I have been wanting to start this for some time but having read and watched only one build through to completion, it seems that its quite an undertaking to complete.
Because of the issues I thought that I would build the support vehicles first as I probably wouldn't want to build such vehicles  if the Lancaster was going to become a bind.
However, having virtually completed the AEC 6 x 6 refuelling bowser it time to start the beast . . .
 . . . and others vehicles completed for the planned diorama
I suppose I have had the advantage of hindsight of other builds so I am able to start with the knowledge of what is required.
I have attached a list of corrections required of the HK model, a number are personal choice and I dare say to some modeller(s) the kit is acceptable in representing the finest allied heavy bomber.
HK Lancaster fault/correction list (in no particular order) Jan. 2021
Cockpit floor removal as to high 👍
Pilots seat height and seat base in-correct 👍
Pilots armour needs replacing/re-shaping
Pilots Control column to short
Flt. Eng. Panel, remove, shape and thin down kick panel 👍
New flight Eng. seat required
Cockpit rail cut back for IP to fit
Replacement IP with AM Instrument panel
Bomb-aimer bulkhead 7 sink marks 👍
Rear bomb bay bulkhead has 3 viewing windows, Should be 2 👍
ASI position Starboard side fuselage to be eliminated 👍
Dinghy stowage in port wing, upper wing removal 👍
Landing lights in starboard wing beneath removal 👍
Wing tip lights Rearmost
Wing tip fitment (5 thou- top)
Flap detail missing ‘OOO’ top & bottom sections
Flaps additional struts needed
Propeller blades need turning
Cabin heater openings in front leading edge of inner wings section
Exhaust covers (shrouds) to large & need re-sizing 👍
Engine cowlings  removal of panel lines 👍
Engine radiator flap opening, personal choice 👍
Engine rad post-war version, needs wartime type 👍
Reshape inner rad vent, square top 👍
Undercarriage to high, needs shortening
Undercarriage main legs have 'holes' - need filling 👍
Ailerons and brackets, ribbed and bracket re-shaping
Ejector stubs in one-piece main wing
Ejector marks in undercarriage doors 👍
Ejector marks in bomb doors 👍
Ejector marks in bomb-bay rack 👍
To many bomb positions front section of bomb-bay 👍
Remove U/C ‘Non-retraction bars’
Rear entry doorstep wrong 👍
Front turret fairing top section broken (at point of delivery)
Front turret base Sink marks x 5 👍
Front/Mid-upper/Rear turret casings (drill outs)
Mid-upper turret fairing requires ‘blending’
Rear turret doors absent
Rear turret front Perspex removal – my choice of aircraft
Rear turret centre (gunners feet) personal choice
Cockpit framing required ? personal choice
Canopy Escape Hatch framing (additional frame removal ?)
Main wheel hubs need drilling (Resin type obtained)
Tail wheel needs strengthening, personal choice
Tail-plane – 2 tops – 2 bottoms split 👍
👍👍👍 indicates issue resolved   :thumbsup:
60”    fuselage roundel . ‘ 47.5mm’
102”  wing roundel . . . .‘80.75 mm’
My choice of aircraft is the last one lost flying out of RAF Station Grimsby in Lincolnshire . . .
There have been numerous photos and reviews of the sprues so unless somebody wants to see specific parts i shall just dive in and start the build, not necessarily in the order of the instructions  . . .
For me personally, this will be the ultimate Lancaster kit and as such I shall endeavour to produce the best I can.
It will be time consuming and no doubt there will be little progress at times but please bear with me . . .
I am looking forward to putting the plastic together
Ian
Edited by Mancunian airman
  • Like 31
Hi Ian , love your bowser ! , just what my " parked " Lanc . needs , it`s got the Iconicair tractor & trailer backed under it . Both mine came in the same box  too ,
 nearly needed a fork truck ! . If you are  going to tackle all your listed corrections , then more power to your elbow. The pilots seat can be made right with a few
razor saw cuts . All the " best " with them ! .
        Don .
This should be an epic journey, what an impressive kit.
Dennis
        Don .
Thanks Don
I'm looking forward to the challenge 👍
Hello,
Any particular reason this is under the ‘discussion’ section and not ‘work in progress’?
No axe to grind - just wondering.
  • Confused 1
Hi Ian - I'd love to tag along on this one.  I've opened a window to let some fresh air in / measured a good 2 metre distance to position my chair / popped a new filter into my mask - it is difficult to munch on popcorn whilst wearing a mask :popcorn:  but a straw in the beer makes that easy enough to slurp on :beer:
Good luck with this mate - I'll cheer along from a safe distance - Steve
Awesome!
Will watch with interest.
The work you'll do here will be a great reference for others brave enough to follow..
I think Im going to tackle a nose section first and see how I get on.
Scooby
I do like to display my aircraft with other bits just to bring in some other points of interest . . .
I was thinking that I would never build such vehicles after the Lancaster because so many others have said what a chore the Lancaster is to build . . .
 I intend also to have a diorama board (8' X 4') . . . to display the vehicles and the 32nd scale Nissen hut 🤔
Will there be room for a control tower Ian? ;)
A beast of a model and that’s some correction list. I’m never going to build a Lancaster ( well never say never) but will follow with interest.
Marklo
I believe the kit was around Nine years in its development but its hard to imagine why so many errors ?
I appreciate that there are some actual molding limitations but so many things could have been put right . . .
Ian,
Happy New Year to you - what a project! Will watch with avid interest,
Roger
Do I have double vision or is that not 2 Lancs in that big cardboard box?:D
Whats the plan for the other one?
I am looking forward to this as I have one to do and much to learn beforehand as my Lanc knowledge is limited so any tips, warnings or advice as you go along will be more than appreciated. Class is sitting upright and paying attention.  Questions at the end of the lesson please.
Where to start  . . . the box comes compact with sprues
The comprehensive instruction book containing 44 pages, I will photo each page as I build to point out amendments etc
Some of the after-market bits, my choice again to improve the overall appearance.
Sadly the aircrafts instrument panel is just a molded representation of the dials, there is no decal to place upon it
Just to give you an idea of the size of the fuselage, this is it on my shelf measuring a full 25 inches and excluding the bomb-aimers nose blister
Research over many years has resulted in the superb book
and the aircraft profile . . .
The aircraft was one of two lost from 100 Squadron based at RAF Station Grimsby in Lincolnshire during a sortie to Nuremburg 16/17th March 1945 making it the last aircraft lost flying from the airfield.
The crew comprised:
Pilot: F/O George Dauphinee RCAF
F/Eng: F/Sgt.Mervyn Jefery RAF
Nav: F/O Bruce Douglas RCAF - POW
B/A: F/O William Vale RCAF
W/Op: P/O Roy Bailey RAF - POW
Mid-gun: William Harvey RCAF
Rear gun: Lyle Bedell RCAF
I knew both Bruce and Roy, I have their stories of the night the aircraft fell to the guns of a night-fighter.
The aircraft ND644
Its going to be a journey  . . .
Ian
  • Like 16
John
Pull up a seat, there will be a lot to see . . .
I have recently purchased a new bomb-aimers blister to give me an option of an aircraft that didnt have the 'oo' in the nose blister.
The second blister in the kit is a shallow version, usually seen on Mk. II's but it was seen on a few Mk.I & III's . . .
Ian
I scratch builds lot and it’s really really easy to introduce errors unless you’re being very strict with yourself. I also reckon that some companies are all about time to market/cost rather than accuracy. Then there are cases like the Airfix fairey battle where the kit was tooled off actual fairey battle blueprints, except they were for the early prototypes which differed substantially from the production model.
And I must add, personally I get quite a sense of satisfaction from getting a good model out of a mediocre/inaccurate kit.
Edited by Marklo
40 minutes ago, Marklo said:
 there are cases like the Airfix fairey battle where the kit was tooled off actual fairey battle except they were for the early prototypes which differed substantially from the production model.
Wouldn't have been a problem if it'd been based on actual prototypes: the drawings provided were those of early design studies.
I entirely agree about the fun to be had: but whether it always justifies the effort is another matter.  Sometimes it just results in the kit getting shelved unfinished.  (Hello, Revell Halifax.)
With all those fixes, changes and refinements it looks like more fun than the average kit.  Have you estimated the time it will take, beginning to end?
I'm not sure I'd be too confident trying one that big without a dedicated workshop and a door with a lock on it.
Of those I have seen being built, best estimate is a year of the example seen on Youtube by 'Model Nerd'
The top R. H. corner indicates one of eight so all his videos can be viewed, click to view his list, it gives some idea of the complexity and size of the completed model . . .
I have seen a couple of other examples but no time frame given . . .
For my time frame Ian , my first one with all opened up / hanging down took six weeks , the second one on the stand/flying with full crew , five weeks .
But I`m the old guy with nothing much else to do . My lap top workbench is only eighteen inches by sixteen , but the big uns like the Lancs & B 17s were
built with all the parts  like fuselages , tailplanes , wings as seperate models , only coming together after painting ( apart from the sticky-out bits ). The
main paint/airbrushing is done in my storeroom with the windows open at each end .
One " hollow laugh " today , I was spraying the parts for the 1/12th Italeri Alfa Romero roadster I`m building , started with sunshine coming in the window ,
finished with snow coming in , oh boy ! .
                                                               Don .
  • Haha 4
