B-17G Flying Fortress Dinghy (4414 for HK Models) 1:48
1:48 CMK by Special Hobby
HK Models’ new medium-sized 1:48 B-17G, not to be confused with their own gigantic 1:32 kit has been around for a while now, taking over the mantle from the old Monogram kit.  The Flying Fortress often flew over large tracts of water, and like most WWII aircraft it had a dinghy pack oboard in case it went down far away from land.  Being a tad larger than a fighter, and with 9+ crew, a larger dinghy was required, which was housed in the raised cockpit portion of the fuselage behind the mid-upper turret on the port side.  CMK resin sets arrive in a clear clamshell pack with a yellow card insert behind that protects the parts within and keeps the instructions free from harm.
There are three parts in the pack, all on their own casting blocks.  Installation is simple, requiring the modeller to remove a small rectangular panel in the port side of the fuselage, which is picked out in pink on the instructions.  The dinghy bay slots into the aperture from behind, then the packed-up dinghy is sides inside, making sure to paint the bay green and the dinghy yellow before you do.  The bay door is wafer-thin, and attaches to the pour block along its hinge edge, with little clean-up needed there, or for that matter on either of the other two parts, which have their contact patches hidden away after construction.
Highly recommended.
Review sample courtesy of
