Tom R Posted November 19, 2020 Share Posted November 19, 2020 I have inherited a Williams Curtiss C-46 and I am wondering how much effort is required to make the BOAC wartime CW-20. I believe the main visual difference is the lack of the 'crease' in the fuselage but what else? Are there any good pictures of the BOAC plane around? Thanks for any help. Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted November 19, 2020 Share Posted November 19, 2020 I have the same kit. As far as I can tell, BOAC got the prototype, that as you mentioned had no "crease". If you take the time to do an Internet search for the plane's registration, G-AGDI, you will find a number of images and information on it. There are dozens upon dozens of interesting, colorful, civil liveries for it, without the need of modifying the kit, unless of course you want this specific version, for which there are aftermarket decal sets. http://www.michaelprophet.com/News_articles/CurtissC_46.html 1 Link to comment Share on other sites More sharing options...
dogsbody Posted November 19, 2020 Share Posted November 19, 2020 Is this of any use? Curtiss CW-20A/C-55, G-AGDI "St Louis", of BOAC is refuelled at Gibraltar. "St Louis" ran regular supply flights between Lisbon, Gibraltar and the besieged island of Malta from 1941 to 1942. You would need to change the main landing gear to a two-leg type. Chris Link to comment Share on other sites More sharing options...
Tom R Posted November 20, 2020 Author Share Posted November 20, 2020 4 hours ago, Moa said: IThere are dozens upon dozens of interesting, colorful, civil liveries for it, without the need of modifying the kit Hello - Yes I have built some Latin American ones a few years ago. I also have the decals for this one, hence the interest. Thanks for your help. 1 Link to comment Share on other sites More sharing options...
Tom R Posted November 20, 2020 Author Share Posted November 20, 2020 3 hours ago, dogsbody said: Is this of any use? Curtiss CW-20A/C-55, G-AGDI "St Louis", of BOAC is refuelled at Gibraltar. You would need to change the main landing gear to a two-leg type. Hello - Yes, great help thank you! 1 Link to comment Share on other sites More sharing options...
rob Lyttle Posted November 25, 2020 Share Posted November 25, 2020 Little bit of an issue with the window count, but they look blanked off in these pictures, so maybe a paint job? Good luck with this.... It's a great old kit. Well worth getting those epic flaps deployed if that's your kind of thing. Link to comment Share on other sites More sharing options...
alancmlaird Posted November 25, 2020 Share Posted November 25, 2020 The engines are also different. G-AGDI had Twin Cyclones which had two rows of 7 cylinders per row. The kit's Double Wasp has two rows of 9 cylinders each so of distinctly different appearance. I think they are of greater diameter to the prototype's too. Link to comment Share on other sites More sharing options...
rob Lyttle Posted November 28, 2020 Share Posted November 28, 2020 https://www.google.com/url?sa=t&source=web&rct=j&url=http://legendsintheirowntime.com/LiTOT/C46/C46_index.html&ved=2ahUKEwiX38_ot6XtAhUOesAKHf73BwsQFjAAegQIAxAC&usg=AOvVaw2Y8eTHLzKgmJOfWscErDTN "Legends in their own time" has quite a bit on the C46 including the twin tailed CW20, which doesn't seem to have the crease. Is that the same airframe with a new single tailfin fitted?? 1 Link to comment Share on other sites More sharing options...
Yankymodeler Posted November 29, 2020 Share Posted November 29, 2020 (edited) All CW-20/C-46 had a 'crease' in the fuselage, it was a structural characteristic of the two-lobe design originally intended for pressurization. The crease is at the point of the floor. Some of the early examples had a fairing covering the crease but this was soon omitted as it provided no discernible drag reduction. Edited November 30, 2020 by Yankymodeler correct spelling 2 Link to comment Share on other sites More sharing options...
rob Lyttle Posted December 15, 2020 Share Posted December 15, 2020 I did come across this graphic when I was researching for the C46. The fuselage crease thing is clearly indicated here, and engine changes, doors etc 1 Link to comment Share on other sites More sharing options...
