aurelien wolff Posted February 19, 2021 Share Posted February 19, 2021 already did the idler wheel on the H2(wich is already done), now it"s academy tiger I, I'll try some drybrush on it. I've seen some late tiger I instruction and it doesn't seem that I've messed up the angle that badly so I'll keep it that way. Link to comment Share on other sites More sharing options...
aurelien wolff Posted February 22, 2021 Share Posted February 22, 2021 Decided to add some tool using academy instruction, but I didn't have enough place for the hammer. I used some part from my tiger H2 box on the turret 4 Link to comment Share on other sites More sharing options...
DByrden Posted February 24, 2021 Share Posted February 24, 2021 On 2/18/2021 at 4:29 AM, M3talpig said: would it be easier to PM you or should i just post my questions here? It would be easier to email me! The address is on my pages at TIGER1.INFO David 1 Link to comment Share on other sites More sharing options...
DByrden Posted February 24, 2021 Share Posted February 24, 2021 On 2/22/2021 at 1:10 PM, aurelien wolff said: I used some part from my tiger H2 box on the turret I don't know what you're building there, but the cupola angle is wrong... David Link to comment Share on other sites More sharing options...
aurelien wolff Posted February 24, 2021 Share Posted February 24, 2021 I'm building a what if F04 from the Kampfgruppe Schultze, the only difference being in the interior https://tiger1.info/EN/Hydraulic-grilles.html (I like doing what if). I've replaced the hatches using dragon one because I haven't putted the vision block at first and thanks for pointing me out about the cupola angle, not sure how I can fix it but I'll try (I think I'll do a mess). Also, I can't do mine with mudguard because I don't know why but some time ago I decided to cut them off and now I can't find them anymore. the second will be much better than this one Link to comment Share on other sites More sharing options...
aurelien wolff Posted February 24, 2021 Share Posted February 24, 2021 is this better? had to use brute force with the cisor 2 Link to comment Share on other sites More sharing options...
DByrden Posted March 3, 2021 Share Posted March 3, 2021 The basic rule with the Tiger cupola is that one of the visor holes faces directly forwards. So, the hatch ended up 72 degrees from forward. David 1 Link to comment Share on other sites More sharing options...
echen Posted March 8, 2021 Share Posted March 8, 2021 (edited) As there is no detail under the engine deck vents I photoshopped the cooling fans and radiator. Suitably scaled and folded I aim to stick it in place on some card. The next trick will be to actually fit it as the hull top is fixed. I've researched L&L track fitting for the Revell Tiger 1 and it's looking a bit tricky. The wheels still need a lot of tidying paint-wise to sort out the mess I made painting the tyres but I thought I'd plan/dry-fit the tracks so I knew where I was going with them. I've drilled the holes in the wheels so that they slide on and off more easily. One suggestion I found was to put the roadwheels in place without cement, cement the requisite number of indy links to the sprocket and idler so they can rotate, allowing fitting of the lengths to join up at each end and then to cement the tracks round them. This enables further work on the running gear away from the hull as the hull/tracks gap is very limited above the tracks. The problem I foresee with this is that there is a row of wheels that are going to be tricky to put in place without cement. Another route was to fix the roadwheels but not the sprocket or idler. Next to cement the requisite number of indy links to the sprocket and idler so they can rotate, allowing fitting of the lengths top and bottom of the roadwheels to join up at each end. Has anyone experience of the 1/72 Revell Tiger 1 (03262-0379) track fitting? All suggestions welcome. Edited March 8, 2021 by echen Additional detail. 2 Link to comment Share on other sites More sharing options...
Dads203 Posted March 9, 2021 Share Posted March 9, 2021 M10 finished so looks like this might be my new home for a month or seven ? Again I must thank @Zack for sorting me out with this kit. Top guy indeed. Box open. Bench tidy-er More to follow 10 Link to comment Share on other sites More sharing options...
echen Posted March 9, 2021 Share Posted March 9, 2021 This'll be worth following. 1 Link to comment Share on other sites More sharing options...
Dads203 Posted March 9, 2021 Share Posted March 9, 2021 Some extra bits, the partial interior I might add, not yet decided First bits ready for building 8 Link to comment Share on other sites More sharing options...
Cerberus Posted March 9, 2021 Share Posted March 9, 2021 If it's got Friuls you can count me as following, I'm a sucker for any metal sparkly stuff to be honest... Matt 3 Link to comment Share on other sites More sharing options...
echen Posted March 9, 2021 Share Posted March 9, 2021 1 minute ago, Cerberus said: If it's got Friuls Do the Friuls come as part of the kit or are they after-market? Link to comment Share on other sites More sharing options...
Dads203 Posted March 9, 2021 Share Posted March 9, 2021 1 minute ago, echen said: Do the Friuls come as part of the kit or are they after-market? Aftermarket fella, you get the crappy DS tracks in the kit and they are only fit for the bin Found these little gems in the stash, Just to add to the detail 8 1 Link to comment Share on other sites More sharing options...
Stef N. Posted March 9, 2021 Share Posted March 9, 2021 Nice. Who makes them? Link to comment Share on other sites More sharing options...
Dads203 Posted March 9, 2021 Share Posted March 9, 2021 Just now, Stef N. said: Nice. Who makes them? RBM, I bought them years ago and the bag of 20 shackles was about £5 !! Bargain 1 Link to comment Share on other sites More sharing options...
Jasper dog Posted March 9, 2021 Share Posted March 9, 2021 2 hours ago, Dads203 said: Aftermarket fella, you get the crappy DS tracks in the kit and they are only fit for the bin They might be crappy ds tracks but I wouldn't bin them.... Dont let on but I've been getting £10-£15 a time for them on the usual on line auction site.... Pays for half the set of Fruils, or did.. funnily enough they are getting expensive now they've stopped supplying them to the model shops. Looking forward to seeing what you do with this Tiger! 1 1 Link to comment Share on other sites More sharing options...
M3talpig Posted March 10, 2021 Author Share Posted March 10, 2021 17 hours ago, Dads203 said: Some extra bits, the partial interior I might add, not yet decided Is this done yet?......... i would have finished by now. 5 Link to comment Share on other sites More sharing options...
M3talpig Posted March 10, 2021 Author Share Posted March 10, 2021 14 hours ago, Jasper dog said: Looking forward to seeing what you do with this Tiger! I will hazard a guess that he will glue it together and then paint it ....but i might be wrong Darryl 4 Link to comment Share on other sites More sharing options...
M3talpig Posted March 10, 2021 Author Share Posted March 10, 2021 Some piccys of my very slow paced build.........trying a different photo host and not sure what i'm doing so let me know how this looks ...... 9 Link to comment Share on other sites More sharing options...
echen Posted March 10, 2021 Share Posted March 10, 2021 (edited) Pics look great.👍 Might benefit from a space underneath each one? Edited March 10, 2021 by echen spaces 1 Link to comment Share on other sites More sharing options...
M3talpig Posted March 10, 2021 Author Share Posted March 10, 2021 On 10/03/2021 at 12:36, echen said: Pics look great.👍 Thanks echen have no clue what im doing with the new host ...not sure i like it, to be fair might switch back as at least i could select photo size ...new host i can't seem to do that. Link to comment Share on other sites More sharing options...
echen Posted March 10, 2021 Share Posted March 10, 2021 1 minute ago, M3talpig said: have no clue what im doing with the new host Pic submission seems to be a perennial issue. I use OneDrive but that seems to fluctuate in its user-friendliness. 1 Link to comment Share on other sites More sharing options...
Andy J Posted March 10, 2021 Share Posted March 10, 2021 Pic's look great to me Steve and the quality of your work is superb 👌 👏. Now crack on and let's see some more progress 😉👍 1 Link to comment Share on other sites More sharing options...
Jasper dog Posted March 10, 2021 Share Posted March 10, 2021 2 hours ago, M3talpig said: I will hazard a guess that he will glue it together and then paint it ....but i might be wrong Darryl Quite the little comedian.... Toddles off for 3mths and then lo-and-behold, back with the comedy gold.... I'll let it slide, this time, without the witty rebuttal... 2 hours ago, M3talpig said: not sure what i'm doing so let me know how this looks ...... Bit like a Tiger....but as for not knowing what you're doing...didn't like to say but.. I assume you are talking modelling?😉 4 Link to comment Share on other sites More sharing options...
