1/48 - Douglas B-26K Counter Invader by ICM - released - new boxing Q2 2022
Homebee
  • 3 weeks later...
On 19/09/2021 at 19:10, Thomas V. said:
Saw your reply late, I have first B boxing, and from the outset sonething looked wrong nose wise, compared to Promodeler kit its almost 6 mm short, now some did mention that Promodeler kit has too long gun nose, compared to what sources I have  ( Squadron Signal in Action as well as few online souces without confirmed provenance)
all mentioned above show discrepancy of 4-5mm, when comparing real aircraft pics to ICM kit- in my view it screams out.
It is a late reply but I have taken some measurements as I have the Monogram and ICM kit and also the Paragon and Ozmods nose and guess what the nose is too short!!
It is an mere three millimeters short on the gun section but the shape is pretty much correct.
The Ozmods and Paragon were correct in lenght but shapewise a bit iffy.
The wrong length on the Monogram is in the fuselage section in front of the cockpit.
I found the shape of the panels on the ICM kit a bit strangelooking but this is because they are too short in length which is logical if you have a short nose and try to fit the same detail in a shorter area.
I measured it against a scaled picture of a direct side view of the nose on IF679 Special Kay.
Solution is simple by adding a 3MM thick plasticard shim and rescribe the panel lines and relocate the vents....
Noses are a difficult and a frustrating item and this why a lot of people do a nose job nowadays 😁
cheers, Jan
cheers, Jan
Others (on the B-26 facebook group) have measured the nose to be of correct length (within 10th of millimeters), and they were judging from the real deal, not just kits and resin parts. I think it goes to show that you cannot be certain unless some kind of proof is posted (it was posted in the fb group).
Jens
Does anyone have, or where can I get just the props for this plane? Doesn't have to be ICM either. I want to convert an early B-26 into a VIP plane and want the square tip three blade props. Or would there be something else to use?
One other question, is there a good 1/72 B-26K?
Jens
If you have the link that would be appreciated..
They probably have measured it correctly but what have they measured! Just the nose or tip to cockpit window?
What I did in measuring is the ICM kit against a good picture and if you have the correct outline on the rest of the airframe (this case an ICM K Invader) and all looks correct except for the nose lenght i tend to believe it to be a pretty accurate outcome (and not within the 10 of a mill.)
I do know that pictures can cropped wrongly as well so there can be a discrepancy (uncertainty)😁
Those other noses weren’t my reference in measuring but they do match up with that picture in lenght.
Seen the Icm A-26 and B26-b build up but the nose still looks off to me.
If am wrong then I’ll be wrong but this was my outcome with the information a have😉
Thanks a lot  for the input Jens this is always appreciated.
my best regards, Jan
The only one Im aware of is the older Italeri B-26K.
https://www.scalemates.com/kits/italeri-1249-b-26k-counter-invader--104122#
a build review.
https://modelingmadness.com/scott/viet/us/b26.htm
Edited by Corsairfoxfouruncle
Flat ended resin blades are included as single pieces in the OZ Mods 1/48 A-26K conversion intended to replace those on the Revell/Monogram propellor hubs.
I have a set of the blades going spare if you would like to try , pm mailing address if you would like me to send them.
Jens
As per this Hyperscale thread, the FB info is a bit out of date and now provisional pending further data: https://www.tapatalk.com/groups/hyperscale/icm-1-48-b-26b-k-8-gun-nose-t526837.html
Jon
Jon
Thank you Jon as this is a very interesting read, it seems that most had the same findings as I had but the actual measure data says something different so there maybe more going on whats tricks us in seeing things being off shape!
Very  interesting😁
cheers, Jan
  • Homebee changed the title to 1/48 - Douglas B-26K Counter Invader by ICM - released -new boxing in December 2021
  • Homebee changed the title to 1/48 - Douglas B-26K Counter Invader by ICM - released - new boxing in December 2021
  • 4 weeks later...
Just saw somebody on FB who had moved the wing rearward on this.
But according to this
A26_comparison_small
The wing and canopy are in the right place.
Must say I've no idea where Sergey got his 'reference' drawing from though.(DOH'...it says in the drawing...🙄)
Edited by Bozothenutter
Idiocy
  • Confused 1
  • Homebee changed the title to 1/48 - Douglas B-26K Counter Invader by ICM - released - new boxing Q2 2022
  • 3 weeks later...
Of interest in Hyperscale: ICM B-26K Invader - An Analysis of 8-gun Nose Dimensions
https://www.hyperscale.com/2022/b26knosejh_1.htm
It's also rumoured Russian producer Vector Resin (https://www.facebook.com/Vector-Resin-1921724494743386) is preparing a nose correction set for this kit.
V.P.
Edited by Homebee
