Icarus Posted November 18, 2020 Share Posted November 18, 2020 So here we are, with an old friend. Ready for the off: The base kit looks pretty good to me so will resist the urge for aftermarket extras - the same for the kit scheme. Thanks for looking, Icarus 2 Link to comment Share on other sites More sharing options...
CliffB Posted November 19, 2020 Share Posted November 19, 2020 for using the kit's decals. Link to comment Share on other sites More sharing options...
Icarus Posted November 20, 2020 Author Share Posted November 20, 2020 OK, initial "on the sprue" painting. I rarely make 1/72 kits, so it is revelation how few sprues there are in this kit. Detail looks reasonable though, with the sidewall detail popping out with dry brushing. The MBs look ok as well. I did say this would be out of the box, but as this will eventually be a gift to another ex-208 friend, I have ordered a tuned brass nose probe to try and add some longevity to the final result. Thanks for looking, Icarus Link to comment Share on other sites More sharing options...
Icarus Posted November 21, 2020 Author Share Posted November 21, 2020 This is progressing rapidly. Just about to close up the fuselage after working on the cockpit last night. The cockpit seems pretty good out of the box - just added a bit of a oil pin wash to help extenuate the detail. Will varnish once the fuselage is closed up, which will eliminate the grey "tinge" from the Payne's grey there at the moment. Thanks for looking, Icarus 2 Link to comment Share on other sites More sharing options...
Icarus Posted November 25, 2020 Author Share Posted November 25, 2020 (edited) Quick update on this. Build progressing fast - I forgot how quickly 1/72 models go together, and I have to say this little Revell Hawk is a real gem. Good old Halfords Grey Primer down, and happily no imperfections to touch up. Have seen an online article describing using Tamiya acrylic black thinned with Tamiya lacquer thinner which seemed to produce a lovely gloss black finish, so will try that here. I have gone with our usual TWU load out, so just outboard pylons and the gun pod. Thanks for looking, Icarus Edited November 25, 2020 by Icarus 1 Link to comment Share on other sites More sharing options...
Icarus Posted November 27, 2020 Author Share Posted November 27, 2020 (edited) So, the black is down but the finish is somewhat disappointing. I suspect the paint mix was a bit thick. This will smooth out with the final varnish after the decals, but not something I've seen before: Should get decaling finished this evening, then it's down to work with micromesh cloths then Alcad Satin varnish to sort out the final finish. Thanks for looking, Icarus Edited November 27, 2020 by Icarus 3 Link to comment Share on other sites More sharing options...
Icarus Posted November 29, 2020 Author Share Posted November 29, 2020 Now, that's better. Full decal set on, and with some varnishing and sanding done, the finish is much more satisfactory. As you can see from the surrounding paraphernalia, I m just about to unmask the front canopy, and if that's fine, I will start adding all the delicate/fiddly bits. I have already painted and weathered the wheels, so with a fair wind this might even be finished this evening... Thank you for looking, Icarus Link to comment Share on other sites More sharing options...
Icarus Posted November 30, 2020 Author Share Posted November 30, 2020 So, on reflection (no pun intended) I wasn't happy with the semi-matt finish, so have glossed up the paintwork to be more representative of a display aircraft. This faffing around meant I didn't get a chance to add the fiddly bits last night, so will do this tonight. Aim to finish tonight. Thanks for looking, Icarus 1 Link to comment Share on other sites More sharing options...
Icarus Posted December 8, 2020 Author Share Posted December 8, 2020 So, typically, on the final run for this one of the main wheels shot off the sprue, never to be seen again. I had to wait for a replacement resin set to arrive before completing this, but we're there now. All done. Ironically given how much trouble I had with the initial black coat, this is almost too glossy in these photos. Looks appropriate in daylight though. Will put some better photos in the Galley, Thanks for looking, Icarus 4 Link to comment Share on other sites More sharing options...
