andy_AUT Posted December 12, 2020 Share Posted December 12, 2020 Hello, after reading a review of the 1/35 KW-85 by Trumpeter (kit 01569), I've got a question. The review (link at the end) mentions that Trumpeter provides the wrong turret (asymmetric IS-2 style), whereas the KW-85 should have a symmetric turret (IS-1 style). Also, the review doesn't provide any pictures or drawings. After looking at several pictures online, I have to admit I don't see what is meant with asymmetric/symmetric with regards to the turret, and what is wrong with the kit. So, if you have any info regarding this, I'd be very grateful for posting it here. Thank you and have a nice weekend, Andy Link to review (I hope it is ok to post it here): http://www.4bogreen.com/kv-series/plastic-and-resin-kits/1-35-scale/trumpeter/01569-soviet-kv-85-heavy-tank 1 Link to comment Share on other sites More sharing options...
JackG Posted December 12, 2020 Share Posted December 12, 2020 You can look at model kit parts/instructions at Super-Hobby, so here are links to Trumpeter and Bronco on said subject - they don't stock the Eastern Express: https://www.su per-hobby.com/products/Soviet-KV-85-Heavy-Tank.html https://www.super-hobby.com/products/Russian-Heavy-Tank-KV-85-Oct-1943-Production.html Side by side comparison, Bronco is the green plastic: Not rear left corner, that is the asymmetry and it also changes the shape of the mg casement. regards, Jack 1 Link to comment Share on other sites More sharing options...
Kingsman Posted December 12, 2020 Share Posted December 12, 2020 Both appear to be further asymmetric in that the side angle change on the right appears to be further forward than on the left. Perhaps more pronounced on the Trumpeter but that might be a factor of the colour. That might be a feature of both IS-1 and IS-2. Trumpeter sides also appear to be steeper and the top looks wider by reference to the other features. As the KV-85 pre-dated the IS-1 it seems logical that its turret would more closely resemble the IS-1 than the IS-2. Link to comment Share on other sites More sharing options...
JackG Posted December 12, 2020 Share Posted December 12, 2020 The biggest difference I see is the SW corner, it's curve follows the shape of the commander's cupola hole. On the Bronco turret, there actually is a corner piece that visually matches the opposite side. Mind you, Bronco may not be 100% accurate either, even the details on the forward half of the turret roof don't match. I've no idea where to grab an official sanctioned line drawing, but apparently the production turret decided upon was the IS-85 type according to tanks-encyclopedia. https://tanks-encyclopedia.com/ww2/soviet/soviet_KV-85.phpI regards, Jack Link to comment Share on other sites More sharing options...
andy_AUT Posted December 12, 2020 Author Share Posted December 12, 2020 I was looking at the sprue shots and instructions at SuperHobby, but it seems I missed the obvious, as I was only looking at pictures and drawings from the front and the sides. Considering the line drawing posted, it seems that the Bronco kit (in top view) is more accurate. Only the (ventilation?) cover at the front seems to be too far aft. Thank you to both of you for your contributions, which helped a lot! Link to comment Share on other sites More sharing options...
JackG Posted December 13, 2020 Share Posted December 13, 2020 Did a little more reading over at missing-lynx, and looked over the only model I have of the KV-85 (PST 1/72). Can confirm the turret roof is symmetrical. The only detail asymmetrical is the left hand turret wall has an angular bulge to accommodate radios. With conversion to the 122mm gun, that is when turret shape, as viewed from above, became asymmetrical. regards, Jack 1 Link to comment Share on other sites More sharing options...
andy_AUT Posted May 30, 2021 Author Share Posted May 30, 2021 As a little follow up, if anyone is interested, there are two resin corrections for Trumpeter's KW-85 in 1/35 available. Tiger Model Designs: https://www.scalemates.com/kits/the-new-tmd-35-35-3045-kv-85-corrected-turret--1241831 Albatros Resin (description of parts http://www.4bogreen.com/news/kv-85-turret-from-aresin (I'm not connected to these manufacturers) 1 Link to comment Share on other sites More sharing options...
