Starting to make some headway on a scratchbuild of the Norman Fieldmaster in 1/48 scale.
DSC03099
Started off with the framing for the fuselage buck...
DSC03105
Then the buck almost ready for vacforming.  Shown alongside the Valom 1/48 Britten Norman Island for a size comparison...
DSC03137
Then after vacforming.  Split into front and rear sections for size practicalities.  Front fuse moulded left/right halves per convention. Rear fuse moulded top/bottom - which is going to assist with building the interior as we see later...
DSC03335
Then here' s the tail in a jig  - with fuse under way in the background. Lego has the big advantage of being resiliently 'square' which comes in handy for modelling.
DSC03338
And here are he basic component parts dry-fitted. Interior is being installed in the lower half with clear section to go over the top. The big plus of separating front and rear fuse halves (apart from moulding limitations) is that I can basically build the cockpit 'pod' as a hermetically sealed unit - without having to worry about plastic swarf, sanding detritus etc making their way inside and ultimately clinging like limpets to the canopy interior.The wings have separate 'trailing' flaps and ailerons which will add a bit more depth.
And here's the scheme I will do - G-NACL on evaluation in Australia 1988 https://www.airliners.net/photo/Untitled/Norman-NAC-6-Fieldmaster/2513794  (a Daniel Tanner copyright photo on Airliners.Net)
  • Like 16
Random thoughts:
Oi, that's some proper modelling there!  😎
The plans look like it's got a P-38 greenhouse on it.
Lego is an amazing jig-making material.
Looking forward to seeing more!
Brilliant! That's a great subject which is much larger than I expected - I'm pretty sure I remember seeing the Fieldmaster in an 'Observers' book when I was young. Very nice vacform work, Ian - what medium did you make the mould out of? P38 body filler?
Jon
Edited by Jonners
This looks very interesting,  the aircraft looks slightly unusual yet pleasing to the eye.  I like the way you have tackled the fuselage too .
Great work.
Chris
Lovely work so far and an interesting subject. I too find that a horizontal split can make interior detailing much easier, when I’m scratch building.
2 hours ago, Jonners said:
... what medium did you make the mould out of? P38 body filler?
Jon
The skeleton frame is sheet styrene and the filler is standard 2-pack panel repair 'bog' from the auto spares shops  (ie a golf ball of filler with a pea of hardener).  This filler is 25% styrene and when hard is easily carved/sanded etc. Usually takes about 4 putty runs to get it to mouldable state - but it goes off in <30 mins so pretty quick...
An unusual subject, and one I'd never seen before. It looks great so far. I'll pop back from time to time.
A bit more progress on the Fieldmaster. 'Canopy' has been fixed to the bottom half of the fuse and first coat of Milliput to blend. The tail assembly was fixed beforehand as I wanted to ensure the cockpit interior was fully sealed before wet sanding etc.
DSC03344
Have then moved onto wings. Have 'tabbed' each wing root to assist with fixing - and also manufactured a styrene spar with the correct dihedral.
DSC03341
Then a bit of a dry fit to make sure it goes together as the manufacturer intended.  Happy with that. The wings look like they have a really narrow chord - but the flaps and ailerons hang off the back of this as pretty much independent appendages?  Rear fuse at this point hadn't had it's first sand (the first photo above is post sanding, post first primer)
DSC03340
And with dry fit passing the test - the wings have been transferred to the Lego land facility for gluing to the front fuse pod - with some Lego-LAM assistance.  Need to do some detail work at front end of cowling but thinking that'll be easier to do once I have some reference points to reference to (ie the wings).
DSC03343
Over the next week I expect I'll get to joining the front and rear sections.  It's a slightly unconventional approach but all driven by need to keep the cockpit interior free of muck...
  • Like 12
Some more progress - engraving of panel lines, cleaning up of front end, fitting/blending fillets for the tail. And sorting out a robust tab system to join the front fuse section to the rear fuse section - which you can see in the pic below..
DSC03354
And then back to the lego jig yard for aligning and gluing the fore/aft sections. With some assist again from the Lego LAME's
DSC03355
Have also scratchbuilt the flaps and ailerons which will be a late fitment after paint. Next steps are blending this new join, then onto undercarriage, vents, intakes etc.  This photo below of G-NRDC is shared from Chris England Flickr page (1986 Farnborough)
Norman NDN-6 Fieldmaster G-NRDC Farnborough 2-9-86
First off - great subject, awesome modelling skills! I really love quirky aircraft like this, so it's right up my street. Can't wait to see how it progresses. I hope you won't mind me posting some (not very good images) from Farnborough. These show the (water scoop?) being demonstrated, and the Fieldmaster being flown two-up.
Farnborough (12)
Farnborough (13)
Farnborough (14)
Farnborough (24)
Farnborough (75)
Apologies for the quality: I had a Zenit SLR, which took great photos on sunny days but not-very-good photos at any other time :)
Excellent reference photos thank you!  The under side shots in particular.   Cheers.
  • 4 weeks later...
Progress continues - blending in the wing/fuse join. Adding lumps and bumps.  The latest milestone has been fitting the main undercarriage - heavily spatted, heavily engineered in 1:1 .  And then the big test - will it be a tailsitter?? There's a LOT of plastic behind the pivot point.....
DSC03465
Ha! Yes!  There's no shortage of space to put lead in the nose - so have not skimped. The flaps/Ailerons have been scratched - but are not shown here.
DSC03463
Next step - getting to the point where I'm going to mask off the canopy - that'll be a significant step in making it look like the real thing. And plenty more detail to be added - struts, hopper detail, engine vents etc.
Impressed with this, I recall the FM from the day but wow, I didn't realise how big it was, from that Farnborough shot above, it was a monster. What chance did it stand against hoards of Agwagons & the like.
Steve.
My thoughts exactly! Ginormous.
And super modelling too!
Regards,
Adrian
  • 1 month later...
Progress has been slow - but a bit of a milestone today - finally masked the cockpit and proceeded to undercoat.  Step one, given the absence of any canopy framing lines - was to create a 'positive' mask (vs negative?). ie apply masking lines where you KNOW you want canopy framing to go.  the advantage of this is that you can quickly check the symmetry of what you're doing and make minor adjustments without actually having to commit the mask.  I am using Tamiya tape - cut to the required dimensions of the canopy frame..
DSC03511
Then (obviously) fill in the gaps with the ACTUAL mask.  A sharp scalpel. Thin strips initially. Then infill with chunkier bits. Easier than you might think ...
DSC03512
Then remove the 'positive' mask leaving what remains ready for painting.   This bit dead easy!  Just run over all the masks remaining to make sure they're bedded in properly. And wing struts added just because they needed to be.  A bit of Contrail strut profile used to good effect
DSC03516
And some Tamiya rattle cat fine grey primer (great stuff!). The (overlength) flaps and ailerons have been taped on just to show the characteristic wing chord of the Fieldmaster.  Next steps are hopper entry and exit details.  - and some photo-etch hangers for the flaps/ailerons/spray bars, and PE atomisers for the spray bars (thanks entirely to a friend who's "in the know" about custom photo-etching!). A little bit of a lead time for these - so don't expect it finished next week!
DSC03518
