Mumbly 134 Posted Thursday at 12:49 AM Share Posted Thursday at 12:49 AM (edited) This is a trip back to my youth. I bought 3 non-running S1/KH250 when I was 17. I managed to piece together a working KH250 and this was my first bike after ditching the L-Plates. It also started a journey where I owned a KH400, KH500 and an H2 750 before I moved onto the Suzuki stink pots which in turn culminated in an RG500. Of the Kawasaki triples, the 250 was my favourite, the 400 was more powerful but not as much fun, the 500 kept breaking down (ignition issues) and the 750 just wanted to kill me. This is also my first Hasegawa bike kit, and it is a beauty! The build and fit so far are superb and the separate parts are going to make the build a lot easier. The plan is to build it as my KH looked, so mine was Candy Cobalt Blue and completely stock, albeit with flatter handlebars. I also have the Hobby Design PE kit for it and I am going to add the bits that are missing, as I still have the Haynes Workshop Manual, so this will include the auto-lube cables and a stab at the wiring loom too amongst other things. So far, I have made a start on the cylinder barrels. The fins have been thinned to remove the joins and the crankcase has had the access way for the oil pipes opened up and the moulded engine bolt removed and replaced with an alloy tube. This shows the before and after on the barrels, the right is without any work: This is the crankcases: From the box: Oil lines are some MFH fine brown pipes with thin wire threaded through so that I can shape them to route along the crancase below the carbs, the bolts are MasterClub 1.0mm resin bolts through some 1.2mm tube: And this is them placed for dry-fit purposes. The molded bolts are removed and drilled out, also the original holes for the clutch and oil lines are plugged so I can use thinner wire than what comes with the kit: This is the case halves assembled with the replacement bolt: I also have been working on the wheels. There is a lot of chrome in the kit, and if you want some sprue-shots I can post them. I have removed the chrome from the hubs by creating a plasticine well for keeping the bleach away from the rim. I also am planning to next write a separate WIP on the methods that I used. But this is the rear wheel before, during and finished for comparison. These are the wheels with the hubs stripped of chrome, just dry fits: I started by removing some of the spokes and replacing with 0.5mm piano wire with 0.8mm aluminium tubes cut to 1mm lengths for the furrels, these are on the left side. The hubs have been painted with AK Xtreme Metal Matte Aluminium: Just steel spokes and now quite flimsy: Finished: I have some tyre valves on the way, so that and the brake and rear sprocket need to be added at a later stage. Front wheel is next and then if the weather allows, some paint on the engine parts. Thanks for looking. Tony Edited Thursday at 12:51 AM by Mumbly 4 1 Link to post Share on other sites
NigeG 108 Posted Thursday at 08:35 AM Share Posted Thursday at 08:35 AM Those wheels look superb, I have a few kits with wire wheels that I am avoiding because the spokes don’t look correct. im gonna have to have a go and what you have done. Link to post Share on other sites
Mumbly 134 Posted Thursday at 01:45 PM Author Share Posted Thursday at 01:45 PM 4 hours ago, NigeG said: Those wheels look superb, I have a few kits with wire wheels that I am avoiding because the spokes don’t look correct. im gonna have to have a go and what you have done. Thanks Nige, I am going to write up the ways that I have tried after I finish the front wheel as a seperate thread, which I hope others can add too, especially on the car side as that is something that I have not tried. You are 100% right on the look of the molded spokes in my opinion too. The ones that I have worked on are from this kit and Ayoshima are both really well molded, but they look just too thick, plus the steel finish of piano wire also sets them off regardless the finish on the rim and hub. This is the Ayoshima rear without the tyre which I will also go through, it was done differently and was not as simple as the way that I am now using. Both make a big difference compared to the OOB. Tony Link to post Share on other sites
keefr22 12,994 Posted Thursday at 06:08 PM Share Posted Thursday at 06:08 PM Never been a biker (I was dangerous enough on a bicycle!) but I do like classic bikesand good models of them - & this is shaping up to be a cracker! Shall follow along if you don't mind! That wheelis excellent! Keith Link to post Share on other sites
Mumbly 134 Posted yesterday at 12:25 AM Author Share Posted yesterday at 12:25 AM 6 hours ago, keefr22 said: Never been a biker (I was dangerous enough on a bicycle!) but I do like classic bikesand good models of them - & this is shaping up to be a cracker! Shall follow along if you don't mind! That wheelis excellent! Keith Thanks Keith, welcome aboard. While I marvel at the bikes of today, I quite like the simplicity of early Japanese bikes as well as the European bike of that era and before. Link to post Share on other sites
