chrispisme 1,380 Posted November 29, 2020 Author Share Posted November 29, 2020 Progress made still and knowing I hadn't found all the issues, cracks misfits etc. on the model, I gave it a quick shot of Tamiya XF-19 to reveal any and all problems I couldn't see. To be honest there weren't as many as I was expecting but still more than I was hoping for. back to the putty and sand paper for now. Thanks for looking 7 Link to post Share on other sites
fjaweijfopi4j48 38,532 Posted November 29, 2020 Share Posted November 29, 2020 The modelers' mantra: Prime, Fill, Sand; Prime, Fill, Sand; ommmmmm!!!! Closer now, well done. 4 1 Link to post Share on other sites
chrispisme 1,380 Posted November 29, 2020 Author Share Posted November 29, 2020 finally getting around to adding some details to the main gear, brake lines and the white disc is for a retraction arm (yet to be made) As well, I've cut off the tail cone and re-worked it a bit to use to plunge form a clear tail light cover which will replace the white plastic one. Here's the main gear being worked on again; the tail cone should be clear; work continues Remember, I strive for mediocrity Thanks for looking 7 Link to post Share on other sites
fjaweijfopi4j48 38,532 Posted November 30, 2020 Share Posted November 30, 2020 Very nice! 1 Link to post Share on other sites
Space Ranger 3,254 Posted November 30, 2020 Share Posted November 30, 2020 9 hours ago, Moa said: The modelers' mantra: Prime, Fill, Sand; Prime, Fill, Sand; ommmmmm!!!! Closer now, well done. You forgot the whack on the head with a copy of Jane's All the World's Aircraft. 2 Link to post Share on other sites
Team Aer Lingus 438 Posted November 30, 2020 Share Posted November 30, 2020 Outstanding work it's really taking shape now great job so far 1 Link to post Share on other sites
chrispisme 1,380 Posted November 30, 2020 Author Share Posted November 30, 2020 Thanks for encouraging me along mates! I've added a bit of detail to the nose gear (while primer dries) here's the nose gear; clear part cobbled up and installed on the tail stinger; white primer/microfiller on the model and found a couple more problems (nothing more filler and sanding cannot remedy) thanks for looking 7 Link to post Share on other sites
Romeo Alpha Yankee 7,475 Posted December 1, 2020 Share Posted December 1, 2020 Some nice detail going into this Chris, the gear legs look great. Link to post Share on other sites
chrispisme 1,380 Posted December 1, 2020 Author Share Posted December 1, 2020 Thanks very much! I've got the first couple of shots of Tamiya gloss white on tonight, I'll put on a 2nd coat tomorrow and let that cure a day before handling again Thanks for looking 9 Link to post Share on other sites
fjaweijfopi4j48 38,532 Posted December 1, 2020 Share Posted December 1, 2020 Ahhh! 1 Link to post Share on other sites
Team Aer Lingus 438 Posted December 1, 2020 Share Posted December 1, 2020 Fantastic coming along nicely Chris well done thanks for sharing regards Eamonn 1 Link to post Share on other sites
kev67 1,738 Posted December 1, 2020 Share Posted December 1, 2020 That is looking really good, first Broplan model I hopefully will see completed 1 Link to post Share on other sites
chrispisme 1,380 Posted December 1, 2020 Author Share Posted December 1, 2020 The fun continues...actually it's not a task (I may make it seem like a hard job but, I'm spoiled) The 2nd coats of Tamiya lacquer gloss white have gone down nicely and the model is parked a while to allow curing before masking for more colors. It should look better with some color on it... Thanks for looking 7 Link to post Share on other sites
Lewis95 212 Posted December 1, 2020 Share Posted December 1, 2020 A very intuitive way of letting it dry! The kit is looking good so far bud! Link to post Share on other sites
TheyJammedKenny! 1,339 Posted December 1, 2020 Share Posted December 1, 2020 Wow! I would be reluctant to position any model in the way you have. Good luck and fingers crossed! LOL. Tamiya white looks great, by the way, as it usually does. I presume you airbrushed it on, rather than rattle-can applied? Link to post Share on other sites
chrispisme 1,380 Posted December 1, 2020 Author Share Posted December 1, 2020 16 minutes ago, TheyJammedKenny! said: Wow! I would be reluctant to position any model in the way you have. Good luck and fingers crossed! LOL. Tamiya white looks great, by the way, as it usually does. I presume you airbrushed it on, rather than rattle-can applied? Thanks! yes airbrushed and, dry to the touch in minutes (that’s why I feel safe leaving it this way) but...DO NOT mask it for at least 24 hours! Experience says it will take on marks from the tape that will need to be sanded out...ask me how I learned that tough lesson. the flat paint can be masked minutes after spraying with no problem but the gloss is a different issue 2 Link to post Share on other sites
Vesa Jussila 616 Posted December 1, 2020 Share Posted December 1, 2020 Looks nice surface. Link to post Share on other sites
chrispisme 1,380 Posted December 2, 2020 Author Share Posted December 2, 2020 Thanks guys! I spent a bit of time (waiting for paint to dry) working on wheels and props. amongst other things. As I was working on the props I was less and less impressed by them but, I did them up to completion. I may yet saw the blades off (a couple are warping and show seams) and re-do with sheet plastic. Thanks for looking 4 Link to post Share on other sites
chrispisme 1,380 Posted December 2, 2020 Author Share Posted December 2, 2020 undercarriage fitted (wheels not glued on yet due to still needing flat spots) should be able to set it up on it's pegs tomorrow... 4 Link to post Share on other sites
busnproplinerfan 1,730 Posted December 2, 2020 Share Posted December 2, 2020 Looking more like it wants to fly. 1 Link to post Share on other sites
Team Aer Lingus 438 Posted December 2, 2020 Share Posted December 2, 2020 Excellent work it's starting to blossom into a very very nice model outstanding work so far Chris thanks for sharing regards Eamonn 1 Link to post Share on other sites
Space Ranger 3,254 Posted December 2, 2020 Share Posted December 2, 2020 17 hours ago, chrispisme said: undercarriage fitted (wheels not glued on yet due to still needing flat spots) should be able to set it up on it's pegs tomorrow... Looking great! However, I have found it's much easier to achieve a correct "sit" if the wheels are glued to the landing gear ("undercarriage") and allowed to fully harden, then place the model on a sheet of sandpaper and gently move it back and forth to flatten the tires ("tyres"). 1 Link to post Share on other sites
fjaweijfopi4j48 38,532 Posted December 2, 2020 Share Posted December 2, 2020 16 minutes ago, Space Ranger said: Looking great! However, I have found it's much easier to achieve a correct "sit" if the wheels are glued to the landing gear ("undercarriage") and allowed to fully harden, then place the model on a sheet of sandpaper and gently move it back and forth to flatten the tires ("tyres"). That may work when you have a rock-solid LG attachment, otherwise it may be as disastrous as advice given by your friend "Star Lord" of the Guardians of the Galaxy! (By the way, can you pull some strings and get me a date, I mean an autograph, from Gamora?) 1 Link to post Share on other sites
Space Ranger 3,254 Posted December 2, 2020 Share Posted December 2, 2020 43 minutes ago, Moa said: (By the way, can you pull some strings and get me a date, I mean an autograph, from Gamora?) Sorry, but her homeworld Godthab Omega is outside the jurisdiction of the Corps of Space Rangers. You'll have to speak with Silver Surfer; I understand he knows her quite well. 1 Link to post Share on other sites
fjaweijfopi4j48 38,532 Posted December 2, 2020 Share Posted December 2, 2020 On 12/2/2020 at 2:31 PM, Space Ranger said: Silver Surfer Silver surfer, yeah, right, another wannabe surfer dude. We here in California will have none of it! (And I will shut up now, before I am kicked off this thread! Sorry Chris!) 2 Link to post Share on other sites
