KeithR 176 Posted January 19 Share Posted January 19 (edited) I’ve decided after building two Airfix kits in succession (Spitfire and P-40) that I would branch out and build my first Special Hobby kit. It’s the 1/72 scale Folland Gnat F Mk.I “British Single Seaters” No. SH 72322:- These are the options in the kit:- I’m not sure that any other than the grey/green camouflaged versions actually flew. Perhaps there are some experts out there in Britmodellerland who could confirm or disprove that. In any case, I’ve decided to go with the kit option of XN326 with the pointy radar nose. It’s not quite as pretty as the round-nosed one (XM740), but it’s a bit more interesting and it will provide a nice contrast with my Red Arrows Gnat T.1. That aircraft I made about 35 years ago from the old-tool Airfix kit. I have another identical kit to build as that option in a few days when I've finished this one . So, I’ll build this one:- The box open-ended box contents. Sprue A:- Sprue B:- The transparencies:- This spine transparency isn’t used in my option:- Neither are these resin parts:- Hopefully I’ll make a start in the next day or so and will keep you posted. Before I go, I’d like to buy some MRP paints for this. Hannants don’t stock them. I can only find a couple of places that sell them online but they are unknown to me. Would any of you Britmodellers have any recommendations for a trustworthy supplier of MRP paints online? Thanks in anticipation and happy modelling, Keith. Edited January 26 by KeithR Title change. Was Folland Gnat F1. 3 Link to post Share on other sites
Sidders 76 Posted January 19 Share Posted January 19 Hi Keith, To purchase MRP paints, look no further than HM Hobbies. They offer a first class service and I wouldn’t use anyone else. Link as follows:- https://www.hmhobbies.co.uk/ Hope this helps. Best regards, Mark 1 1 Link to post Share on other sites
KeithR 176 Posted January 20 Author Share Posted January 20 12 hours ago, Sidders said: To purchase MRP paints, look no further than HM Hobbies. Hi Mark, That's just what I wanted to know. I'd spotted them and was about to give them a try. Thanks and best regards, Keith. 1 Link to post Share on other sites
KeithR 176 Posted January 26 Author Share Posted January 26 I’ve made a start on the Gnat with the cockpit:- I’ve found that you have to be careful with part 03 to glue it carefully in the pocket in the cockpit side wall. The lower and back edges must be aligned with the pocket edges. See arrows:- The reason is that the rear bulkhead is sandwiched tightly between part 03 and the nose undercarriage bay part 31 which can’t be adjusted too much. I glued part 31 into the fuselage half with the cockpit interior and the other fuselage half both in place but not glued. After it dried I then glued the cockpit interior to one half of the fuselage and held it in place with the other fuselage half taped but unglued. This ensured that it all fitted when I came to glue the two fuselage halves together. The jet pipes were glued in. I didn’t learn anything from my experience with the P-40 and used too much Tamiya Extra-Thin cement and too much pressure. It all went a bit banana shaped and I had to do quite a bit of sanding to get it all to fit:- As with the Airfix 1/72nd P-40, alignment of the fuselage halves wasn’t great so I had to remove most of the locating pins. The fuselage halves glued together:- Despite fettling the jet pipes I still ended up with a nasty gap requiring filling near the back end:- The instrument panel ended up looking like it should be a bit further forward. We’ll see what it looks like when I put the canopy on:- I had to remove the locating pins on the wing-mounted air data probe. I don’t think the probe itself looks all that great. I might make one out of brass tubing. The difficulty is that the real probe is parallel to about half way then tapers down towards the front. I’ll do a bit of experimenting. I ordered some MRP paints from HM Hobbies and they came the next day. Excellent service. Thanks for the recommendation Mark @Sidders. Well that’s it for now. Happy modelling. Keith. 4 Link to post Share on other sites
Sidders 76 Posted January 26 Share Posted January 26 No problems, Keith. If you haven’t used them before, MRP paints are a joy to spray. Just keep the air pressure low and make sure you use in a well ventilated room, ideally with a decent spray booth. Gnat coming along nicely BTW. Cheers, Mark 1 Link to post Share on other sites
