WW2 Vickers Valentia data needed
Thank you for info about u/c, I was not aware about any visual difference in this area before.
Here we have Valentia
And here is Victoria
You need to look at them carefully, but indeed, there is a difference clearly seen . Besides appearent different construction of suspension (shock absorbents) The Valentia looks to have it taller, so this should result in different height given in technical data. I have to look for it.
On 12/26/2020 at 12:24 AM, JOCKNEY said:
When are you planning on starting building Jerzy ?
Pat, I think (or hope) to do her in 2021, but certainly not now yet. I have to collect more info to feel myself ready for build...
Regards
Jerzy-Wojtek
Thanks for the pictures Jerzy.
Definitely able to spot the different engines also the nose hase glazed panels on the Valentia which seem to be missing on the Victoria.
Are you building the Contrail on that comes with 5 kits in one box ?
Many thanks for all comments, I do hope to complete her in 2021...
Regards and have a Happy New Year!
J-W
Hi, I am currently building the three Victoria/Valentia available in the Contrail kit. Finding references is a true hunt, as soon as one is trying to decide which one to make ! I thank everyone contributing to the exchanges on this thread. I have not yet decided what to make, but certainly a Victoria, a normal Valentia, and the Valentia with the turrets. I will probably make the latter camouflaged. I am now making the interiors, and up to now it was difficult to properly understand how the cockpit was made. The pictures of the interiors in the various posts here were unknown to me. Thank you !
Do you have a camouflaged  scheme for Valentia with turrets, especially the nose one?
Regards
J-W
Hi, thanks for your reply. No, I have no camouflage scheme, and I can't find any view of the front turret, apart from the picture provided with the kit's instructions...
The link below will give you a bunch of useful pictures, but still no trace of front turret for aircraft used in WW2...
http://www.70squadron.roselake.co.uk/walkerjohngeorge5.htm
Paolo
Paolo
Paolo and Chris, thank you! From that web page I took one of photos in first post (but I did not record the link...)
BTW - in this link there is a photo described as "French airplane crashed in Habbaniya" and in fact depicts Westland Wapity in an interwar livery from break of end of 1920.s and 1930.s....  So perhaps one should be a bit careful with credit all what is given there....
Regards
J-W
This is a better resolution photo of Valentia "T" from first post
full?d=1533598460
The serial is still not seen :( . The  web page where it appeared suggest that it could be machine from 31 Sq in Iraq. The single letter perhaps confirms it. However, in another web page the same photo is illustrating the East Africa usage of SAAF Valetia... This Valentoa has four blade props whereas all SAAF machines I've seen so far had two blade props. There is something like a nose art below cockpit (?) - what it could be?
Regards
J-W
P.S>
I was wrong about two blades, here is SAAF Valentia with four blades prop (colorised photo i think)
Edited by JWM
The odds are slim but the 31 Sqn Operations Record Book, might offer some options for the serial number.  If you're really lucky, it may even mention the individual code letter.  ORBs should be downloadable for free from the UK National Archives.  I stress again that it's much more likely that the ORB won't have the details you seek...but what have you got to lose?
Thank you! Meanwhile I have some serials here
http://www.rafcommands.com/forum/showthread.php?20325-Vickers-Valentia-31-Squadron-Iran-26-8-1941
But.... I HAVE FOUND link between serials and some code letters here
https://books.google.pl/books?id=SLPNDwAAQBAJ&pg=PT397&lpg=PT397&dq=serials+valentia+31+squadron+iraq&source=bl&ots=k-TbXiOMHD&sig=ACfU3U2OipeKyHmnoeLdt0t3jj2zDQD7-Q&hl=pl&sa=X&ved=2ahUKEwiq2JnumIjuAhWilosKHaGIDcAQ6AEwEHoECBIQAg#v=onepage&q=serials valentia 31 squadron iraq&f=false
Regards
J-W
Paolo
Here are some interesting photos and drawings
http://aviadejavu.ru/Site/Crafts/Craft26342.htm
Regards
J-W
  • 1 month later...
Hi
Maybe you know this figure, but for any case it shows some interior details like a pilot position and arm chair
  • 2 months later...
The 'SJ' is intriguing, as it appears again here, but without another letter visible. The date for this flight taking Haile Selassie from Khartoum to Gedaref on a day trip was the 6 Sept, 1940. The Valentia in camo is most likely to be K3160 of 70 Squadron RAF, that had flown down from Heliopolis a few days earlier. It's likely that these shaky shots were not actually taken by my dad but by someone using a camera of his, possibly Selassie's son.
neg000 by Sandeha Lynch, on Flickr
neg012 by Sandeha Lynch, on Flickr
The date on another of my father's photos (also seen above here) was 8 Jan, 1939, on a trip down to Kenya in K3604 of 216 Squadron. They had some problem with the rear wheel !!
l002 by Sandeha Lynch, on Flickr
l004 by Sandeha Lynch, on Flickr
Incidentally, I have only the negatives and a hand-written log by my dad - any other information has been provided from the ORB that several air historians have shared access to. Take a look at the other shots if it helps.
I'll be very interested to see how your Valentia progresses.
Very interesting is also heavy damage of paint on top of fuselage given that year before tha machine was all over alu dope. So the sun and sand did the job apparently...
I am strongly tempted to do this particular Valentia...
I'd have to say it's a good choice! 🙂
Here's the notes from the ORB.
From the Operations Record Book of Headquarters, No.203 Group.
"6/9/40, 0600 - The Emperor HAILE SALASSIE (sic) arrived by road and was received by Group Captain C.E.V. PORTER, (SASO), Wing Commander J.G. ELTON, DFC., AFC., (Stn. Commander, RAF Khartoum), and Flight Lieutenant B.J. LYNCH, Ph.D. B.A (sic, in fact a BSc), (Group Senior Intelligence Officer). After a brief inspection of the fighter aircraft on the aerodrome the Emperor departed by a Valentia aircraft piloted by Pilot Officer FARMER, to GEDAREF and was escorted by two Vincents of 430 Flight. The Emperor was accompanied by his son and members of his staff."
The Valentia is most likely to be K3160 of 70 Squadron RAF, that had flown down from Heliopolis a few days earlier. You might be aware that the whereabouts of Selassie in that period was top secret, which might make an a/c identification tricky. But as someone suggested, K3160 certainly wasn't anywhere else that day.
