alex_stela 1,796 Posted December 27, 2020 Share Posted December 27, 2020 One of the two Sea Harrier models I managed to finish this week - 1/72 Airfix BAe Sea Harrier FRS.1 XZ457 "14" of 800. Naval Air Squadron, HMS Hermes Air Group, Falkland Islands, May 1982. Airfix SHAR kit is a total disappointment. If you think that wide panel lines are its biggest drawback, you are wrong - this kit has so many different issues that it could cover 5 other kits with them! Although it's easy to assemble, it takes a lot of work to fix all the bugs and it still won't look as good as the old ESCI! Airfix, it`s time for a new SHAR, at least as good as your GR.9!!!... I`ve used Eduard PE set (poor), Pavla resin air intakes (horrible! - don't buy them EVER) and exhaust nozzles (awful), Pavla resin gunpods (even more awful, horrible and innaccurate), Pavla resin MB.10H ejection seat (poor), Aires Quickboost outriggers for FA.2 (nice) and Master Pitot tube (nice). Decals are from the kit and they are the best part of the whole set. Painted with Gunze Mr.Color (333 EDSG, brightened). A couple of photos taken in daylight: And now a few photos taken in artificial light: Thanks for watching! 44 Link to post Share on other sites
Blue Monday 202 Posted December 27, 2020 Share Posted December 27, 2020 Despite all the problems with the kit, you got a nice Sea Harrier out of it, at least here on its own. Looks good. BM. 1 Link to post Share on other sites
junglierating 1,361 Posted December 27, 2020 Share Posted December 27, 2020 (edited) Sounds like you had the issues with the aftermarket not the kit so what were the issues then Nice rendition btw I happened to be plane captain of that Cab back when she was 715 on 899 NAS mid 90s....well shared with Mr Stokes on the other watch Edited December 27, 2020 by junglierating 2 Link to post Share on other sites
112 Squadron 246 Posted December 27, 2020 Share Posted December 27, 2020 Look as excellent as the other Sea Harrier you posted a while ago. Good work! 1 Link to post Share on other sites
Piotr Sudnik 329 Posted December 27, 2020 Share Posted December 27, 2020 Well done! 1 Link to post Share on other sites
Cuppa_joe 206 Posted December 27, 2020 Share Posted December 27, 2020 Very well done considering the setbacks 1 Link to post Share on other sites
RMCS 6,073 Posted December 28, 2020 Share Posted December 28, 2020 Excellent 1 Link to post Share on other sites
David H 1,355 Posted December 28, 2020 Share Posted December 28, 2020 Gee... and i was seriously considering the Airfix AV-8A... Link to post Share on other sites
KevinK 606 Posted December 28, 2020 Share Posted December 28, 2020 15 minutes ago, David H said: Gee... and i was seriously considering the Airfix AV-8A... That one's actually pretty good - it's a completely unrelated and later kit. 1 Link to post Share on other sites
David H 1,355 Posted December 28, 2020 Share Posted December 28, 2020 14 minutes ago, KevinK said: That one's actually pretty good - it's a completely unrelated and later kit. John Geigle had one on his shelf in Vancouver.... Link to post Share on other sites
BLACK_MAMBA 3 Posted December 28, 2020 Share Posted December 28, 2020 She came out looking very nicely! The effort around the front windshield does certainly change the "look" for the better in my opinion. I do hope we see you tackle an FA.2 as well now knowing where most of the issues are and how to adress them. 1 Link to post Share on other sites
Mig88 4,297 Posted December 28, 2020 Share Posted December 28, 2020 Despite everything, you've succeeded in doing a great job. Well done! Miguel 1 Link to post Share on other sites
swralph 1,957 Posted December 28, 2020 Share Posted December 28, 2020 Very nice build. 1 Link to post Share on other sites
Luka 556 Posted December 28, 2020 Share Posted December 28, 2020 Alex, I think there is a slight problem with your reasoning. If you say that the Airfix Harrier is problematic and you also used some bad aftermarket sets, then how come your model looks so good? 1 Link to post Share on other sites
socjo1 512 Posted December 28, 2020 Share Posted December 28, 2020 3 hours ago, Luka said: Alex, I think there is a slight problem with your reasoning. If you say that the Airfix Harrier is problematic and you also used some bad aftermarket sets, then how come your model looks so good? Lot of hard modeller's job? Alex, gratulations! 1 Link to post Share on other sites
Kentavros76 192 Posted December 28, 2020 Share Posted December 28, 2020 You have managed to present a very nice model despite the problems you mention. Great job!!! 1 Link to post Share on other sites
Luka 556 Posted December 29, 2020 Share Posted December 29, 2020 16 hours ago, socjo1 said: Lot of hard modeller's job? Alex, gratulations! I got that. 1 Link to post Share on other sites
F-32 4,874 Posted December 29, 2020 Share Posted December 29, 2020 Great result from what sounds like a bit of a nightmare kit 1 Link to post Share on other sites
alex_stela 1,796 Posted December 29, 2020 Author Share Posted December 29, 2020 Thanks for your comments, guys! I forgot that the WIP is on the forum here: https://www.britmodeller.com/forums/index.php?/topic/235072750-172-sea-harrier-frs1-x-2-airfix-vs-italeri-comparative-assembly/ I should wrote about the kit issues (only those that I've noticed), but I don't know if my English will be good enough too write it right. But let's try: - panel lines are much too wide, and not always correct; - fin under fuselage is too small in hight and has wrong shape (it's end should be more curved); - radar cone is too long and has wrong shape; - cockpit is too short (should be few mm longer to the back, so the ejection seat should be few mm back) and it's edge is about 1,5 mm too low; - windshield's lower edge should be much more straight and it ends too low, so the windshield has wrong shape; - air intakes should be a little wider and not so high - Pavla's replacements are not better in shape and they spoil insides of intakes that's why you shoul avoid them; - elevators have good size, but wrong shape on leading edges (you should fill up and rescribe the panel lines at the ends and correct leading edges); - the radar rays detector at the front of the fin is to thin and too short; - gunpods are wrong, but they replacement from Pavla are also wrong and are hard to fit correctly; - fuel tanks are oval, not round; - Sidewinder's rails are much too small (much too short and should be higher); - main gear leg is about 1,5-2 mm too high; - front gear bay is too shallow; - there are not any outriggers bays under the wings; the outriggers itself are a joke and really need replacement or improvement; - some of the air scoops are missing. That's all I remember... I think that "Harrier SIG guys" could make this list longer. I've tried to make as many improvements to this kit as I could, but still I'm not very happy about it... But decals were really good! About month ago I've realized that I have Airfix SHAR FA.2 in my stash. I wanted too sell it ASAP, because it's almost the same kit (except fuselage with almost the same issues, new wings top and some AMRAAMs), but now I have so much experience, that I want to build it immedietaly! I will try to force the same improvements to the kit (mostly handmade), but won't use Pavla gunpods (I will take those from Italeri FRS.1 kit), nor Pavla intakes (waste of money and work), nor Pavla exhaust nozzles (I will use Aires Quickboost, which are much beter in detail). And I will buy Aires Quickboost outriggers for sure! I hope, that it will look like Sea Harrier FA.2. My advice - if you want to build good looking Sea Harrier kit - go for Kinetic in 1/48. If you want it in 1/72 - go for old ESCI kit (reboxed from time to time by Italeri) or even old, simple and cheap Hasegawa, which is maybe not so accurate as ESCI, but still much better than Airfix! Just few more words about "new" Airfix Harriers - you should avoid their 1/72 Sea Harriers FRS.1 and FA.2 only! Their new 1/72 GR.1, GR.3 and GR.7/9 Harriers are different, much better kits!!! Thanks for your attention! Alex 1 Link to post Share on other sites
Wafu 1,359 Posted December 30, 2020 Share Posted December 30, 2020 Alex, congratulations on your stunning build, I never served on Shar’s but worked very close to them during my time on the RN carriers. In my humble opinion you have been able to get the best from the kit. I’m interested in your comments about the kit, I have one of these and the FR2 I hope to build. Thank you for sharing your experiences with the kits. Wafu. 1 1 Link to post Share on other sites
