Cheshiretaurus 2,180 Posted January 16 Share Posted January 16 Im planning to build the shuttleworth collections Spitfire Vc AR501 from the Airfix new tool 1/72 Spitfire Vc, I belive this kit has the parts to make a clipped wing version with a normal air filter. What I also need is a six stack exhaust for it, does anyone havecany recommendations for an after market exhaust? Thanks Mark CT Link to post Share on other sites
Wez 5,988 Posted January 16 Share Posted January 16 Both Eduard and Quickboost do 6 stack exhausts for a Mk,IX, any of those would be suitable - as seen here on a quick Hannants search, you just need to choose the appropriate one, fishtail or rounded. Link to post Share on other sites
Cheshiretaurus 2,180 Posted January 16 Author Share Posted January 16 Thanks I was wondering if a mk IX would be appropriate for a mkV. I'll have a look. Link to post Share on other sites
Wez 5,988 Posted January 16 Share Posted January 16 30 minutes ago, Cheshiretaurus said: Thanks I was wondering if a mk IX would be appropriate for a mkV. I'll have a look. The main difference between the Merlin fitted to a Mk.V and a Mk.IX is the supercharger on the rear of the engine, the cylinder block and thus the exhaust fittings are the same (at least dimensionally). It looks like AR501 has the rounded style. 1 Link to post Share on other sites
Work In Progress 3,644 Posted January 16 Share Posted January 16 1 hour ago, Cheshiretaurus said: mk IX would be appropriate for a mkV Yes in this case (not for most in-service examples). The bore spacings are the same for all Merlins and Meteors. Link to post Share on other sites
gingerbob 3,153 Posted January 16 Share Posted January 16 So I can put Spitfire exhausts on my Meteor? 4 Link to post Share on other sites
Wez 5,988 Posted January 16 Share Posted January 16 6 minutes ago, Work In Progress said: Yes in this case (not for most in-service examples). Can you explain why? Link to post Share on other sites
Work In Progress 3,644 Posted January 16 Share Posted January 16 Because most in-service Mark V lived and died before being retrofitted Link to post Share on other sites
Cheshiretaurus 2,180 Posted January 16 Author Share Posted January 16 11 minutes ago, gingerbob said: So I can put Spitfire exhausts on my Meteor? Would look like a menacing meatbox. Think he meant the RR Meteor engine a derivative of the Merlin for AFVs https://en.m.wikipedia.org/wiki/Rolls-Royce_Meteor Link to post Share on other sites
Graham Boak 6,943 Posted January 16 Share Posted January 16 Also, few Mk.Vs were employed in a role where it mattered. Methinks if you put Spitfire exhausts on a Meteor, they wouldn't make the Cromwell go even 5mph faster. Might run into other problems too - the Germans would certainly hear them coming. 2 Link to post Share on other sites
Work In Progress 3,644 Posted January 16 Share Posted January 16 8 minutes ago, Graham Boak said: Might run into other problems too - the Germans would certainly hear them coming. Yes, and they weren't exactly quiet to start with. (There are as far as I know no running Cromwells but here's a running Comet, so for these purposes much the same thing). Link to post Share on other sites
Wez 5,988 Posted January 16 Share Posted January 16 17 minutes ago, Work In Progress said: Because most in-service Mark V lived and died before being retrofitted Agreed, I wondered if there was a mysterious technical reason. 8 minutes ago, Graham Boak said: Also, few Mk.Vs were employed in a role where it mattered. I can't think of many examples although the one that does spring to mind is the Mk.Vs used by the US Navy gun spotters around D-Day Link to post Share on other sites
Graham Boak 6,943 Posted January 16 Share Posted January 16 I'd rule out those too. The odd few MPH really didn't matter in the slightest for what they were doing. Some of the ones in Italy might count, which is where some were indeed seen, but even then they were mainly fighter-bombers so it didn't matter. Link to post Share on other sites
Wez 5,988 Posted January 16 Share Posted January 16 10 minutes ago, Graham Boak said: I'd rule out those too. The odd few MPH really didn't matter in the slightest for what they were doing. Some of the ones in Italy might count, which is where some were indeed seen, but even then they were mainly fighter-bombers so it didn't matter. Third picture down in this link. Link to post Share on other sites
stevehnz 11,113 Posted January 16 Share Posted January 16 37 minutes ago, Graham Boak said: Some of the ones in Italy might count, which is where some were indeed seen An earlier one was the well know mount of Kiwi Ace Rosie Mackie who apparently had his Vc so modified in North Africa & went so far to retrieve the 6 stub exhausts when his machine crash landed for fitting to its replacement. Steve. Link to post Share on other sites
MACALAIN 101 Posted January 16 Share Posted January 16 Rolls Royce engine also used for Vosper MTB and recue boats Alain Link to post Share on other sites
gingerbob 3,153 Posted January 16 Share Posted January 16 (edited) I'm not sure the point of this side discussion. It is well known that some late Vs had the 6-stack exhausts fitted- it is somewhat associated with LF.Vs, but there's no hard correlation. IF your Mk.V has 6-stack exhausts fitted, then yes, "Mk.IX" ones should be appropriate. Whether a set intended for one kit directly fits another is a separate question, but I wouldn't think it would be too hard to make it work. Edited January 16 by gingerbob 2 Link to post Share on other sites
fishplanebeer 271 Posted January 16 Share Posted January 16 Not forgetting that the Seafire III also had the later style 6 exhausts fitted to their single stage merlin engines along with some IIc's as well, and I've even seen a pic of a hooked Seafire Ib similarly attired. Regards Colin. 2 Link to post Share on other sites
Work In Progress 3,644 Posted January 16 Share Posted January 16 (edited) Mark I G-AIST / AR213 used to have six stacks a side, when in the Battle of Britain movie, when owned by Victor Gauntlett, and for at least a while afterwards. Highly visitble too is the four blade prop, of course Edited January 16 by Work In Progress 1 Link to post Share on other sites
Graham Boak 6,943 Posted January 16 Share Posted January 16 I think the point of the digression was not how many examples can be found of Mk.Vs with 6-a-side exhausts, but why was there not more of them. I would discount warbirds completely: until recently they didn't have a lot of choice in what working exhausts were around, and they see no benefit from them as they never explore the outer limits of the performance envelope. The basic answer to the question is that the cost of implementing this was outweighed by the lack of value. There were simply more important things to spend money, time and effort on than semi-obsolete fighters that could carry out less demanding roles perfectly happily as it was. In the case of the Seafire, there was a genuine need for whatever performance they could get. 1 Link to post Share on other sites
72modeler 6,760 Posted January 16 Share Posted January 16 4 hours ago, Work In Progress said: Yes, and they weren't exactly quiet to start with. Bet the Germans didn't know whether to look up or down when they heard one coming! Now, if our M4 Sherman had only been fitted with a Merlin.... Mike 1 Link to post Share on other sites
Work In Progress 3,644 Posted January 16 Share Posted January 16 2 hours ago, 72modeler said: Now, if our M4 Sherman had only been fitted with a Merlin Well, any Sherman of mine would have to be R-975 powered even though the GAA and diesels were probably better tank engines Link to post Share on other sites
stevehnz 11,113 Posted January 16 Share Posted January 16 Get a lung full of that! I've long wondered how they got on starting these, they could hardly turn it over on the prop to cleat the lower cylinders? Steve. Link to post Share on other sites
ColFord 426 Posted January 17 Share Posted January 17 USN VCS-7 on D-Day, what photos are around show their Spitfire Vbs with a mix of the three a side and six a side exhausts across the various aircraft they used. Examples of six a side: VCS-7 1 by Colin Ford, on Flickr VCS-7 by Colin Ford, on Flickr 26 Sqdn RAF and 63 Sqdn RAF who were also part of the Spotting Pool were equipped with Spitfire Vb at the time, from what few photos of them there are from this timeframe, some with, some without. Looking at the AM78 for the Spitfire Vb issued to them at the time, some had been back into MU and contractors before being issued to the Squadrons before D-Day with various mods being implemented before issue. Link to post Share on other sites
Work In Progress 3,644 Posted January 18 Share Posted January 18 On 1/16/2021 at 11:21 PM, stevehnz said: Get a lung full of that! I've long wondered how they got on starting these, they could hardly turn it over on the prop to cleat the lower cylinders? Steve. I don't have a Sherman manual but there are several ways to mitigate the risk. I imagine they would motor it over on the starter before switching the ignition on. This can be combined with a slipper clutch on the starter to prevent it pushing over a hydraulic lock with enough torque to bend, and thereby shorten a con-rod (as on the inverted Gipsy Queens on the Rapide I used to dally with). Another likely measure was one or more drain taps in the low points of the exhaust manifolds, as I had on my Yak. 1 Link to post Share on other sites
