cobraleader 53 Posted January 16 Share Posted January 16 G'Day All, Another RAAF themed build. An old Airfix 1/72 Spitfire Vb. Painted the cockpit with a black base, White Marbling and Gunze H56 Interior Green. Used thin plastic strips to fill the gaps in the wing/fuselage joins. 4 Link to post Share on other sites
bigbadbadge 7,947 Posted January 16 Share Posted January 16 Ahh yes, this was my first ever Spitfire kit. Good to see all together very quick. Are you rescribing the panel lines or leaving them off? Chris Link to post Share on other sites
Paulaero 712 Posted January 16 Share Posted January 16 Pure nostalgia that box lid ..... 1 Link to post Share on other sites
cobraleader 53 Posted January 18 Author Share Posted January 18 and moving along quickly. Putty applied, canopy masked 2 Link to post Share on other sites
Eric Mc 2,575 Posted January 18 Share Posted January 18 One of my favourite kits. It may be a bit basic but it is pretty accurate. I presume it will now be deleted from the range with arrival of the new tool MkV. Link to post Share on other sites
cobraleader 53 Posted January 18 Author Share Posted January 18 I think its in their classic range now ... I'm looking forward to the new Mk Vc tooling. I have an old Vc that is basically a Vb with extra wings for the Vc. Wings are beautiful tooling with recessed panel lines, yet the old Vb parts are slightly raised panel lines ... Link to post Share on other sites
Graham Boak 6,779 Posted January 18 Share Posted January 18 The old Mk. Vc had a pretty awful wing: far too thick because it was based on a misunderstanding of an error with the Mk.Vb at the wing root. (The Mk.Vb wing has a funny little kink up near the root to match with the fuselage.) The new Mk.Vc is far superior to both. 2 Link to post Share on other sites
cobraleader 53 Posted January 23 Author Share Posted January 23 slowed down a bit on the build. Finally black based it and white marbling 1 Link to post Share on other sites
cobraleader 53 Posted February 21 Author Share Posted February 21 G'Day All, Slowed up a bit with production. Finally put down some paint. Paint Scheme is British European Ocean Grey/Dark Green over Medium Sea Grey. Ended up using Gunze H335 Ocean Grey, H309 Dark Green and H306 Medium Sea Grey. Painted the undersides and free hand painted the camou scheme on top Spinner and fuselage band are painted Gunze H31 White Green. Started sealing the finished paint work with Humbrol Gloss varnish, however it started reacting the the underlying paint (same problem when using Humbrol Satin and Matte varnish as well). Ended up with cracks over the wings. I don't know what i'm doing wrong - this has happened on several other models and even over Humbrol Enamels. Instead of stripping and redoing the paint, I decided to go back to the good ol' trusted Gunze and Tamiya clear coats. I found that it covered the cracks, had to do some minor paint touch ups due to the cracking going through to the primer coat. Decals are DKDecals. These are beautifully printed decals. They laid down nicely and had no problems with being coated with Mr Mark Softner. 1 Link to post Share on other sites
