85sqn 1,983 Posted January 20 Share Posted January 20 Hi folks, I'm just spraying a Tiger Moth with this. To me it looks too mustardy, has anyone got any thoughts or observations about this particular paint? Is it accurate? Link to post Share on other sites
FinnAndersen 553 Posted January 20 Share Posted January 20 What did you use as undercoat? Link to post Share on other sites
85sqn 1,983 Posted January 20 Author Share Posted January 20 I'm using grey but I've used it over other lighter colours before and black. A good base for yellow is pink which I've used for a stearman but with this Xtracolor even the tin lid colour looks mustardy. I know the depth will build with more coats but I'm not sold on it. Link to post Share on other sites
85sqn 1,983 Posted January 20 Author Share Posted January 20 Just to provide some form of evidence here is Xtracolor on the left and Xtracrylix on the right: https://flic.kr/p/2ktYYGy Link to post Share on other sites
FinnAndersen 553 Posted January 20 Share Posted January 20 15 minutes ago, 85sqn said: I'm using grey but I've used it over other lighter colours before and black. A good base for yellow is pink which I've used for a stearman but with this Xtracolor even the tin lid colour looks mustardy... I'm using X011 on a regular basis, and have found out the hard way that it can be a bit difficult to get a nice even result where the undersurface does not show itself too much. My current favourite technique is to base with white, shake or stir the X011 extremely well, thin carefully and then apply one or two thin coats of it. This leads to a multiple of coats that I'm not too fond of, but what can you do? Are the paint new or old? Perhaps you should try with a newer tin. HTH Finn Link to post Share on other sites
spitfire 1,631 Posted January 20 Share Posted January 20 I tend to go for X106 Insignia Yellow, stir for 2 minutes with a Badger Stirrer, thin 50:50 with XDTT, airbrush at 20psi straight onto clean and polished plastic, not tried the X11 yet but the lids look the same. Cheers Dennis Link to post Share on other sites
85sqn 1,983 Posted January 20 Author Share Posted January 20 34 minutes ago, FinnAndersen said: I'm using X011 on a regular basis, and have found out the hard way that it can be a bit difficult to get a nice even result where the undersurface does not show itself too much. My current favourite technique is to base with white, shake or stir the X011 extremely well, thin carefully and then apply one or two thin coats of it. This leads to a multiple of coats that I'm not too fond of, but what can you do? Are the paint new or old? Perhaps you should try with a newer tin. HTH Finn I've found it sprays beautifully, absolutely no trouble with laying it on with the airbrush. Lovely smooth finish, I'm just not sure about the accuracy of the colour. 1 Link to post Share on other sites
Work In Progress 3,632 Posted January 20 Share Posted January 20 Every time I use Xtracrylix I find I have to do far more stirring than with any other paints to make the colour come out right. I now give it a minute with a thin L-shaped piece of wire in a Dremel and that seems to do it. Link to post Share on other sites
Denford 731 Posted January 20 Share Posted January 20 Or use a small Allen Key Link to post Share on other sites
spitfire 1,631 Posted January 20 Share Posted January 20 4 hours ago, 85sqn said: I'm just not sure about the accuracy of the colour. Hi got carried away there, so I looked in the RAFM book British Aviation Colours of WW2 and there is only one yellow listed there, this does not answer your question but it did lead me to do some further digging and I came across this discussion all about RAF yellow which you may find useful. Cheers Dennis Link to post Share on other sites
303sqn 538 Posted January 20 Share Posted January 20 Original Gas Detector Paint was formulated using cadmium lithopone yellow pigment which the specification of July 1939 stated was to approximate BS 381 (1930) No 55 Lemon. IIRF it is the same colour that artists call Cadmium Yellow. Link to post Share on other sites
