Pin Posted November 21, 2020 Share Posted November 21, 2020 Hello, I have some experience in retooling old, long out of production vacform into a resin kit with the permission of original vacform producer. But what if such permission cannot be obtained? At what point using a vacform as a base for a resin kit stops being piracy? Retooling is a lot of work and final product in very different from the original. I'm thinking about retooling Esoteric Overstrand, I'm happy to make some deal with the current owner of rights but I have no idea how and I definitely don't want to be accused for piracy Link to comment Share on other sites More sharing options...
Graham Boak Posted November 21, 2020 Share Posted November 21, 2020 I've seen the matter of piracy argued with respect to "copying" of existing injected kits from Eastern Europe and the Far East, but comments were passed to the extent that providing sufficient changes are made to make it significantly different then producers could not be sued successfully. I think that the alterations necessary to do a resin model would be quite sufficient, but (without knowing the Esoteric kit) are there not other changes that you will/could be making to improve the accuracy or level of detail? After all, every accurate model of any subject has to bear a remarkable resemblance to the original and hence each other. However, the amount of money involved would likely be considerably less, even for mainline kits, than the costs of a legal action. My comments are not "legally informed" but if you do go ahead you could keep o record of what you have done to try and find the owner of the rights as this would improve your position anyway. Link to comment Share on other sites More sharing options...
Pin Posted November 21, 2020 Author Share Posted November 21, 2020 The original owner has passed away more than 20 years ago. I'm not aware of any heirs, the kits were not reissued by any other marque either. Link to comment Share on other sites More sharing options...
Lewis95 Posted February 4, 2021 Share Posted February 4, 2021 I would also argue this point. It's a scale subject. It's not feasible, possible or legal(?) to "copyright" say... a P51D. You are using the same subject choice and providing you make sufficient changes to the parts, it's arguably a retooling of the Vacform. If you make extensive changes to the resin parts, I would go so far as to say it is now your own tooling. Link to comment Share on other sites More sharing options...
TheRealMrEd Posted February 5, 2021 Share Posted February 5, 2021 Generally, with most things (DVD's probably excepted!), you are entitled to make a copy FOR YOUR OWN USE. If you want to go into business with it, that's another matter... Ed 2 Link to comment Share on other sites More sharing options...
