Denford Posted January 4, 2021 Share Posted January 4, 2021 Too late if it's already happened! But if learnt from Britmodeller - where else- then use an old soldering iron to cut either adjacent sprue, or detach the said part from the sprue 1 Link to comment Share on other sites More sharing options...
malpaso Posted January 4, 2021 Share Posted January 4, 2021 A good option if the smàll part looks hard to access around the sprue, which is also handy for not stressing clear parts - heat your cutting blade over a candle flame and, er well there's no other way to describe it, the blade will cut the plastic "like a hot knife through butter". 1 Link to comment Share on other sites More sharing options...
dogsbody Posted January 4, 2021 Share Posted January 4, 2021 I use a broken CMK saw blade, stuck into a pin vise, to carefully saw through the sprue gate. Chris 1 Link to comment Share on other sites More sharing options...
Shin Posted January 8, 2021 Share Posted January 8, 2021 you can also throw money at the problem, the Godhand ($$$$), Dispaie ($$$), or higher end Tamiya ($$) side cutters can provide a "hot knife through butter" cut instead of a "snap" cut. I ended up getting a pair of Dispaie (from eBay seller) after reading a bunch of reviews and was still surprised at how easy it cuts through the sprues attachments and doesn't "ping" small pieces away. I figure a tool used for an action I do hundreds if not thousands of times each kit it was worth investing in. Link to comment Share on other sites More sharing options...
