speedy Posted November 25, 2020 Share Posted November 25, 2020 (edited) I’m progressing on my build and decided to jump a couple of steps whilst pondering other issues. I noticed this on the sprue which is the part of the rotor head and its a main and obvious part. The kit is 2nd hand and has obviously got hot at some point; although all else is as intended. Anyway how on earth can I make this straight (vertical). 5A584467-0EEC-4259-8E77-003FAB5D041B Steve. Edited November 25, 2020 by speedy Link to comment Share on other sites More sharing options...
Vicarage Vee Posted November 25, 2020 Share Posted November 25, 2020 I can only suggest using it as a guide to make another out of Evergreen/Plastruct/Slaters tube, rod, sheet and strip. possibly incorporate some brass for strength. Link to comment Share on other sites More sharing options...
Kev The Modeller Posted November 27, 2020 Share Posted November 27, 2020 Gentle warm the area and slowly bend it back. Link to comment Share on other sites More sharing options...
cmatthewbacon Posted November 27, 2020 Share Posted November 27, 2020 On 11/25/2020 at 2:27 PM, speedy said: Anyway how on earth can I make this straight (vertical). Viagra... More seriously... polystyrene softens at around 100 degC so if you dip it into just boiled water for increasingly long times (you need to experiment to see how long it takes — use some sprue, but bear in mind a thin bit of sprue will heat up more quickly than that chunky part) until it softens you can flex it back slowly into place. If you leave the cold tap running you can then hold it underneath to “set” the piece back in the right shape... best, M. 1 1 Link to comment Share on other sites More sharing options...
