bootneck Posted January 3, 2021 Share Posted January 3, 2021 I've seen some nice looking models on the web but the format quoted is .max. Can anyone advise whether that format can be imported into Fusion 360 and converted to STL for printing? cheers, Mike Link to comment Share on other sites More sharing options...
Bonhoff Posted January 3, 2021 Share Posted January 3, 2021 https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/sfdcarticles/sfdcarticles/What-file-formats-does-3ds-Max-import-and-export.html#:~:text=MAX file format is a,compatible version of 3ds Max. Does this help? IanJ Link to comment Share on other sites More sharing options...
st george Posted January 3, 2021 Share Posted January 3, 2021 Hi Mike, .max is the file extension for Autodesk 3ds Max. I don't have the program but did find this for you to watch. Cheers David 1 Link to comment Share on other sites More sharing options...
bootneck Posted January 3, 2021 Author Share Posted January 3, 2021 Hi David, thanks very much for this. I shall watch it tonight. cheers, Mike Link to comment Share on other sites More sharing options...
xvtonker Posted January 11, 2021 Share Posted January 11, 2021 Hi Mike, There are a number of online converters available. For max to stl conversion I use this one. https://anyconv.com/max-to-stl-converter/ It also converts other formats into stl, obj, etc. I also use MeshMixer which allows you to resize & tweak your models then export them as stl files. XVTonker 1 Link to comment Share on other sites More sharing options...
ampthetex Posted January 18, 2021 Share Posted January 18, 2021 Yes, just do a search on google, there are loads of free online converters. Link to comment Share on other sites More sharing options...
