Chrisj2003 Posted December 29, 2020 Posted December 29, 2020 (edited) Not halfway through the GB and the F-89 is going well. Restrictions means an unusual amount of free time so I am going to start this DreamModel F-5E which is new this year and I got from the Big H when it got to the UK last month. There had been a lot of negative comments about cost and accuracy. But for me it seems the going rate for kits from the Far East now; with a new Hasegawa 1/72 F-4 >>£50. This has a large box, delicate details, sprues engineered for other variants, multiple different options, large coloured painting and decalling guides, and a tiny PE fret for seat belts and the flat bit on top of some operators fins. I bought it to do a USAF aggressor but am going with the RoKAF option; 2 tone grey. I am hoping the painting guides scale up easily as pseudo masks. Chris Edited March 13, 2021 by Chrisj2003 FINISHED 5
reini Posted December 29, 2020 Posted December 29, 2020 Interesting! Nice to see the kit up and close and how it builds up.
Col. Posted December 29, 2020 Posted December 29, 2020 Another worthy type to deserve recognition in our GB Was hoping someone does an aggressor type but a RoKAF scheme is just as good. Sure you'll gain a lot of interest from those of us keen to see how this one goes together.
Chrisj2003 Posted December 30, 2020 Author Posted December 30, 2020 So the F-89 did need another coat of black so on with this F-5. First impressions are fine detail, and thin plastic with thought-out joins, but not many pieces. The plane itself is only 6 parts: nose cone front left front right fuselage bottom rear with wings and tailplanes top rear fin but there are 7 parts in each guided bomb + pylon - 5 parts in each sidewinder - 8 parts in the seat including PE my loadout will be 2 wingtip late model sidewinders + centre fuel tank - it feels I am leaving around half the part count unused fit looks good some odd choices, eg bottom rear 8 locating holes - but top rear only 2 locating lugs you have to drill holes for tailhook - is there a F-5 without one? but fill holes in wings for unwanted wing pylons very fine mating surfaces - eg on inside of inlets - and very fine lips to same - but ejector pin marks on the inside curved surface which I cant completely remove nice details in wheel bays but speed brakes arent openable So a lot of filing sprue ends (is there a term when there is a stub of plastic on the part - see eg landing gear and pylons on photo?) and priming; started construction with fins on one side of sidewinders - leave them to dry solid before trying opposing sides - and drilling holes and filling holes. Chris 7
Col. Posted December 30, 2020 Posted December 30, 2020 This one sounds to be something of a curate's egg; a mix of good and bad features. While I don't know what those extra bits on so many parts are called there's certainly plenty of them now you mention it. Is there much in the way of cockpit detail? The fuselage sidewall look particularly bare.
Chrisj2003 Posted December 30, 2020 Author Posted December 30, 2020 No detail on the sidewalls; full colour decals for IP. Going lid down. Always assumed F-5 cockpit is small. Chris 1 1
Andwil Posted December 30, 2020 Posted December 30, 2020 Looks like it will take a lot of care removing the undercarriage parts off the runner without breaking them. I call those attachment points “nubs” and they can be a real pain, especially on small parts. AW 1
Chrisj2003 Posted January 16, 2021 Author Posted January 16, 2021 Bit more progress while waiting for weather to progress F-89. 4 bits of PE added to seat; 6 bits in kit, no instructions, so went on Dream Models FB page. Fiddly. Also drop tank done and primed. Will speed up when F-89 done. Chris 7
Col. Posted January 19, 2021 Posted January 19, 2021 Well done on making good use of the secret parts this kit includes but doesn't bother mentioning. 1
Chrisj2003 Posted January 23, 2021 Author Posted January 23, 2021 More progress while waiting for F-89 to complete. - drop tank painted - paint on wings where holes for pylons filled - happy they cant be seen - multiple thin white coats on intake insides (white is hard to brush and get cover - but light grey is very easy) - and now masked and external colour on front ends - can see will be less than perfect when pieces glued - instrument decals on - need a matt coat - not perfect - but will be closed up because the canopy opening mechanism isnt there and building that is beyond my current abilities - ejection seat painted - that I am happy with Chris 6
modelling minion Posted January 24, 2021 Posted January 24, 2021 Nice work Chris, the instrument panel looks really good as does the seat and all of this will make a very convincing cockpit, especially if the canopy is closed. 1
Chrisj2003 Posted January 30, 2021 Author Posted January 30, 2021 Glad you liked the pit Craig. Took a few photos before closed up. Pleased with shadow under the PE belt and silver button on the stick. Also of the two 2 part intakes painted inside white and top colour to a distance. I said it was going OOB but the vague bumps where the cannon muzzles are were rubbish; so I have twist drilled 0.7mm holes; need a bit of polishing out of visible gouge marks. Chris 5
Chrisj2003 Posted February 6, 2021 Author Posted February 6, 2021 With the F-89J done time to close up this one. DreamModel have got most of the joins on real panel lines and allowed for different front ends as well as getting the intakes together nicely, but that means 4 sub assemblies or 8 parts all coming to together at the rear of the pit / at the intakes. And what I didn't like was having to flex the LREX to get the intakes in, they didn't break but they do need a smear of filler (and behind the pit). The other interesting idea is to make the HUD quite deep; great you don't lose it but it does fill a big hole in the cockpit coaming. So far I have not broken any of the 3 small vertical aerials which are moulded with the fuselage; keeps them nice and thin which seems to be DreamModel's driver. Got to prime and refill and sand as necessary, then get tailfin on. Looks like a F-5 now. I bought the Master cannons and pitot; not sure whether to put the cannons on before or after main painting. Thoughts? Chris 6
Col. Posted February 6, 2021 Posted February 6, 2021 That looks to be coming together well despite all the joints Chris. As for what point to fit the barrels; depends whether you're better at gluing tiny parts or masking them
Chrisj2003 Posted February 7, 2021 Author Posted February 7, 2021 Neither; so l have painted, and will add them now. Macro photo shows still some filling work to do behind cockpit; one coat a day with enamels makes for slow progress. Chris 6
Chrisj2003 Posted February 9, 2021 Author Posted February 9, 2021 Ok there are 6 clear parts on this sprue; and there's a different sprue for the 2 seater so that's instructions are no help(this time): square - no idea windscreen - ok canopy - ok flat bent - no idea flat bent - no idea HUD - ok Any ideas on what 1, 4 and 5 are meant to be? I cant see what they should be or where they could go. Chris 1
Vultures1 Posted February 9, 2021 Posted February 9, 2021 39 minutes ago, Chrisj2003 said: Ok there are 6 clear parts on this sprue; and there's a different sprue for the 2 seater so that's instructions are no help(this time): square - no idea windscreen - ok canopy - ok flat bent - no idea flat bent - no idea HUD - ok Any ideas on what 1, 4 and 5 are meant to be? I cant see what they should be or where they could go. Chris 1, 4 and 5 look like the camera windows for the RF-5E variant. I am guessing Dream Model have moulded one clear sprue for both variants. Chris 2 1
Chrisj2003 Posted February 9, 2021 Author Posted February 9, 2021 Brilliant @Vultures1 I can close up cockpit with no fear the instructions are missing something I should have added. Thank you very much, Chris
Chrisj2003 Posted February 13, 2021 Author Posted February 13, 2021 Filling and filing done now. Changed my mind after dry fitting; will add cannon after painting. But the HUD piece doesn't fill the gap in the coaming; didn't see that one coming; needs to dry, then fill and paint before canopy on. Dry fitting canopy showed excellent clarity and even if it didn't I'd know the gap was there. Chris 6
Col. Posted February 14, 2021 Posted February 14, 2021 This one looks to be shaping up nicely now for you Chris
Vultures1 Posted February 14, 2021 Posted February 14, 2021 Coming together really nicely Chris. Good call on adding the cannon after the main painting, I'd say
Chrisj2003 Posted February 19, 2021 Author Posted February 19, 2021 Ahh well, cockpit not as neat as it was after I filled the gap next to the HUD. But clear bits masked and on and first coat of Light Compass Gray. Cycle with enamel paints means finishing on time will be challenging. Chris 3
