Corsairfoxfouruncle Posted December 30, 2020 Share Posted December 30, 2020 Hello everybody... As the A-4 Scooter STGB is coming up in the not to distant future. Im looking to build an A-4K, the base kit is the Hasegawa A-4F most if not all the mods look to be doable but my major roadblock right now is the K’s vertical tail. It is taller and squared off compared to a standard E/F. Im looking for any info, blueprints, line drawings, or schematics on the height of the vertical tail. Is it the same as the later OA-4M tail without the sensor package on top, or is it different ? Ive got most of the other mods already lined up but any info will help. Dennis Link to comment Share on other sites More sharing options...
Giorgio N Posted December 30, 2020 Share Posted December 30, 2020 (edited) According to the D&S volume it is the same tail as originally used on the A-4M, where for originally I mean before the addition of the ALR-45 fairing. When the fairing above the fin was added, the leading edge was extended further out at the top, resulting in a kinked line instead of a straight one. The fairing also covers part of the original tail surface with the result that the rudder is slightly shorter. Personally from looking at pictures I believe that on the A-4K and M without fairing the rudder remained the same of the earlier models, it is only the leading edge of the tail that was extended. I would probably just draw a straight line from the rudder and get the height of the new leading edge section from there. At least this is what I intend to do on a similar project. Edited December 30, 2020 by Giorgio N 1 Link to comment Share on other sites More sharing options...
gingerbob Posted December 30, 2020 Share Posted December 30, 2020 Also, might the "right" cap be in the kit? I'm pretty sure I remember (assuming 48th) that they give at least two styles. Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted December 30, 2020 Author Share Posted December 30, 2020 6 hours ago, gingerbob said: Also, might the "right" cap be in the kit? I'm pretty sure I remember (assuming 48th) that they give at least two styles. Painfully I had the Hasegawa Kahu boxing in 1/48th years ago. I built as an “E” and gave the Kahu bits a new home in Paris. Im working with the 1/72 “E/F” kit, and looking at parts tree diagrams i don't think so. Though there may be a possibility but wont know until Friday when the kit arrives. Link to comment Share on other sites More sharing options...
coneheadff Posted December 30, 2020 Share Posted December 30, 2020 I have the Gekko Graphics decal sheet and it has all the infos you need. http://www.kitreview.com/reviews/a4gkdecalreviewbg_1.htm I will make a scan of the main instructions explaining the differences between an early and late Kiwi Skyhawk and it also mentions all the parts you need. Alex 2 1 Link to comment Share on other sites More sharing options...
Fredag Posted December 31, 2020 Share Posted December 31, 2020 Not much help to your question, but the 'K' fin will be the same as the 'H' fin used on the Isreali Skyhawks as that was what was on the assembly line at the time. Also the Hasegawa 1/72 A-4E/F Skyhawk has an over length fuselage, its actually longer than their later more accurate TA-4J. The stretch seems to be throughout the fuselage, making it somewhat overscale. the wings appear to be ok and were used in the later TA-4 kit. 1 Link to comment Share on other sites More sharing options...
Greg B Posted January 2, 2021 Share Posted January 2, 2021 @Calum he used to fix the real thing and is building a couple at the moment 1 Link to comment Share on other sites More sharing options...
coneheadff Posted January 2, 2021 Share Posted January 2, 2021 Here we go... Don't get confused by things crossed out. I did it for my build, so I wouldn't forget it. Let me know if you need a higher resolution. Alex 1 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted January 2, 2021 Author Share Posted January 2, 2021 5 minutes ago, coneheadff said: Here we go... Kiwi Skyhawk That helps a lot, Thank you. Link to comment Share on other sites More sharing options...
LDSModeller Posted January 2, 2021 Share Posted January 2, 2021 Hi Folks, Few notes to correct missing info from Gekko info above The Red Dot (option 2) was only worn when the A4K's arrived in New Zealand, as that was what was painted on the A4K's at the Douglas Factory in ConUS (RNZAF Official - RNZAF Museum- Used with Permissions) RNZAF T-A4K over Yosemite National park prior to deliver note Plain Roundel (no fern) RNZAF T-A4K - Plain Roundel The Red dot then had the "Silver Fern added (after May 1970), before the Kiwi Roundel was adopted by the RNZAF circa Nov/Dec 1970 per links below RNZAF A4K - Fern Leaf Roundel RNZAF A4K - Fern Leaf Roundel -1 Also The RNZAF A4K's arrived and lived with straight refueling Probes for a time, which were later refitted with cranked probes (stopped fuel flowing back into engine during aerial refueling) The Main tanks on early RNZAF A4K's were painted Gloss White (RNZAF Official - RNZAF Museum- Used with Permissions) Regards Alan 2 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted January 2, 2021 Author Share Posted January 2, 2021 The xtradecal set I’ve ordered has the fern-leaf roundels so thats good. 1 Link to comment Share on other sites More sharing options...
Calum Posted January 5, 2021 Share Posted January 5, 2021 I've written a couple of blog posts on modelling the RNZAF Skyhawks. The first one covers the aircraft and what mods/changes where introduced and when (See Here) The second one, which I'm still working on, covers the Hasegawa 1/48 Kit (See Here) 2 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted January 5, 2021 Author Share Posted January 5, 2021 (edited) 34 minutes ago, Calum said: I've written a couple of blog posts on modelling the RNZAF Skyhawks. The first one covers the aircraft and what mods/changes where introduced and when (See Here) The second one, which I'm still working on, covers the Hasegawa 1/48 Kit (See Here) I had already found the first one while looking for answers, I didn't know there would be a second one. In my stupidity I didn't go past the credits at the bottom of the link/article. Thanks they both help and have saved the first as a link to get back to in a hurry. Dennis Edited January 5, 2021 by Corsairfoxfouruncle Link to comment Share on other sites More sharing options...
kiwitrogg Posted January 6, 2021 Share Posted January 6, 2021 12 hours ago, Calum said: I've written a couple of blog posts on modelling the RNZAF Skyhawks. The first one covers the aircraft and what mods/changes where introduced and when (See Here) The second one, which I'm still working on, covers the Hasegawa 1/48 Kit (See Here) Hi Calum. I've been using your sites myself the last week or two for my own post-Kahu kit conversion, and they'll be my go-to references for my T-bird and pre-Kahu as well. They've been an absolute goldmine (even for someone who used to work down the Italian end of 4 hanger! ). Many thanks for taking the time to put them together and sharing your knowledge. Thoroughly recommended. Cheers Gaz 1 Link to comment Share on other sites More sharing options...
