Supermarine Spitfire Mk.Vb (A50125A)
1:48 Airfix
The Spitfire is perhaps one of the best known and well-loved aircraft in Britain, and deservedly so for its work in the Battle of Britain alongside the doughty Hurricane.  It thrived in its point-defence role, and shone during its finest hour, then on through many versions and types to the end of WWII and beyond.  The Mk.I was predictably the first in-service type, and sported eight .303 Browning machine guns, and by the time hostilities commenced in 1939 many of them were using the blown canopies that gave the pilot a better field of view with less likelihood of smacking his head against the glazing.
The Mk.I was superseded by the Mk.II, Mk.III, and then the Mk.V due to the introduction of the Focke Wulf Fw.190 by the Germans that gave the British Spitfire pilots a nasty shock when they first encountered it.  The Mk.V gave them the extra horsepower to cope with these pugnacious little fighters, and so the tactical leapfrog continued to the end of the war with the Mk.22/24 being the last mark of the Spitfire with cut-down fuselage, bubble canopy and the monstrous power of the Griffon engine in front of the pilot with all the torque steer he could handle.
The Kit
This is a reboxing of Airfix’s recent Mk.V that has been given new decals and box art to depict it as a couple of different aircraft, and leaves the tropical filter parts in the box.  It arrives in a standard Airfix red-themed top-opening box, with five sprues of light grey styrene inside, a clear sprue, decal sheet and the spot-colour instructions that have a colour painting guides on the rear pages.  It brings with it all the detail you would expect from a recent Airfix tooling, and the knowledge that if you want more detail, the aftermarket industry will be there to help you out if you don’t fancy the DIY option.  It shares a lot of parts with the rebox of the Mk.Ia we reviewed recently, which is to be expected due to their common heritage.
Construction begins with the cockpit interior, which consists of two inner skins that are decorated with the usual items we all probably know and recognise instantly.  The pilot's chair is made from an L-shaped seat with separate sides, that is mounted on an armour panel, with the adjustment lever on the right side.  The frame behind the pilot has moulded-in lightening holes that you can either fill with wash or drill out at your whim, then add the seat frame and head-armour, finally fitting the seat to the frame on its four corners.  The rudder pedal assembly goes through a section of the wing spar and has separate pedals that you should leave off if you are intending to fit the pilot, and the control column with separate top is planted in the middle of the sub-assembly.  The instrument panel is glued to the next frame forward and has a nice decal with just the dials printed and an outline to help locate it correctly on the panel.  A little decal solution should help that to settle down into the recesses nicely.  The compass attaches to the rear of the panel, and is then inserted into the port cockpit side along with the rudder pedal assembly and a lever, allowing the two halves to be joined and a front firewall bulkhead to be fitted to close in the foot well.  Then the seat assembly and next frame to the rear are slotted into the grooves, and your optional pilot with his two separate arms can be placed in if you’re using him.  Before inserting the cockpit tub you need to paint the interior of the fuselage above the waistline, and remove a small part of the sill if you are posing the canopy closed.  Then it slips inside the starboard fuselage half along with an oxygen bottle, and the port side is joined up together with an insert in front of the canopy, which is where the fuel tank filler is found.  You can also cut out the access door on the left side of the fuselage, bearing in mind that you have a new door on the sprue so you can be a bit brutal in removing the plastic.
The wings are built next, and the full-width lower wing has two circular bay walls fitted along with a section of the front spar, before the rear spar and front extensions are also attached to stiffen the wing.  The tops of the gear legs are inserted into recesses in the bay, then it’s just a case of popping on the upper wings and moving on to joining them to the fuselage after making sure you’ve fitted the light in the belly first.  The elevator fins are slotted into the tail at 90o to the rudder fin, then the flying surfaces are added with any deflection that you might wish to portray, remembering that some smart-alec will always complain if you don’t also offset the control column and rudder pedals too.  The ailerons are also separate and can be posed with the same caveats applied.  Under the nose the chin-insert is glued in, noting the Dzuz fastenings there and on the side cowlings.  They could possibly stand a very slight flatting down to look less like semi-flush donuts, but maybe that’s just me.  Under the leading edge of the wing there is a two-part intake, then the square radiator bath with textured radiator panels and tubular oil-cooler are added to their recesses, with optional open or closed cooling flaps on the rear of the radiator.
The tail wheel was still fixed in the Mk.V, so slots into a hole under the tail, and you then have the choice of wheels up or down.  In-flight a small portion of the wheels can still be seen, so Airfix have provided a slim wheel to put on the doors so that a realistic look is obtained.  For the wheels down option, you have separate struts and doors, which slot into the top-sections already within the bay and have a pair of tyres with separate hubs added, making sure that the slightly flattened section is facing the floor.  A pair of scrap diagrams show the correct angles from the front and sides to help with positioning.  A T-shaped pitot probe goes under the wing, then the triple-fishtail exhaust stubs are glued into the nose and the long-fairing equipped cannons, joined by a one-piece triple-bladed prop, two-part spinner, and three parts that permit the prop to spin if you don’t flood it with glue.  You then have a choice of open or closed canopies, using a three-part assembly plus rear-view mirror for open, and two-part plus mirror for closed.  You did remember to paint and fit the clear reflector gunsight, didn’t you?  The open option also allows the door to be posed down, which as previously mentioned uses a new part.  There is an aerial mast behind the cockpit with small teardrop light, with a little look at your references showing where to string the antennae wires.
Markings
There are two decal options in the box, one of which is an American airframe with early stars painted over the roundels, the other in British roundels but with an American at the helm.  From the box you can build one of the following:
  • ‘Buckeye Don’ Flown by 2nd Lieutenant Don Gentile, 336 Fighter Squadron, USAAF, RAF Debden, North Essex, England, 1942
  • Aircraft flown by Sqn.Ldr. Eric Hugh Thomas, No.133 (Eagle) Squadron, RAF Biggin Hill, England, April 1942
Decals are by Cartograf, which is a guarantee of good registration, sharpness and colour density, with a thin gloss carrier film cut close to the printed areas.
Conclusion
A welcome reboxing of this recent tool from Airfix, and the American decal options should appeal to our colonial cousins from across the pond.  Detail is good, and you’ll be left with a number of spare parts for the parts bin.
Highly recommended.
Review sample courtesy of
Lovely kit but if building with the undercarriage down, the undercarriage is a serious problem. I suggest that you assemble the whole leg before closing up the wings
Trevor
