I just finished the second wing, left side. Same as the other, first glued 3 pieces of wing together, let them set up a bit then
pulled the top up until the kerf closed. I then added glue and tape. I also added some slivers of card stock to some gaps
near the rear flaps that wouldn't close, same as other wing. When it was set up I checked it with the same template flipped
over with the correct angle of 175 degrees written on this side, NOT 5 degrees! LOL. Now to putty it up.---John
Wings done and sanded. They measure to about 1/2 mm with each other, angle on them looks good.---John
There's been big discussions about the dihedral of the revell kit, but I don't know if they did get right or very wrong. In flight when under load there is obvious dihedral but on the ground and fully fueled the dihedral doesn't seem too apparent as in these two photos:
Lancaster at rest
Lancaster at rest
 The revell kit is going to be my next build as a post war ASR3. Model on boys
Thanks, that's a lot flatter than I was told. Maybe Revell isn't that far off. I have the engine added to the nacelle but not closed up yet.---John
There were I'm sure some comparison images somewhere showing the Revell  Airfix and Hasegawa kit dihedral.   Looking good so far .
Great work
Chris
Lancaster at rest
Lancaster at rest
Having looked into this recently (to help decide whether to go for the Revell or Airfix kits!) I'm of the view that the apparent difference on the ground is due to the angle of viewing compared to most in flight photos.  Seen directly head on, the dihedral is clearly visible on the ground, but few pics are actually at that angle.  In the pics above, the plan view taper of the wing combined with the angle of the aircraft is creating an optical illusion and appearing to straighten out the dihedral.  Comparing this view below (which is almost looking directly along the axis of the fuselage) to inflight images, there doesn't appear to be that much, if any, difference:
Avro_Lancaster_bombers_nearing_completio
This is actually AV Roe's own production line as opposed to one of the other builders & from the Lancaster wikipedia page.  There's also a more head on shot of S for Sugar at the RAF museum here:
https://www.rafmuseum.org.uk/cosford/whats-going-on/news/chelsea-fc-adopts-raf-museum-lancaster-bomber/
Great work
Chris
Probably this review article of the Airfix kit: http://www.hyperscale.com/2013/reviews/kits/airfixa09007reviewmd_1.htm
