US Navy Late 70's Hi Viz Schemes
The Tamiya 1/48 F-14A calls for AS-16 to be used for the grey.
What would suitable alternative's to this be?
I have Tamiya XF-19 Sky Grey & Tamiya XF-20 Medium Grey.
Is there a ratio to mix these 2 to get the correct shade?
Should the final clear coats be Gloss, Satin, Matt or somewhere in between?
If you have to use Tamiya, I'd go for a mix of the XF-20 with white. There are many brands who do the right shade straight from the bottle though. I'd go for a satin coat but you won't be wrong with a flat or slightly more glossy finish either. They started glossy, but some time at sea and it all becomes flat sooner or later.
If you're limited to using paints from Tamiya's X/XF range, then I'd recommend adding some XF-55 Deck Tan to the XF-20/white mix as suggested by Pete - perhaps up to equal measure with the other two paints. To my eye, Light Gull Grey is a pale, brownish grey and it needs that extra brown/yellow tint.
For what it's worth, here are two other mixes using Tamiya paints (collected a long time ago from sources now forgotten, apologies for the lack of attribution):
36440 Light Gull Grey (link goes to the Colorserver rendition)
*Mix 1 -- XF-19:1 + XF-80:1 + XF-2:2
*Mix 2 -- USN LIGHT GREY -- XF-19:2 + XF-2:1 (add a tiny drop of yellow)
Many thanks.
My only reasoning for the Tamiya paints was I have those to hand.
I'll have a look and see what else is available and if anywhere has stock.
