1/72 Airfix Tiger Moth - Aussie Version - Completed
Oh Go on Then I'll Have Go as Well
A day too late, I have braved all to do the Airfix Tiger Moth:
IMG_3553
Start time is 10:23 ish on Sunday 27 December GMT.  It will be the Australian version as it doesn't need any yellow strips and is therefore all one colour to paint.  I have had two previous attempts at this kit and both have speared-in!  So hopefully it is third time lucky, the fiddly bits won't break and I won't be trying any rigging.
Edited by Olmec Head
finished
Pressing on -Slow Progress
Time is now 21/2 ish hours on and I am behind where I thought I could be...
The cockpit is done, the instrument panels needed a bit of a trim to fit and the decals were also trimmed down as they are too large full stop.
I then painted the cockpit and put in some basic Tamiya tape Sutton harness straps.  The fuselage is now being mercilessly clamped as it was a bit gappy.
IMG_3555
Next will be the tailplane, the nose and lower wing.  The Airfix nose has a bit of a fit problem, but I am going to go with the kit as is and not try to adapt it.  That way would lead to ...
Despite difficulties, our glorious maker presses on
1600 (Z) hrs - 5 and 1/2 hours on.
I had forgotten that all the small struts on this kit break just by thinking of them.  Pretty much each strut broke as I tried to detach them.  Some I managed to fix with superglue, some were replaced with plastic strut.  I know now why I swore never to try this kit again!  That said this one has got further than my previous 2 attempts  - look it even has the top wing balanced on prior to undercoating.  I kept the outer wing strut 'strengtheners'  on, although I know that they will be tedious to remove at the end without leaving little sprue stubs.
IMG_3557
State of Play at the End of Day One
I was going to undercoat with Halfords Plastic primer, but that's a bit slow, so I have used Tamiya RAF Dark Green as an undecoat/ first colour.  The finish should be RAAF Foliage green, I might use a Vallejo Dark Green which is a bit greener; or I will probably just do a second coat of the Tamiya.  Trying to airbrush in a garage in the UK at freezing point is not ideal.  Really this is like the last entry but in green and a bottle of Stilton flavoured beer.
IMG_3559
  • Olmec Head changed the title to 1/72 Airfix Tiger Moth - Aussie Version - Completed
Now Completed
Stop the clock! 1600 (Z) hours ish
The Markings are on, Airfix decals are excellent and always go on well.  So I am calling this done.  Thanks to Enzo for the GB.  This is the third 1/72 Airfix Tiger Moth that I have started and the only one I have finished, its a finicky little kit with lots of little struts that break.   Sorry,  the rigging was beyond me.
IMG_4488
Tiger Moth of No.12 Local Air Supply Unit (LASU) Kiarivu Airfield PNG Aug 1945.
It looks great!
I've built all the 1/72 versions of this except this one, and after seeing your build I’m now on a very slippery slope! The foliage green looks very nice too.
I might have, ahem, broken the odd strut myself...
Regards,
Adrian
Thanks Adrian, I remember your kits, they looked considerably better than mine.  The Aussie version is a nice scheme; I have a 1/48 Airfix Tiger Moth to do sometime as a post war RAF basic trainer.  The new ICM 1/32 might be interesting as well.
