perdu 30,905 Posted November 25, 2020 Share Posted November 25, 2020 Blimey! I love this one. 1 Link to post Share on other sites
Team Aer Lingus 442 Posted November 25, 2020 Share Posted November 25, 2020 That's really impressive work taking shape nicely loving the attention to detail thanks for sharing regards Eamonn 1 Link to post Share on other sites
chrispisme 1,380 Posted November 25, 2020 Author Share Posted November 25, 2020 Ice shields. Since I sanded them off the DHC-6 to better represent the aircraft I was trying to build, I've decided I should add them to this model. The ice shields are offset from side to side relative to how the ice would fly when thrown from the props. Higher up on the port side lower on the stbd. side. I've made mine using a template cut from a roll of post it note type tape (very low tack) transferred that template to .005" sheet styrene cut out and glued that to the model. Here's the paper (tape) templates; test fitting/tweaking the fit; stbd side glued in place; port side glued on; the fun continues, thanks for looking 6 Link to post Share on other sites
chrispisme 1,380 Posted November 26, 2020 Author Share Posted November 26, 2020 A little more accomplished today. Empennage built up and seams filled. Beware anyone building this kit, the panel lines each side of the vertical stabilizer and top and bottom of the horizontal stabilizers are not symmetrical top to bottom or side to side. Much filling and re-scribing is need required to make the panel lines match from side to side...let alone accurate. Kit flap track/followers on the left, sheet plastic (and resin) copy replacements on the right Sponson painted inside and fitted, filler and sanding (the rule of this build) underway Thanks for looking 8 Link to post Share on other sites
fjaweijfopi4j48 38,532 Posted November 26, 2020 Share Posted November 26, 2020 One more step forward on this masterful build. 1 Link to post Share on other sites
mark.au 1,156 Posted November 26, 2020 Share Posted November 26, 2020 Fascinating to watch someone doing something I could not do myself, but instead pick out nuggets of technique and approach for inspiration that may help me in my assembling. Great stuff, thanks for sharing. 2 Link to post Share on other sites
Romeo Alpha Yankee 7,478 Posted November 26, 2020 Share Posted November 26, 2020 Good to see you are overcoming the issues (self imposed and otherwise ) . I am also picking up some techniques Link to post Share on other sites
Vesa Jussila 616 Posted November 26, 2020 Share Posted November 26, 2020 These builds from masters are something to follow for lesser souls like me. Link to post Share on other sites
chrispisme 1,380 Posted November 26, 2020 Author Share Posted November 26, 2020 13 hours ago, mark.au said: Fascinating to watch someone doing something I could not do myself, but instead pick out nuggets of technique and approach for inspiration that may help me in my assembling. Great stuff, thanks for sharing. I didn’t think I could build a vacuform kit either... until I did. Not that I’m any good at it... Don’t let them scare you, it’s a good opportunity to build something you may never get in I.M. form. 12 hours ago, Romeo Alpha Yankee said: Good to see you are overcoming the issues (self imposed and otherwise ) . I am also picking up some techniques between Broplan and me it funny I’m this far along... 8 hours ago, Vesa Jussila said: These builds from masters are something to follow for lesser souls like me. Thank you, I wouldn’t consider myself a master...experienced yes, but not a master. 1 Link to post Share on other sites
chrispisme 1,380 Posted November 26, 2020 Author Share Posted November 26, 2020 The sponson is faired in and, so far looking ok. and work has commenced on fitting the main wings; almost a full tube of Tamiya putty so far on this model. Thanks for looking 5 Link to post Share on other sites
chrispisme 1,380 Posted November 27, 2020 Author Share Posted November 27, 2020 All the airplane shaped parts are all finally in place, the upper rear fairing of the wing to fuselage joint is still taking filler and attention to fair in but I think that may be the last big job. I've begun adding some grills to the sponson and work has started on the main gear and wheels. undefined Thanks for looking 8 Link to post Share on other sites
fjaweijfopi4j48 38,532 Posted November 27, 2020 Share Posted November 27, 2020 I see a model airplane there! 1 Link to post Share on other sites
stevehnz 10,410 Posted November 27, 2020 Share Posted November 27, 2020 The lines of it are looking really good in that last photo. Coming on a treat. Steve. 1 Link to post Share on other sites
Team Aer Lingus 442 Posted November 27, 2020 Share Posted November 27, 2020 This is shaping up to be an incredible build outstanding work so far well done thanks for sharing regards Eamonn 1 Link to post Share on other sites
chrispisme 1,380 Posted November 27, 2020 Author Share Posted November 27, 2020 Thanks guys! I think most of the heavy lifting is done...I've started adding some of the details and some P.E. to the model. Nothing specific just caps vents latches etc. etc. just to busy it up where I can. with the wing faired in, I've begun using Tamiya putty to sharpen up the edges. This is mostly a matter of add a thin smear sand, add a thin smear sand etc. the cargo door hinge stolen/borrowed (as is all the P.E.) from left overs from other kits scratch built flap tracks now (finally) glued on becoming more enjoyable now that it looks like an airoplane and mostly over the hump. Thanks for looking 9 Link to post Share on other sites
Vesa Jussila 616 Posted November 27, 2020 Share Posted November 27, 2020 Really good progress. I think I need to build one of these just for memory of old days. So many times walking in as a last passenger from London connection at Friday Saturday night... Link to post Share on other sites
chrispisme 1,380 Posted November 27, 2020 Author Share Posted November 27, 2020 9 minutes ago, Vesa Jussila said: Really good progress. I think I need to build one of these just for memory of old days. So many times walking in as a last passenger from London connection at Friday Saturday night... Thanks! I'd be quite happy to see someone else build one!! 1 1 Link to post Share on other sites
TheyJammedKenny! 1,341 Posted November 28, 2020 Share Posted November 28, 2020 Really nice! Your efforts are paying off. What plans do you have for masking the windows to prevent overspray from fouling your nice interior? Link to post Share on other sites
chrispisme 1,380 Posted November 28, 2020 Author Share Posted November 28, 2020 31 minutes ago, TheyJammedKenny! said: Really nice! Your efforts are paying off. What plans do you have for masking the windows to prevent overspray from fouling your nice interior? Thanks! Like the Twotter, I'm masking the cabin windows with PVA glue. I have applied that as we speak...(as I type I guess) Running with an idea that popped into my nogging while painting the black marks for the cabin windows, I shot paint through the flight deck windows onto tape, stuck that tape to clear acetate (packing for a toothbrush) and cut out the window shapes, the result was not too shabby giving me nice clear cockpit windows. here's the clear plastic with the painted tape stuck behind; cockpit windows glued in with PVA; The kit wheels are.....yucky. So I cut off the oblong, lop-sided nose gear axle and replaced it with a brass rod which will be fitted with DHC-6 nose wheels sanded to a more appropriate diameter (smaller) The main wheels are even worse than the nose wheels, I found a couple of wheels in the spares box. The diameter is close, actually a little smaller with nice detail so I cast a couple more for the dual wheels on the main gear. The real plane's outer wheels have a kind of hub cap over them, only the inners will need the details but they came out not too shabby either. The prop is also of my cobbling (firkytootling) the casting warped but I think I can straighten it out, or make another. Thanks for looking 7 Link to post Share on other sites
fjaweijfopi4j48 38,532 Posted November 28, 2020 Share Posted November 28, 2020 Extra work on everything, brownie points for Modeling Heaven! 1 Link to post Share on other sites
chrispisme 1,380 Posted November 28, 2020 Author Share Posted November 28, 2020 6 minutes ago, Moa said: Extra work on everything, brownie points for Modeling Heaven! Thanks I'll need those brownie points! 2 Link to post Share on other sites
Team Aer Lingus 442 Posted November 28, 2020 Share Posted November 28, 2020 Taking shape nicely loving the work on the cockpit windows regards Eamonn Link to post Share on other sites
TheyJammedKenny! 1,341 Posted November 28, 2020 Share Posted November 28, 2020 Great technique on the flight deck windows! Are you using Zap 560 Canopy Cement? It works wonders--and I don't work for them or hold shares. The tires and landing gear struts are strongly reminiscent of Mach 2 fare, and I'm glad you found similar diameter wheels in your spares box. In pre-Covid days, our local club had several boxes of extra parts available for grabs at each meeting, and I dipped my hand in several times. For my 1/72 Caravelle, I stole main wheels from two Esci F-27 kits obtained at bargain prices, and used the nose wheels from an Aurora DC-9. 1 Link to post Share on other sites
chrispisme 1,380 Posted November 29, 2020 Author Share Posted November 29, 2020 Contrary to my better judgement, I'm still progressing on the ATR model, the main gear has come in to some attention and TLC today. After building a main gear leg up and dry fitting it to the model, I turned the model over to check the stance and the gear leg dropped out of place hit the floor and vanished...I searched for quite a while with no joy. I gave up started to scratch build another and dropped it as well! I was getting pretty frustrated looking for tiny little parts on the floor. My wife came to see what the commotion was (It's not often she hears furniture being moved in the hobby room) when I told her what had happened (twice) she bent down and picked up a part...the first one I lost! we never did find the second one. So, back to work and, here's where I'm at tonight. Still needing brake lines etc. but back in this realm; dry fitting; Looks like an airplane with the props (just temporarily stuck on) in "hotel mode", prop. brake on on right side... this was the warped prop. I gave up and cut the blades off. It'll eventually have two feathered props in place Thanks for looking 6 Link to post Share on other sites
fjaweijfopi4j48 38,532 Posted November 29, 2020 Share Posted November 29, 2020 Eventually you will be able to build entire models from the kit parts lying under your desk 1 5 Link to post Share on other sites
