% For details watch D o o g’s YouTube video… www. youtube.com/watch?v=0pRyuCKu_VU Approx’ start at 10 thru 14 minutes on how to make and use it Some of the supplied decals were used for the IP dials. To help them settle I first used Micro Set and then after around 20 minutes or so I applied some Solvaset to really hammer the decals down. However, the “smaller” switches were painted rather than use the decals as the buttons were quite raised and the decals would have struggled to fully/correctly conform and I thought it would be easier to paint. Next I’ll be finishing the cockpit… until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 4 Link to post Share on other sites
bigbadbadge 8,855 Posted January 31 Share Posted January 31 Ips and cockpit tubs look great. Cracking job John. Chris 1 Link to post Share on other sites
shortCummins 3,103 Posted February 1 Author Share Posted February 1 Joysticks detail painted. Both instrument panel coaming were dry-brushed with XF-63 German grey …and then the gun-sight base was very lightly dry-brushed with XF-16 flat aluminium to pick out the fasteners and edges. I’ll attache the gun-sight once the cockpit subassembly and IP coaming(s) have been fitted to the fuselage. The cockpit tub, joysticks and coamings were given a coat of aqua matt. Next I’ll be preparing the weapons and landing gear as I can’t finish the cockpit until the pilot figures arrive from down-under … until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 2 Link to post Share on other sites
bigbadbadge 8,855 Posted February 1 Share Posted February 1 Looking good John, the joystick looks great with the buttons picked out. Chris 1 Link to post Share on other sites
shortCummins 3,103 Posted March 1 Author Share Posted March 1 João and Paulo, the two pilots, arrived from down-under, very efficient they arrived a couple of weeks after I ordered them, I was expecting a month or two! Unfortunately João and Paulo needed some surgery to get them to fit and seat down properly. The pilot who sits in the rear seat needed a smaller shoe size and both seats needed “thinning” so that they could slide down into the tub. Having enjoyed Deanflyer’s Bruntingthorpe Buccaneer build… I had to have the chap in the rear waving, such a good idea I thought I’d steal it! Next I’ll be painting the pilots… until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 6 1 Link to post Share on other sites
