E for Easy (or will it be) Airfix Lancaster B3 Dambusters.
Just now, Mancunian airman said:
Alastair
Have you tried mixing some sprue from the kit into a small bottle of Tamiya glue to create 'sprue glue' and run that along the seam lines of the kit ??
Just a thought
Ian
Hi There,
I have a bottle of sprue glue mixed in an old Tamiya bottle. It's one of my options if the current attempt hasn't worked.
May well be tried.
Alistair
4 hours ago, Spookytooth said:
baking soda is another one to mix with C/A from what I have read.
I only use flour now with CA - the end result is smoother than anything else. Although, if I'm not in a rush and I don't need a structural bond, I tend to use sprue gloop more and more, just as @Mancunian airman says.
Nice progress on the painting side, Simon :clap:
Ciao
Thanks @Mancunian airman, @AliGauld, @giemme, @bbudde, @dogsbody, @Pete in Lincs, @elger, @Dr. Quack and @Tomoshenko.
Well, after a coffee, a bit of hairy stick work on the pilots seat.
IMG_20210120_195245
IMG_20210120_195305
IMG_20210120_195353
And those seams....
IMG_20210120_195441
IMG_20210120_195448
That`a all for tonight, my poor old eyes can`t take much more LOL
Let`s see what tomorrow brings.
All comments welcome.
Simon.
  • Like 11
…and on that seat - amazing! :)
On 20/01/2021 at 21:16, elger said:
nice work on those nacelles!
Thanks, the nacelles were a pita with those seams but got there I think, the seat was OK , could of done better.
Thanks @rob85, @giemme, @Pete in Lincs, @AliGauld@mark.au, @dogsbody and @bbudde.
OK, time for some fiddly bits, some P.E. levers and plates?
A right pita to be honest, I would of left the moulded ones on if I could but the I.P. would not allow it with out surgery.
IMG_20210123_104249
That gives you an idea of the size of the little bleeders.
They are suppose to be curved in profile so after mucking up the first one I went into  old school mode.
Remembering somewhere back an article on P.E. seat belts and buckles. I bent the levers first then threaded them through the mounting plate before forming the curve on my patented jig.
A piece of cocktail stick C/A`d onto a stirrer.
IMG_20210123_104317
Just visible but you can see it better in the reflection .
And here they are placed not glued on the I.P.
IMG_20210123_105140
A bit of work to sort them out before tackling the main throttle quadrants.
I could be a while with those!!!
You all have a great weekend.
Stay safe.
Simon.
  • Like 9
Splendid job with those tiny levers, Simon! :clap: :clap: They really add a lot to the overall of the IP.
Ciao
6 hours ago, giemme said:
Splendid job with those tiny levers, Simon! :clap: :clap: They really add overall lot to the overall of the IP.
Ciao
3 hours ago, CedB said:
Seconded! Cunning… :)
Thanks, and here they are now fixed into position.
IMG_20210123_185729
IMG_20210123_185739
Thanks @Pete in Lincs, @elger, @Tomoshenko, and @AliGauld.
To give peeps an idea of how small these levers are here is a pic of the ones for the main quadrant.
IMG_20210123_171751
fitted in place with a drop of C/A.
IMG_20210123_185027
And from the side.
IMG_20210123_185128
A bit blurred but shows there are there.
I have still got to put the bottom ones in before forming the "Plate" to the required shape.
Fun!!!!!!
Simon.
:frantic: :frantic: :frantic:
They look impressive,  though :clap:
Ciao
I will add that despite how fiddly and pita they are, the IP looks much better with them so it is worth the effort. That's a nice shot of them below.
31 minutes ago, Spookytooth said:
IMG_20210123_185739
  • 5 weeks later...
Thanks @bigbadbadge, @giemme, @CedB, @mark.au, @elger, @Pete in Lincs, @Tomoshenko and @AliGauld.
Sorry about the delay but life etc gets in the way, that and this lockdown was starting t get to me but!!! I am back on the bench again catching up on things.
First up, some re-scribing of missing/erased panel lines on the outer nacelles.
IMG_20210223_133452
Sear belt added to one of the crew seats (who`s I don`t know)
IMG_20210223_133516
And finally have sorted the levers out as best as I can on the central console.
IMG_20210223_133535
I will adjust them once they are fitted.
Anyhow, I hope all is well where ever you are all are.
Simon.
  • Like 12
Wondered where this one had gone  good to see you back on it, hope you are feeling better now too.
Nice  work, I have never thought of doing the levers that way , will have to bear that in mind. Thanks.
Chris
I agree with the others, Simon - great to see you back to the bench, and neat job with those fiddly PE bits! :clap:
Ciao
Fiddly levers - hateful - but you've done a good job Simon :)
Thanks @Thom216, @CedB, @elger, @giemme, @AliGauld, @bigbadbadge, @bbudde, @Dr. Quack, @Pete in Lincs and @dogsbody.
Sorry for the slowness of the build at the moment but life keeps getting in the way.
But some progress, some masking of the fuselage windows, lots of them.
Thankfully I got the Montex sheet for her, saved my sanity no end.
IMG_20210301_150117
The ghostly foot ha ha.
Port side done, after a slight error on my behalf (not reading the part numbers right on the kit`s instructions)
IMG_20210301_152303
There is a difference between the mid "5" and rear "5" I will tell you.
IMG_20210301_152307
Not much but 2 of the windows are slightly longer.
IMG_20210301_152310
Just the other side to do, then build the canopy to mask that and the turrets too.
I am glad that I got the masking sheet....
Stay safe.
Simon.
Nonetheless, a great exercise for patience, KUDOS :clap:
Ciao
I wouldn't even contemplate a greenhouse canopy without one any more.
I have heard of some problems with Montex Masks, but I've used them o couple of times and had no problems.
In fact I had them on a Dakota build that they were on for a good month or two... ish with no issues.
Looking good.
Alistair
Ciao
Looking good.
Alistair
Yes, a great deal of time saved too.
I have a few more kits in the stash that I will be getting some P.C.M.`s for as well.
Thanks @CedB, @elger, @Dr. Quack and @dogsbody.
Well following on, I did the other side without any problems.
IMG_20210302_135055
Then it was the turn of the turrets.
Front first.
IMG_20210302_134132
IMG_20210302_134139
And then the rear.
IMG_20210302_134154
IMG_20210302_134210
And the rear piece of the rear turret which did not have any framing marks but a quick look at the ref pics showed the positions.
IMG_20210302_134224
Just the main canopy and bomb aimers position to do, once I have fixed the canopy together.
Stat safe.
Simon.
1 hour ago, Spookytooth said:
And then the rear.
IMG_20210302_134154
The top right mask looks like it's lifting up. Other than that, neat job :clap:  :clap:
Ciao
It is Giorgio, but it is a bit of a pain. I will burnish it down just before spraying.
It has happened elsewhere but not as bad .
Simon.
